Author Topic: D.F.W. C.V  (Read 2683 times)
Offline Jacek
D.F.W. C.V
« on: August 21, 2013, 11:29:03 PM »
Aircraft manufactured in 1917 ,  factories Aviatik.
Engine Mercedes  Bz.IV
Aviation Museum Krakow
Re: D.F.W. C.V
« Reply #1 on: August 21, 2013, 11:40:27 PM »
Very good pictures, Jacek. Thank you!
Re: D.F.W. C.V
« Reply #2 on: August 22, 2013, 02:20:02 AM »
Thanks Jacek!
(this is definitely a subject WNW should cover... DFW C.V was built and served in huge numbers...)
Re: D.F.W. C.V
« Reply #3 on: August 29, 2013, 02:33:18 AM »
Thank you Jacek. These are very interesting photos.
Please forgive the dumb question, but do you (or anybody else) know why the two front cylinders have bands of red around them?
Offline Jacek
Re: D.F.W. C.V
« Reply #4 on: August 29, 2013, 04:02:24 AM »
No, it's not a stupid question. I'm sorry but I do not know the answer to your question.
Maybe someone knows? !
Re: D.F.W. C.V
« Reply #5 on: August 29, 2013, 04:34:02 AM »
(it's all 6 cylinders with red band, , actually)
Denotes an overcompressed motor optimized for high altitude operation, and that cannot be operated at full throttle below something like 1500m.
Re: D.F.W. C.V
« Reply #6 on: August 29, 2013, 05:10:53 AM »
Many thanks Bob,
So is it just a visual reminder for the ground and aircrew (and a paint/tape job?) or it is something which contributes to the optimization?
Re: D.F.W. C.V
« Reply #7 on: August 29, 2013, 05:21:08 AM »
Yup, just paint, but they say if you paint your car red it goes faster, sooooo....  ;)
Re: D.F.W. C.V
« Reply #8 on: August 29, 2013, 07:18:28 AM »
I started to question whether my info on the red bands is actual fact or supposition, so I did some googling. This thread -- among several others on the 'drome on the subject --  goes to the point:
http://www.theaerodrome.com/forum/aircraft/46312-one-last-fokker-dvii-mercedes-diii-question-5.html
bottom line; the red band likely meant a field modification (presumably upgraded compression etc) or factory built over compressed, but it is not at all clear (at last to me) whether the practice and/or the meaning was universal.
It seems like a lot of modern restorations and display motors are sporting red bands because it looks cool (a TVAL Alby D.Va's Merc D.IIIa has them and as such is probably spurious); the same goes for the white serial numerals. Lesson: check your original sources before relying on museum restorations and replicas -- however well-intentioned they often are fraught with errors.
