Author Topic: WNW Fokker D.VII (OAW), "Seven Swabians", Jasta 65, Wilhelm Scheutzel  (Read 8384 times)
Re: WNW Fokker D.VII (OAW), "Seven Swabians", Jasta 65, Wilhelm Scheutzel
« Reply #15 on: November 21, 2013, 06:11:24 AM »
Thanks much guys!  Bud, I used a combination of paints for the fuselage and undercoating for the lozenge decals.
I used Pollyscale Sand to coat the wings, with a couple of coats of Future to give a nice gloss for the decal application.
For the fuselage, the WNW Decal instructions called for Tamiya #66 Light Gray, but when I applied the first coat it looked too dark, so I added some Tamiya white to lighten it up for the final coat.  I was going to use the specified Tamiya Hull Red for the cowling and tail surfaces, but I sometimes have a problem with getting Tamiya paints thinned properly, and the gray had gone on a little grainy, so I found a bottle of Pollyscale Wisconsin Central Maroon on my shelf that matched well, and it airbrushed on smoothly and looks great.  The fuselage was also treated to coats of Future before the rather large mural decals and balkenkreuz were applied to the sides, and the crest to the fuselage spine.  Pollyscale Clear Satin sealed everything and evened out he sheen.
The fin and rudder are Pollyscale Reefer White.  The metal panels on the top and bottom of the fuselage, and the wheel covers, were coated with Misterkit Albatros Mauve.  After drying for a day, I applied patches of sticky-tack as masks and then airbrushed these parts with an old bottle of Pollyscale Fokker Dark Green.  Removing the sticky-tack after the green paint is dry yields a soft edge mottle of mauve and dark green.
I am progressing well with assembly, and hope to have final photos up by this weekend.  :D
« Reply #16 on: November 24, 2013, 11:19:15 AM »
Weekend update time.  Almost done--just the landing gear to add.  I couldn't quite get the lighting right for these, but here she is with wings:
The mural on the port side dffers somewhat from that on the starboard.
This has been a fun build, but with some minor challenges.  I like this aircraft and this kit.  I hope to have her done by Thanksgiving Day.  ;D
« Reply #17 on: November 24, 2013, 11:26:15 AM »
Looking brilliant Bob, I love all the colours you have used, they all fit in perfectly, and your decal application has been superb, looking forward to seeing her up on her feet.
Offline mc65
« Reply #18 on: November 24, 2013, 11:37:55 AM »
wonderful!
I like very much the horizontal part of the tail's color, it's perfect! :D
« Reply #19 on: November 24, 2013, 12:40:58 PM »
  Awesome works my old friend!
« Reply #20 on: November 24, 2013, 02:32:03 PM »
Hi Bob:
Gotta love those Sieben Swabians!  I am a little behind you on my DVII F.  I like your model and the way it is turning out.  Looking forward to the finishing touches.
« Reply #21 on: November 24, 2013, 05:10:39 PM »
Just a super job, Bob.  Your paint work as well as the decaling is flawless.
I look forward to the final photos.  Well done!
« Reply #22 on: November 24, 2013, 10:48:27 PM »
Your DVII looks gorgeous! Beautiful construction,painting, and decaling!!
Offline Zabu
« Reply #23 on: November 26, 2013, 12:13:47 PM »
Beautiful!
Great work all around.
« Reply #24 on: November 28, 2013, 09:01:52 AM »
Thanks gents!  Here are some final shots from the bench, on her feet.  She's done except for the prop, which will be out of the drying box tomorrow.  I'll post better pix in completed models this weekend.
The only problem I encountered was that the aircraft did not sit level on the landing gear when attached, perhaps because the struts are scale thickness and very fragile.  Fortunately, I was able to level things up with the landing gear rigging, and all is well.  I look forward to building more WNW D.VIIs.
« Reply #25 on: November 28, 2013, 11:07:55 AM »
Great looking build!!
« Reply #26 on: November 28, 2013, 12:38:33 PM »
Hello Bob:
I gotta tell ya!  It looks mighty sweet!
Offline stefanbuss
« Reply #27 on: November 28, 2013, 04:23:44 PM »
Good that you were able to recover the landing gear. Such a beautiful Fokker.
Stefan
