Author Topic: WNW's 'Wooden Wonders' Albatros D.va  (Read 43838 times)
Re: WNW's 'Wooden Wonders' Albatros D.va
« Reply #15 on: August 23, 2013, 05:32:41 PM »
Thank you,
Bud - thanks for the decal info.. That's a shame - cos I only got them to use as a template - If they're the wrong size - kinda defeats their purpose!
I haven't got the Uschi ones yet so I can't compare, but I'm certainly impressed with the look of the HGW -  looks very scale to my eye - Vladimir's also putting in a sample of the Old Propeller Plywood in with my order to try. So it'll be interesting to have 3 options to look at.. Although my intention is to use the Uschi ones - I'll happily look at each on their own merit..
Spoilt for choice now..  :D
Online RAGIII
« Reply #16 on: August 23, 2013, 10:41:57 PM »
Your first Albie was beautiful and I am looking forward to seeing your next effort! I am also going to start my second Albatros soon so I am very interested in watching your build unfold!!
« Reply #17 on: August 24, 2013, 02:52:25 AM »
  Guy,
The first Albatros is beautiful my friend. I've no doubt the latest will be even better. Keep up the outstanding progress.
« Reply #18 on: September 04, 2013, 06:44:27 PM »
Morning all,
Finally made a start.. I always have a go at the wood areas first - for the drying time required, then I can put that to one side and have a bash at the engine.
I've masked the recesses here - just to stop them clogging up with paint as I seem to remember the fit tolerance here is fairly critical:
How do other people fill those pesky sink holes - there are loads on the internal structure of this kit! I normally superglue, then sand, but these are tricky to get at and I was worried about making more of a mess by sanding/scraping.. So I tried filling the holes with a few layers of Klear - it seems to have worked - they've almost disappeared (and certainly won't be visible once the fuse is closed up)
Pre shading for the oils:
Framework brush painted for variation:
Hopefully, I'll post the results of the oils a bit later on..
Thanks
Online RAGIII
« Reply #19 on: September 04, 2013, 09:41:40 PM »
Guy,
The shading on your base coat looks Terrific! I am looking forward to your work with the oils!
Offline martin
    • Martins Scale Models
« Reply #20 on: September 04, 2013, 11:07:36 PM »
Looking good Guy, nice start for sure. Regarding the ejection marks I normally use a standard modelling filler and an assortment of graded flexible sponge type sanders that ive bought for fitting in all sorts of nooks and crannies, even the most awkward and tightest of areas can normally be covered with a little patience.
Martin.
« Reply #21 on: September 04, 2013, 11:24:50 PM »
Guy,
Excellent progress my friend.I'm look forward to seeing the wood works progress.
As to you question about filling those pesky sink holes.I usually. Fill them with thin plastic
Disc then coat the super glue and sand them out. You can fill then with choice of liquid putty.
« Reply #22 on: September 05, 2013, 12:28:29 AM »
Guy,
    A pleasure to follow your progress thus far, looking like another beautiful  model from your production line, and I'm particularly interested in what you choose for the fuselage wood grain finish.
« Reply #23 on: September 05, 2013, 02:41:10 AM »
The Alby is looking good, Guy.  I'm looking forward to your interior oils stage.
Good work.
« Reply #24 on: September 05, 2013, 04:41:47 AM »
Hi,
Thanks for the advice guys.. I think I need to get some flexible/sponge sanders - now all I can see in the photos is those blooming sink holes!  :-\ although when closed up - I genuinely can't see them..
Here're the oils - bit darker than I intended but not too bad. The oval panel (backstop for the seat) I tried with the Uschi decals - wow! Boy, I can't wait to try this on the fuselage! It was a good lesson, because I need to do the base coat in a much lighter colour - but the potential is beyond my expectations.. They're almost see through, so the base colour is definitely key here..
Online RAGIII
« Reply #25 on: September 05, 2013, 07:28:19 AM »
I really like the effect the oils have created! Subtle is good, IMHO,
RGIII
« Reply #26 on: September 05, 2013, 09:23:10 AM »
The oval panel looks very cool... However you may wish to know that it was a piece of linen stretched over the frame on the actual aircraft.
« Reply #27 on: September 05, 2013, 09:59:35 AM »
Really nice effect you have created with your wood work, it's looking great so far.
« Reply #28 on: September 05, 2013, 02:53:30 PM »
No, I didn't want to know that!  :-[
I remember that from your build now you've said it.. Was it linen or lozenge? The instructions say light wood!
« Reply #29 on: September 05, 2013, 04:03:25 PM »
Ah,
Just re-read your build on the fabric Bo.. Do pay attention Guy  ::)
Ps still haven't decided if I'll re-do it though, not sure I'd trust myself to get that fabric effect on the plastic.
