Author Topic: Re: WNW 1/32nd Bristol F2b "McKeever"  (Read 6799 times)
« on: October 29, 2013, 09:14:53 AM »
   Thanks to all you Guys that added comments after my last entry. Zabu, Gary,, Mike, Adam, Ernie, Bud and Patrick. I really appreciate you taking the time to offer such great comments, you may drive me to drink (in celebration) at this rate!
   It's hard to believe I opened this Thread last Nov. 16th, been quite a busy year and the stop and go nature of this Build is no way to run a Model line! She is finally COMPLETED, Here's my usual final photos as coached by my mentor, Mr. Bean..............
   The loose wires are the two I mentioned earlier, left disconnected as they would be to remove the engine cowling panels. I used a combination of Bobs' and Gas Patch buckles for the ends.
  Some close up shots:
   Two of the undersuface weathering..
  As you can see She has a few "warts", the Scarff Ring bungees aren't what I had hoped to accomplish and I believe less bungee cord on the wheel axles would have been more accurate. Also, I may do another Lewis Gun, it's just not quite "clean" enough for my eye.
  The Build was incredibly enjoyable, it's probably the best engineered Kit I've ever done. Most of the obstacles I encountered were very much a product of the broken sequence of the Build, in other words induced by the Builder! This is still not a Kit for a beginner, the aircraft design with the "underslung" lower wing has to be carefully worked or the whole assembly can be out of whack. The struts for the attachment of the lower wing were the only criticism I have of the Kit; the Instructions just weren't that clear to me. Last, the rigging can be a challenge. I left off the second set of bracing wires on the vertical stab as the only photos I found of it were on the TVAL Bird. The real challenge was thinking through the sequence to ensure new wires going on didn't result in old wires getting torn off!
   In summary, an outstanding Kit, the best WNW I've tackled to date, and a very satisfying Build. I learned a lot from this one!
   Here's two final shots of her on the Base, I'll probably be adding to the Base with some maintenance stuff (Bench, a few bits and tools, perhaps a ladder, and I'd like to add some mud and yellow grass as well.
    Des, I guess you can move this over to Completed Models...She's finally done! :) :) :)
Re: Re: WNW 1/32nd Bristol F2b "McKeever"
« Reply #1 on: October 29, 2013, 09:20:15 AM »
An awesome and STUNNING build! Beautifully done all around!!!!
Offline mc65
« Reply #2 on: October 29, 2013, 10:18:11 AM »
sigh...
she's so a beauty!!
« Reply #3 on: October 29, 2013, 10:31:02 AM »
Fabulous Biff, Lance!  I will aspire to achieve your results whenever I get around to mine.  You can be rightly proud of this beautiful build. ;D
« Reply #4 on: October 29, 2013, 10:32:32 AM »
Congratulations Lance on creating an absolute masterpiece, your skills as a talented model maker are very apparent in this model, the overall finish is superb and your attention to detail is unsurpassed, you have done Captain Andrew McKeever proud.
« Reply #5 on: October 29, 2013, 11:46:32 AM »
Lance, you have really out-done yourself.  Wonderful model.  Thanks
for sharing this marvelous build with us.
« Reply #6 on: October 29, 2013, 12:03:59 PM »
Hello Lance:
You have done an absolutely outstanding job on this model.  Knowing how difficult it is to start, stop and start again after long periods of time, this makes it especially outstanding.  As has been mentioned, the finish, the rigging, the engine, all the details, truly outstanding.  I still don't have the guts to start one, but seeing your model sure makes it tempting.
Offline LindsayT
« Reply #7 on: October 29, 2013, 03:06:56 PM »
Lovely work, Lance! A great tribute to a Canadian hero. Well done.
Lindsay
« Reply #8 on: October 29, 2013, 05:28:21 PM »
Great to see this one completed. After a year, oh my dear... But you should be really proud of this one. Congratulations.
Offline FokkerFodder
« Reply #9 on: October 29, 2013, 06:02:07 PM »
a wonderful build and I've already picked up a few modelling tips that i'm going to try on my Pup....
cheers
FF
« Reply #10 on: October 29, 2013, 06:50:48 PM »
Brilliant Lance,
Beautiful finish, incredible detail, it looks like a years work!  ;D
Offline Jacek
« Reply #11 on: October 30, 2013, 02:07:18 AM »
Simply beautiful!
Congratulations.
Jacek
« Reply #12 on: October 30, 2013, 02:17:47 AM »
  Lance,
Now that's one AWESOME Bristol my old friend. Top Shelf Master level skill and craftsmanship from the very beginning to completion.
P.S Any snow yet?
« Reply #13 on: October 30, 2013, 02:18:13 AM »
Truly extraordinary, Lance!  This is easily your best yet.  Well worth the wait.
Offline Epeeman
« Reply #14 on: October 30, 2013, 04:38:06 AM »
Lance,
Very, very nice - rid shading and weathering are first rate.
Glad you got there in the end!
Whats your next project then, mate?
