Author Topic: Albatros D.III Jasta 11, Eduard 1/48  (Read 5329 times)
Offline jarosz92
« on: December 09, 2013, 07:37:07 AM »
Hello,
I started on Eduard's Albatros D III. I will make M. von Richthoffen's plane (series D.1910-D.2200/16). I use Eduard's photo etched parts and a few handmade parts.
At the beginning seat.
And frames
And equipment of cockpit: fuel system, hand air pump, Bosch magneto starter. I made new board for valves ( Eduard's board is too small).
I made new control stick based on Windsock.
Then I found another drawings from 1919. This is polish description of the plane. In these drawings the stick is like in DV (not DII)
So I will make new.
Re: Albatros D.III Jasta 11, Eduard 1/48
« Reply #1 on: December 09, 2013, 07:53:38 AM »
Incredible is the first word that comes to mind, your attention to detail is amazing, it is hard to believe that some of these items are 1:48 scale, we don't see this much detail in larger scales. The fuel distribution panel is brilliant as is the control column, and to turn around and make a second one is a credit to you. Your seat is superb as is the pressure pump, this is going to be a build to follow very closely, very well done.
Offline Rob Hart
« Reply #2 on: December 09, 2013, 08:24:13 AM »
What you have done so far looks spectacular! If you ever decide to sell copies of those parts, I'll be your first customer. I can't wait to see the rest of the model.
« Reply #3 on: December 09, 2013, 10:59:31 AM »
Nice!
Offline Jacek
« Reply #4 on: December 09, 2013, 11:44:49 PM »
Beautifully done details.
I look forward to continued.
« Reply #5 on: December 10, 2013, 12:43:19 AM »
   Incredible detail and more so given the scale............this is Modelling absolute top of the Class! I'm with Des; this will be a Build to follow very closely.
   Well done Jarosz! 8)
« Reply #6 on: December 10, 2013, 12:45:11 AM »
I can't say it any better! I also will follow your incredible build!
« Reply #7 on: December 10, 2013, 02:14:06 AM »
WOW!!  Amazing work Jarosz.  ;D  Beautifully crafted details in smaller scale.  Thanks for sgharing your talents with us.  :D  This will be a real learning experience to follow you build, and the model will be fantastic!
« Reply #8 on: December 10, 2013, 02:18:44 AM »
Stunning scratch-building, Jarosz!  I am even more amazed that it is in
1/48th scale.  Absolutely first-class attention to detail. I am in awe of
modellers with such talents.  Thank you for sharing your work.
« Reply #9 on: December 10, 2013, 02:23:38 AM »
My exact thoughts, expressed by Des.  Brilliant work, Marcin!
Offline jarosz92
« Reply #10 on: December 10, 2013, 06:11:18 AM »
Thank you for comments. I'm glad you like it :)
If you are interested: http://www.muzeumlotnictwa.pl/digitalizacja_archiwaliow/digitalizacja.php This is a multimedia archive  of the Museum of Polish aviation. There is a lot of interesting books, instructions and descritpions (for example Avro or Salmson) in English, German, French and Polish.
« Reply #11 on: December 10, 2013, 06:44:40 AM »
Thank you for the link to the museum, there is some very interesting photos and information, I will spend a bit of time reading it today.
Offline jarosz92
« Reply #12 on: December 10, 2013, 07:04:43 AM »
I'm sending 2 photos (I forgot to post them). A few switchers and Bosch magneto stater.
« Reply #13 on: December 10, 2013, 07:15:56 AM »
 :o
Offline Zabu
« Reply #14 on: December 12, 2013, 10:32:18 AM »
If you didn't had  tell us the scale... i could swear that this was a 1/32 model.
Brilliant detailing work.
