Author Topic: Barker's Snipe -rigging wires what size?  (Read 8631 times)
Re: Barker's Snipe -rigging wires what size?
« Reply #30 on: December 12, 2013, 09:27:53 PM »
Egads!  I'm so far behind in this subject that I will be coughing dust for a week. ;D
  However, it will be very interesting to see how you fellows make out. Carry on, my
modelling heroes.  :D :D
Offline petrov27
« Reply #31 on: December 12, 2013, 10:57:48 PM »
Found this image online - wish it was easier to read but maybe you can pull out the sizes from it with a magnifying glass?
-Patrick
Offline WillScarlet
« Reply #32 on: December 13, 2013, 01:49:58 AM »
      Looks as though petrov27 has found what is needed.
   As an aside and addendum to my last post, I also used the PE wire in the cockpit interior, the cross wires in the upper wing above the cockpit, and the tail planes with excellent results. I can only conclude there is flexing between the wings causing the bowing of the wires. If I were to try the PE wires again I wonder if running them through the lower wing, drawing them taught with weight, and gluing would work?
Offline Dave in Dubai
  • Beyond the blue horizon
« Reply #33 on: December 13, 2013, 07:04:19 PM »
Good find Petrov thankyou.
Interesting to note that the date of the drawing is 1925 , and that there is a comment that " complete set of wires should be tried up on machine before large quantities are made".
Looks as if they were making a new batch of wires perhaps of a strengthened variety?
I also presume the dimensions provided on the drawing wouldnt be too far away from an in service machine from 1918...-at least not in 1/32 scale!
Once again many thanks for the information.  :)
