Author Topic: Morane Saulnier typ N - Eduard, 1:48  (Read 7505 times)
Offline KrzysiekK
« on: December 18, 2013, 06:37:00 AM »
Hello everyone,
It seems that it would be a short thread, because the amount of plastic parts is rather poor but this is only my first assumption.
Some discrepancies between the possible real outlook and the manufactures outcome are so far as follows:
-          lack of wood floor?? Decided to get rid of it
-          lack of throttle?? Decided not to assemble
I started to adapt the chair to possible look. I do not have any PE parts, so I had to slim down plastic, drilled holes, prepared seat belts from notebooks covers used 30 years ago in primary schools and here it is:
Re: Morane Saulnier typ N - Eduard, 1:48
« Reply #1 on: December 18, 2013, 08:03:00 AM »
The Morane sounds like an interesting build, Krzysiek.  I don't
know if it is my computer, but I am unable to see any photos.
I look forward to following your project.
« Reply #2 on: December 18, 2013, 10:06:56 AM »
Same here!
« Reply #3 on: December 18, 2013, 11:32:45 AM »
Same here!
ja też.  I sure would like to see it, though!
(Next Day):
Ah!  There they are!  Very nice start, K.  I'm looking forward to watching this one come together.
« Last Edit: December 19, 2013, 02:57:52 AM by coyotemagic »
Offline Cimmerian
« Reply #4 on: December 18, 2013, 05:42:35 PM »
No pictures for me either. :(
Regards, Ken
Offline xmald
« Reply #5 on: December 18, 2013, 06:11:22 PM »
It`s a nice start Krzysiek! The seat looks really good! I would use a drop of some clear gloss enamel for the instrument faces. I use the clear nail enamel - it`s rather thick which helps to create a desired layer. Should you want to use it be absolutely sure that the decal is dry and give it a protective coat of some clear acrylic paint - I destroyed one of the decals because the enamel dissolved it.
Keep up the good work on MS N.
Best regards
Filip
« Reply #6 on: December 18, 2013, 06:20:45 PM »
For instrument "glass", you could use Future(Kleer) acrylic floor polish or
Microscale Krystal Kleer.  I have used both and they both work very well.
Offline KrzysiekK
« Reply #7 on: December 22, 2013, 09:57:28 PM »
Sorry for lack of pics..server host failure, now should be ok
Accepted by you, so going deeper..
Let’s take the wings on the desk..
- 1st layer on bottom: H89 with little drops of H57
- masking the frames
- 2nd layer on bottom: same mixture with few drops of white.
- used same mixture for upper framing
- masking the upper frames
- and final Vallejo 71028 will be applied on both sides. Hope it will be worth of doing. will see
regards
K
Offline xmald
« Reply #8 on: December 22, 2013, 10:05:05 PM »
It will most certainly pay off! I`m anxious to see the result!
Keep up the good work mate!
Best regards
Filip
« Reply #9 on: December 22, 2013, 11:32:17 PM »
Wow!  Now that I can see the photos, KrzysiekK, it's evident how
talented you are.  Very nice work.  I will enjoy seeing the rest of your project.
Nicely done. :D
« Reply #10 on: December 23, 2013, 11:48:44 AM »
Now that the pictures are visible I must say you are off to an Impressive Start! Keep up the great work and I am Looking forward to your progress!
Offline KrzysiekK
« Reply #11 on: December 30, 2013, 06:13:43 AM »
Thanks for support ;D
You were right it was worth of doing.
Going further lets take fuselage into attention. The red color will overweight this thread, so red front was done.
and later on I have looked at the decals and said to myself: those red stripes does not work.So again..
« Reply #12 on: December 30, 2013, 06:37:57 AM »
The wing turned out beautiful, well done, and I like the shade of red you have used on the front of the plane, looking forward to more updates.
Offline xmald
« Reply #13 on: December 30, 2013, 09:07:27 AM »
I like it very much!! Are you going to chip the cowling and the spinner?
Best regards
Filip
Offline miecio52
« Reply #14 on: December 30, 2013, 04:51:00 PM »
Very nice work, bravo :D
 Mietek
 IPMS Poland / Silesia
