Hints and Tips/Questions about modeling
Heat to Tighten Mono Rigging
Topic: Heat to Tighten Mono Rigging (Read 5364 times)
lcarroll
October 13, 2013, 02:50:00 AM »
I've got a couple of "runs" of monofil rigging that have sagged on my Bristol Fighter. I recall seeing reference to using heat to tighten it up; was it heating a metal object (nail, blade etc) and holding it near by?? I don't think a hairdryer would be prudent given other areas would get the effects, and don't think an open flame prudent either!
I've never had this problem before, I think I just didn't tighten it up on installation and failed to notice it ("Old Man's Syndrome"!) Has anyone suffered this problem and repaired it or do I have to remove the runs and start over again? Given the rental costs of trained insects to get the job done between two wings and around the good rigging I am hoping for an easier solution!
Cimmerian
Sr. Member
Re: Heat to Tighten Mono Rigging
October 13, 2013, 03:32:00 AM »
I've had that happen before. I found that was the only time being a smoker was useful.
Regards, Ken
DaveM
Jr. Member
October 13, 2013, 04:34:44 AM »
Hi Lance,
I've used a lighted joss stick to tighten up slack rigging in the past.Just hold the stick approx an inch or so away from the line(check the heat intensity by putting a finger in the smoke,not directly on the heat source!),or practice with a piece of rigging held between 2 blobs of blu-tac.Let the smoke pass over the line and guage the results with repeated passes until the required rigidity is obtained.Take it slow man,you don't want to melt the line.An added benefit is,if the line shrivels and breaks,the calming effect of the joss stick overcomes the prospect of you pulling your hair out
Dave.
bobs_buckles
Freedom isn't free.
October 13, 2013, 04:36:24 AM »
Hi Lance,
A soldering iron works well - But be quick!
VB
coyotemagic
October 13, 2013, 05:05:00 AM »
Lance, I have had a great deal of luck using wooden matches. I light a match, blow it out, then pass the smoke from the extinguished match under the offending line. Just don't get the hot match head too close. Good luck, buddy.
Nigel Jackson
October 13, 2013, 05:30:44 AM »
Lance, I've tried broadly the same approach as Bud when trying to tension rigging made from stretched sprue. Instead of the matchstick though I've used a cocktail stick, lit the end, blown it out and let it cool for a second. It took me far too long to remember that since heat rises I needed to angle things accordingly!
lcarroll
Reply #6 on:
October 13, 2013, 05:54:00 AM »
Thanks for all the great info in record time, Guys. I think I'll try the wooden match method first since I gave up smoking several years ago. As soon as I read Cimmerian's reply I found myself having very evil and dangerous thoughts regarding how much of a cigarette would be left over if I used one as the heat source! It never goes away........... I'll let you all know how it works out.
Cheers, and Thanks again,
Cimmerian
Sr. Member
Reply #7 on:
October 13, 2013, 06:50:37 AM »
Do not give in to the temptation, it really isn't worth it. Use the other guys suggestions - they were much better, especially as I'm pretty much a novice at this biplane stuff.
Regards, Ken
Ernie
"Once more into the breach"
Reply #8 on:
October 13, 2013, 07:59:58 AM »
Thanks for the this thread, Lance. I was thinking of the hair dryer, but after reading
here maybe I'll go the wooden match route as well. It probably makes more sense
if there is only one or two to tighten.
Ernie
Des
Reply #9 on:
October 13, 2013, 09:23:22 AM »
I have used both the hair dryer and a soldering iron, I prefer the soldering iron. I use a small soldering iron and allow it to come up to full heat, I then place the tip of the iron under the line to be tensioned, about 10 - 15mm from the line and moving it along the length line, a back and forth motion. If you hold the heat in one place it will melt the line. Be very watchful of all othe rigging lines because if the iron touches one it will melt and break instantly.
IanB
Reply #10 on:
October 13, 2013, 09:34:33 AM »
I use old knife blades, heated in a flame and held close. But as Des says, keep an eye on the other wires, if you touch one you WILL have to replace it!
Rob Hart
Reply #11 on:
October 13, 2013, 12:21:48 PM »
I've also used sticks of incense (joss) as heat source. In my experience the rigging eventually went slack again over time. I'll also echo the warnings previously mentioned having once managed to melt a gouge in the leading edge of a Nieuport wing through carelessness.
lcarroll
Reply #12 on:
October 14, 2013, 05:56:09 AM »
I used the extinguished match method, worked nicely however I may try the soldering iron in future; steady heat and evenly applied to the entire line makes sense. Thanks again for the feedback, great shopping here!!
TomR1981
Full Member
Reply #13 on:
October 14, 2013, 09:04:30 AM »
I've had this problem with some control wires. I tightened them with a lighter held a long way underneath but they just kept on sagging again so I'll be replacing them with EZ Line.
Is there a way of avoiding the problem in the first place? Maybe I needed to put them under more tension.
IanB
Reply #14 on:
October 14, 2013, 10:03:32 AM »
I do the same: drill through, then thread and tighten the line and hold it tight with a small doll's house clothes peg available from craft stores, then apply the superglue. The heat is just to tighten up anything I may have messed up!
