Author Topic: Using Mr. Metal Color  (Read 2969 times)
Offline Bribo
« on: November 07, 2013, 12:55:22 AM »
I've been trying out the Mr. Metal Color range of paints, I was wondering if those who use them varnish them after buffing?  I notice every time I touch them, I've got silver all over my fingers, but I was worried that doing a clear varnish over top would destroy the metallic effect.
If you do use a varnish, what do you recommend?
Thanks!
Brian Speerly
Offline Zabu
Re: Using Mr. Metal Color
« Reply #1 on: November 08, 2013, 05:59:26 AM »
Hi Bribo.
You should not have any problems in the metallic effect after applying clear varnish, i advise you to try it first in a scrap plastic part or plastic card.
Give it a coat of metal color and then apply the varnish, if the look suits you then go on to your model.
Offline Ian from Doncaster
« Reply #2 on: November 08, 2013, 06:14:34 PM »
I would use Klear, but give the metal surface a really good buff up first?
« Reply #3 on: November 08, 2013, 07:19:15 PM »
I use Mr Metal Colors quite often, I use the stainless on all my rigging lines which never get touched so coating is not an issue. But for other areas that may be handled I polish the paint to the desired sheen then spary it with Humbrol Gloss Cote (their spelling not mine), this will stop the metallic paint rubbing off.
Offline Bribo
« Reply #4 on: November 09, 2013, 01:12:33 AM »
Thanks for the advice!  I'll give it a try.
Brian
Offline Ronkootje
« Reply #5 on: November 24, 2013, 05:51:31 AM »
Hi,
I use this stuff specialy made for sealing buff paints
Testors Paint 1409
Metalizer Sealer
Regards Ron
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #6 on: November 24, 2013, 06:27:22 AM »
Hi,
I use the gloss varnish from Alclad - Aqua Gloss 600. Its quite thin varnish and can be used also for clear parts like "future" or before decals :)
Hope this helps
Best regards,
Sasho
Think globally, act locally!
« Reply #7 on: November 24, 2013, 07:38:31 AM »
Ron - Does the application of Testors Paint 1409 Metalizer Sealer change the appearance of the polished metallic finish which is achieved from Mr Metal Colors?
Sasho - Is the Alclad Aqua Gloss 600 compatable over any type of paint and is it quick drying?
Offline Ronkootje
« Reply #8 on: November 25, 2013, 10:39:50 PM »
Not in my opinion it only fixes the pigments in place.
