Author Topic: Phonix D.I, J.4 of the K.u.K. Kriegsmarine  (Read 18383 times)
« on: August 21, 2013, 05:12:46 AM »
Yes, I know, the Halberstadts aren't finished yet.  I'm suffering from a mild case of lozenge burn-out, so to prevent total loss of mojo, I've decided to do something fairly simple on the side.  I love the red and white markings of the Kriegsmarine and have wanted to do a Phonix D.I for quite a while, so here she is.  I have both the Special Hobby and the Blue Max kits and after examining the contents of both boxes, settled on the Blue Max which has a better cockpit representation than the SH and a much more accurate Hiero engine.  This aircraft began it's life as A.100 and originally had it's fuselage done in factory applied brown mottle, according to photos in the DF.  However, it crashed at least once before being designated J.4 and, since the Blue Max instructions indicate she could have had a dark varnished or brown mottle fuselage, I may just go with dark stained wood and natural metal panels.  Not sure yet.
Here are the engine bits before assembly.
Somewhat crude, but better than the Special Hobby engine and it cleans up okay.
As you can see, I wrapped the induction manifold as in the original.
A quick test fit of the engine in the fuselage revealed that any additional detailing (carburetors, linkages and ignition harness) would be a waste of time and since this is supposed to be an easy, relaxing break, I decided to pass.
« Last Edit: August 30, 2013, 04:59:41 AM by coyotemagic »
Re: Phonix D.I, J.4 of the K.u.K. Kriegsmarine
« Reply #1 on: August 21, 2013, 05:23:35 AM »
As with most limited run kits, there are no locating pins on the fuselage halves, so I decided to add some just to make fuselage closure just a bit easier.
Got the prop finished, as well.
I'm working at a feverish pace on this one, so I should have more photos up soon.
« Last Edit: August 30, 2013, 05:00:23 AM by coyotemagic »
« Reply #2 on: August 21, 2013, 05:30:30 AM »
Very nice, the prop is gorgeous!
« Reply #3 on: August 21, 2013, 05:47:03 AM »
Coming along nicely Bud,
Although seeing those kits does make you realise how far the hobby's come along with the advent of Wingnuts.. But it's nice to make a model once in a while with a low parts count!
Looking forward to updates..
« Reply #4 on: August 21, 2013, 07:50:36 AM »
With your talent, Bud, this is sure to turn out a beauty.  I really like
the prop...very pleasing to the eye.  Looking forward to more on this
build.
Offline martin
    • Martins Scale Models
« Reply #5 on: August 21, 2013, 08:15:24 AM »
Now this i am liking, fantastic start and that prop is simply glorious ;-)
Martin.
« Reply #6 on: August 21, 2013, 09:09:56 AM »
Bud,
terrific start on what I am sure will be your usual Stunning work! As others have said the prop is gorgeous!
« Reply #7 on: August 21, 2013, 10:13:35 AM »
Thanks so much, guys!  I really appreciate the encouragement, not that I need encouragement with this one.  It's such a fun and easy build, it's just taken on a life of it's own.  I only break to post while something's drying and things dry fast in this heat.
For comparison purposes, here's a shot of the Special Hobby engine.
I think I made the right choice.
I usually draw my prop laminations with pencils, but I masked and painted this one.
Thanks to the heat, I've gotten a lot of cockpit work done.  My water based oils are drying in a matter of hours, instead of days.  I fabricated the pilot's seat cushion from Citidel Green Stuff.
Then painted it Tamiya light sand, followed by a coat of Tamiya red-brown.  I then lightly sanded it until enough tan came through to give it a worn look.  I followed that with a wash of brown and black water colors.
Added triggers and cables to the control column while waiting for the cockpit sides to dry.
My bride still isn't back from work, so I'll forge on and hopefully have more photos tomorrow.
« Last Edit: August 30, 2013, 05:01:19 AM by coyotemagic »
« Reply #8 on: August 21, 2013, 10:30:10 AM »
Bud,
You weren't kidding about that Light Speed Stuff! Your Stick and Seat are AWESOME!
Offline martin
« Reply #9 on: August 21, 2013, 05:50:44 PM »
Great progress, all of which looks outstanding, loving that seat cushion, nice work.
Martin.
« Reply #10 on: August 21, 2013, 06:15:47 PM »
Lovely start, Bud! Phonix with red-white-red markings will certainly be a striking model. I presume it is 48th scale, isn't it? Anyway - very fine detailing. Looking forward to see more.
Offline Jacek
« Reply #11 on: August 21, 2013, 06:50:58 PM »
A good start !!!
I look forward to a continuation  :)
Jacek
« Reply #12 on: August 21, 2013, 09:54:51 PM »
A great start Bud, the seat, propeller and control column look excellent, I really like the seat cushion. Looking forward to seeing more updates.
Offline Rob Hart
« Reply #13 on: August 21, 2013, 10:40:17 PM »
Nice work. Great choice of subject too. All of the individual components you have completed look super. Thanks for the comparison photos of the engines. We need a good aftermarket Hiero for sure.
« Reply #14 on: August 21, 2013, 11:07:50 PM »
Bud that is such good work.  And so fast!  Amazing.  You did a super job on the
seat.  I was wondering...the water-based oils...are they as good as the oily ones?
Is there a difference in the drying time?  That's the pain for me, waiting for the oils
to dry.
