Author Topic: 1/72 Albatros DVa  (Read 3844 times)
Offline bari
1/72 Albatros DVa
« on: November 10, 2013, 07:23:03 PM »
Hi,  This is my first attempt at a WW1 subject. I bought a load of these little kits when Modelzone was having one of their periodic sales. I thought that they are cheap enough to get thrown into the bin if it all goes wrong.  I used the method of rigging shown in this thread on another forum  http://www.britmodeller.com/forums/index.php?/topic/72714-fitting-struts-rigging/  I first started with very thin wire but found it too difficult to get the tension right as when I did one bit the next one would make the first slacken off.  In the end I raided the wife's knitting basket and used what is described as 'knitting in elastic' which was just slightly stretchy but had little knobs of rubber attached to the thread which I had to rub off.  I also found that this thread was so flexible and thin that I could not get it into a blind hole on the lower wing so in the end I drilled all the way through both wings and just sewed the whole structure with one long length, almost. I had to do a shorter length for the bit from the lower front fuselage to the starboard wing and aileron.  This method seemed quite easy (beginners luck maybe) except I had to make the holes in the wings 0.4mm as my eyes are not what they should be, this meant I had to use quite a bit of super glue to fill the holes which caused a bit of overfill on the top of the lower wing. Once it had all dried I cut all the joining threads  off and sanded down.  I did use wire for the undercarriage and elevator cables but despite hanging quite a weight from the ends (enough to slightly distort the U/C) they still didn't tension properly. I also found that when trying to mask the upper wing for the rib tapes I was apprehensive about applying too much pressure in case the structure moved, so I though I would paint the upper wing and just touch up after for the next one.  Anyway a few photos, any observations and tips would be welcome.
Re: 1/72 Albatros DVa
« Reply #1 on: November 10, 2013, 07:51:02 PM »
Despite your woes with the rigging, it really is a great job on such a tiny model, Bari.
Not being a 1/72 scale modeller, I'm not sure what would be best for rigging...maybe
ez-line?  I hope to see more of your work.
« Reply #2 on: November 10, 2013, 07:56:11 PM »
For your first attempt at a WW1 biplane you have done an excellent job, congratulations on producing such a wonderful model in the tiny 1:72 scale. The finish on your model is very good and the rigging looks great, doesn't matter how you do the rigging as long as it works for you. It would be a good idea to completely finish the top wing before you fit it to the struts. I am looking forward to seeing your next build.
Offline Cimmerian
« Reply #3 on: November 10, 2013, 08:08:43 PM »
Really nice model. I've just finished a D.III, I used EZ line for the first time on there, it was the easiest way I've ever tried. I would certainly recommend it.
Regards, Ken
« Reply #4 on: November 11, 2013, 03:31:51 AM »
Outstanding first effort, Bari.  In spite your difficulties, the rigging looks nice and tight.  Nice work.
« Last Edit: November 19, 2013, 02:06:12 AM by coyotemagic »
Offline bari
« Reply #5 on: November 11, 2013, 07:08:21 AM »
Thanks you all for the nice comments, I really enjoyed the build and will practice on a few more and build up to the little Revell DH2 I've always wanted to build.
Offline Rob Hart
« Reply #6 on: November 11, 2013, 07:47:53 AM »
Nice job. I'll look forward to seeing that DH2.
« Reply #7 on: November 11, 2013, 11:32:01 AM »
I must agree with all of the others! Great first effort, especially with a small and rather Old kit that is generally not uo to modern standards. You have made it look great! By the way, I built more of those DVa than I can remember. They were 29cents at my local drug store when I was about 17, 1970ish  :-\
Offline AROTH
« Reply #8 on: November 11, 2013, 12:41:49 PM »
29 cents..................
my time period also. I remember it very well. Now, I feel very old.......... :'(
« Reply #9 on: November 12, 2013, 02:12:32 AM »
I can remember when these kits were 2 shillings (by 1970 they were 2shillings and sixpence or even more - not sure now as it is too long ago and I am too old to remember properly). For a first effort on what is a very old kit you have done an excellent job - very good finish and very good rigging.
It happens that my first foray into serious biplane building was also this kit which I made in the mid 1970's and still have, but it is not as good as yours. Compared with later productions it is a crude kit but it is cheap and it does have potential to build into a good model - as your have clearly demonstrated. No doubt about it 1/72 scale is the best! I look forward to seeing more of your little gems.
Offline Epeeman
« Reply #10 on: November 12, 2013, 08:17:21 AM »
Bari,
Agree wholeheartedly with what others have already said - excellent first effort on a very dated kit!
« Reply #11 on: November 12, 2013, 11:27:20 AM »
Where I was, South Florida, I think it was Airfix  Craftmaster  packaging. I remember very WELL .29 on the end of the box!Funny how things jar memories. I was on a Summer trip up North with my Older Brother. He challenged me to do something Stupid for a Dollar. I remember thinking that the Dollar would buy 2 Airfix Dvs and a Triplane :o
Offline IFF1418
« Reply #12 on: November 12, 2013, 11:39:54 PM »
Hi Bari,
Indeed, great work on this tiny scale. I couldn't do it. And besides your rigging looks great.
Kind regards
Patrick
