Author Topic: Eduard 1/48 Fokker EV  (Read 10831 times)
Re: Eduard 1/48 Fokker EV
« Reply #15 on: October 16, 2014, 01:45:49 AM »
Very neat and crisp work Nigel!  Looks terrific. :D  Of course, we know how this one ends: one beatiful little E.V! ;D  Great job!
« Reply #16 on: October 16, 2014, 04:12:42 AM »
It is a superb work and paint.
« Reply #17 on: October 16, 2014, 11:46:44 AM »
The kit looks like it builds up really well . Did you have any trouble with the assembly ?
« Reply #18 on: October 16, 2014, 07:32:40 PM »
I like the idea of leaving just one sprue attachment on the struts. Must make handling while painting much easier!
« Reply #19 on: October 16, 2014, 09:34:41 PM »
Hello All and thank you again for the kind words, Martin and Bob.
Just to add a couple of things. Yes, Terri, it is a nice kit to build. I did have problems with some of the decals and the wing fixing but I suspect that in each case the problem was self-inflicted. I will definitely explain each in due course if that's ok.
Leaving one sprue attachment on the stut attachments did help, Rick. My reasoning was twofold: to make handling that bit easier; and also to keep track of which piece was which since the sprue included the part number. I don't always do this and sometimes wrap a small piece of masking tape with the part number written on it around the strut end. After painting I used a really sharp blade to remove the sprue and then touched it up.
« Reply #20 on: October 18, 2014, 02:00:23 AM »
Hello All
I was keen to get the fuselage sealed to start work on the lozenge fabric. The decals provided by Eduard haven't really stood the test of time and much better versions are more easily available now. Those to hand were from Wood & Wire and they were applied onto a high gloss white surface. I found them to be a bit fragile, but that almost certainly reflected my clumsiness. This work began with the fuselage upper decking and to avoid the edges flaking off I varnished before embarking on anything else. My local model shop in Limoges recommended Mr Hobby matt topcoat, and I was very pleased with the overall finish.
While on the decals, I first thought to use the black stripes provided by Eduard on the horizontal tail surfaces. This did not work too well because the decals are quite large and the ends kept flicking over on themselves and generally misbehaving. They were cleaned off and I did what I knew I should have done all along, measured and masked carefully and sprayed on my own stripes. Because I wanted to give a sense of different surfaces being finished in slightly different ways, I gave the tailplane a very light pass with a Tamiya semi-gloss spray.
Of the other things done here, I’ve put the undercarriage together, having checked all the angles and dry-fitted it against the fuselage and prepared the rigging. The machine guns and propeller have also been worked on, with strips of tape helping to guide the painting of the layers of wood on the latter. Getting a bit impatient, masking tape has also been used to give an early indication of the placement of the bands of colour on the wing undersurface.
 IMG_4448 by nigeljjackson, on Flickr
Sorry about the reflected glare from the fuselage in the next photo. The point I wanted to make was that it took me several goes with the lozenge decals before I was happy with them on the fuselage sides and I sealed them asap with a gloss varnish to prepare for the Eduard snake and rabbit decals. The matt varnish would come later. All the struts have been wholly removed from the sprues and bits of numbered masking tape used to keep a check on which is which. Such is my normal state of paranoia.
IMG_4486 by nigeljjackson, on Flickr
I like the stage when I can put fuselage sub-assemblies together and this takes things into the third photo.  As you’ll see the blue elements of the under wing paintwork has been started, but I’ll go through what I did on that in the next posting and we get ever near to the near catastrophe.
IMG_4498 by nigeljjackson, on Flickr
« Reply #21 on: October 18, 2014, 02:06:18 AM »
What a beautiful work Nigel.
« Reply #22 on: October 18, 2014, 08:47:20 AM »
Lovely job, Nigel.  Your painting is superb as shown by the
the finished pictures. Neat idea about leaving the sprue on
the struts, my friend. :D
« Reply #23 on: October 18, 2014, 01:23:04 PM »
Exceptional neat, clean work, Nigel!  She is stunning!  Your wing streaking is superb.
