Under Construction
Eduard Nieuport 11
3
4
Topic: Eduard Nieuport 11 (Read 12432 times)
jessie_c
Jr. Member
Eduard Nieuport 11
September 23, 2013, 02:17:20 PM »
It having been far too long since I did anything here, it's time to share a build with the good folk herein. This is Eduard's Nie. 11 being built for a group build over on Aeroscale.
Are we seated comfortably? Then I'll begin.
"When once you have tasted flight you will walk the Earth with your eyes turned skyward
for there you have been and there you will always long to return." Leonardo Da Vinci
jessie_c
Jr. Member
Re: Eduard Nieuport 11
September 23, 2013, 02:18:12 PM »
Et voilĂ , here is the Eduard 1/48 Nieuport 11. This is a lovely kit and ought to present no problems for a fast assembly.
jessie_c
Jr. Member
September 23, 2013, 02:18:52 PM »
I've got the interior wood grain done.
The seat's drilled out and awaiting a Milliput seat cushion once the oil paint is dry
And the plywood grain is on the interior side walls and floor
jessie_c
Jr. Member
September 23, 2013, 02:19:33 PM »
Now that the oil paint has dried I can get a little more work done. I've sculpted a Milliput seat cushion, assembled the engine, and outlined the fuselage members with slivers of brown painted decal trim film.
I didn't bother with a picture, but I've got blue-grey paint on all the metal bits which will live in the cockpit.
jessie_c
Jr. Member
September 23, 2013, 02:21:48 PM »
A nice dark wash makes the details pop.
(Okay, I cheated a bit in this series of posts. I actually started work on this kit two weeks ago, but since watching paint dry for two weeks is actually quite boring, I've compressed the timeline a bit. Too bad that we're all caught up now and I can't do that anymore.)
LindsayT
"Somehow it didn't seem like war at all..."
September 23, 2013, 02:43:41 PM »
I haven't seen this one built before. Thanks for sharing.
Lindsay
Ernie
"Once more into the breach"
Reply #6 on:
September 23, 2013, 07:49:59 PM »
Good choice, Jessie. The bebe is a great little aeroplane. As with Lindsay, I haven't seen
it built before...about time, so thank you for bringing it to us. Great start. I'll be looking
for more updates.
Ernie
coyotemagic
Reply #7 on:
September 24, 2013, 12:16:30 AM »
It's good to see you back here, Jessie! Great start on an excellent kit. I built this one about a year ago and enjoyed it so much, I bought two more (well, actually one is a Nie.16). I look forward to watching yours come together.
jessie_c
Jr. Member
Reply #8 on:
September 24, 2013, 12:59:56 AM »
Here's an interesting camouflage question. From the two photos someone on another forum
pointed out
, there seems to be something of a mystery about the edge taping on the flying surfaces. The photo taken from
behind the aircraft
clearly shows that the edge taping was much lighter than the upper surface colours yet the one taken
from ahead
shows just as clearly that they're darker than the undersurface fabric, which has been established as clear doped linen.
What colour is darker than clear doped linen yet lighter than green and khaki camouflage?
uncletony
Reply #9 on:
September 24, 2013, 03:48:52 AM »
Quote from: jessie_c on September 24, 2013, 12:59:56 AM
weellll, not taking into account the effect of ortho film, here's a simple experiment that shows it could be a medium shade...
Youtube Channel
jessie_c
Jr. Member
Reply #10 on:
September 24, 2013, 04:34:49 AM »
That's what I've been thinking. I'm probably going to go with something like Tamiya's Buff, which is toward the bottom range of your smaller square.
Gilly
Full Member
Reply #11 on:
September 24, 2013, 05:04:01 AM »
Looking forward to watching your excellent work Jessie. I am sure I have one of these in the to do cupboard and seeing this you have helped narrow down my decision as what to do next
jessie_c
Jr. Member
Reply #12 on:
September 24, 2013, 06:23:06 AM »
I made major progress today. Here's the cockpit looking busy. The only aftermarket parts are a set of Eduard French seat belts and the aforementioned Milliput seat cushion. Everything else is straight out of the box
I added that little shelf behind the seat to block the view of the fuselage seam.
Nothing much happening inside the left fuselage half
Ready to close up
A little glue, lower wings and tailplanes later and we have an airplane happening!
Ernie
Reply #13 on:
September 24, 2013, 10:41:55 AM »
Good job on the build, Jessie. Looking forward to the next update.
Thanks for sharing with us.
Ernie
Dal Gavan
Sr. Member
Reply #14 on:
September 24, 2013, 04:23:22 PM »
That's coming along nicely, Jessie. Will you be doing the box-top scheme?
Welcome back.
Dal.
3
4
Under Construction
Eduard Nieuport 11