Offline BigBlue
« Reply #24 on: October 19, 2014, 01:36:45 PM »
What a great looking build!  She looks really sharp, Nigel.
Offline Dagmar Henderickx
  • Slow Builder
« Reply #25 on: October 19, 2014, 11:54:14 PM »
Hi Nigel,
Great build with lot of attention to the upper wing. Like it a lot!
Dagmar
« Reply #26 on: October 20, 2014, 12:19:50 AM »
    What Bud said and more Nigel. Lovely work!
« Reply #27 on: October 20, 2014, 04:17:37 AM »
Dear Martin, Ernie, Bud, Chris, Dagmar and Lance, thank you all so much for your kindness which provides such encouragement to continue. I hope to be able to post the next part tomorrow. It will focus on the wing.
Offline Epeeman
« Reply #28 on: October 20, 2014, 04:21:53 AM »
Hello, Nigel -
Looking good - I really like your chosen colour/marking scheme.  Look forward to seeing more progress.
« Reply #29 on: October 22, 2014, 12:47:13 AM »
Thank you Dave.
With the fuselage and tailplane largely complete, it was time to work on the wing and here I’ll focus on the techniques used. For the paint scheme’s rationale, I would refer readers to the notes which accompany the completed model in the Show us your Fokker E.V thread. It is certainly not my intention to try and teach anyone to suck eggs, rather just to show my approach.  Any faults or errors are, of course mine alone.
Having decided to try and replicate bands of coloured wood stain, streakily applied rather than an overall olive drab, my preferred approach was to use oil colours over a white base.  The oils used are from the Rembrandt extra fine range (I have a small box of ten colours), plus a tube of Sennelier extra fine sap green. The shades I was aiming to recreate - though I recognise with limited success, are those shown in the Ronny Barr illustrations and the comparative colour charts in Volume 2 of the excellent Achim Sven Engels’ (Fokker Team – Schorndorf) Fokker D.VIII in Detail.  Shown below are the scrap art paper/card mixing palettes. Clearly some of the colours played no part in the final outcomes and others were little more than a touch.
IMG_4856 by nigeljjackson, on Flickr
The point about using oils is that they are easy to mix and you can lift excess paint and reapply if necessary to achieve the effect you want. This is a benefit of what can be an incredibly slow drying time. However, the drying speed can be increased considerably by mixing in a very small amount of white spirit.  Care is needed because using too much will negate the very quality you are seeking to capitalise on - the time oils give you to work on the surface finish. In terms of the overall mix, I wanted something the consistency of something that would never have any hope running.
Having marked out the boundaries of the first underwing colour with masking tape, I applied some lines of colour with an old thickish brush. The strokes were parallel with the masking tape and each line was separated by a couple of clean brush widths. I started very close to but not quite against the masking tape (to avoid a big build up of paint at the junction), and worked from left to right. With this done, the   effect almost looked like blue and white zebra stripes!
The next stage was to use a trusty wide, stiff brush - one that I use for dry brushing, and dragging it straight along each line of colour. Some of what was picked up was wiped off the brush, but what remained was then dragged alongside and parallel to the first line of colour. The same thing was done again until the next thick line of colour was reached where the whole process was repeated. Regularly wiping the brush dry (keeping away from the white spirits) and revisiting each of the streaks made it possible to get the blend and effect I was after. A bonus was that the brushing left a nice thin covering of colour and an even surface.
Nervous as ever, I left things a day or two before attempting to apply the second colour. When I was absolutely sure that the first was dry, I deliberately applied some hopelessly untacky masking tape I had in the garage. The aim was to prevent accidental over brushing with the new colour without running the risk of strong adhesion removing any of the blue.  In the photo, I have yet to apply anything to delineate the ailerons, that will come later, or to ensure that the different bands of colour had no tiny white gaps between them.
IMG_4503 by nigeljjackson, on Flickr
Here we have an overview of things, and now we also have the undercarriage in place, which proved a nice secure fit.
IMG_4619 by nigeljjackson, on Flickr
With the wing under surface done, the process was repeated for the upper surface of the wing.
IMG_4737 by nigeljjackson, on Flickr
However, disaster is just around the corner..... Mysterious eh?
