Author Topic: suitable first kit  (Read 3037 times)
Offline simon 64
suitable first kit
« on: July 30, 2013, 09:22:42 PM »
here we go, I'm intrested in what forum members think would make the ideal first kit in any scale for newbies to try, allowing for rigging and build complexity of the kit?
Offline Adam
Re: suitable first kit
« Reply #1 on: July 30, 2013, 09:55:17 PM »
Also Roden  Dr.1 1/32
Adam.
Offline LindsayT
« Reply #2 on: July 30, 2013, 11:26:52 PM »
Academy 1:32 Nieuport 17? Fairly basic on the detail, but low part count and goes together well.
Lindsay
« Reply #3 on: July 30, 2013, 11:58:26 PM »
Good question Simon!
When first dipping my toes into the pool of biplanes and rigging my 1/48 scale choice was the delightful Eduard Nieuport Ni 17. It can still be picked up reasonably cheaply on Ebay (I went for the profipack version). Construction is quite straightforward and there is just enough rigging to be done to help develop the skills without feeling that you are completely entwined in the stuff.
Good luck!
« Reply #4 on: July 31, 2013, 12:02:56 AM »
My suggestion is always for the WnW Sopwith Pup for a first build. Relatively easy to build which makes it a confidence builder.
« Reply #5 on: July 31, 2013, 12:52:32 AM »
  Simon,
I would suggest the Academy Nieuport 17 . Great first 1/32 kit to start with. It's a bit of a blank slate as far as detail goes but can be build into a real stunner straight from the box. Or you can add all the detail your skill will allow,your choice. If you're looking for a cheap entry into this scale this scale this is the kit for you.
If your looking for a very well detailed kit straight out of the box I'd suggest the WNW Sopwith Pup as Chris did. The build isn't as simple as say the Academy Nieuport but still easy enough to build for even the newest of newbie . The rigging isn't too difficult either. Please do look around at the outstanding Pup build threads here and around the web. There's some excellent threads to study before you get started on this excellent kit.
In 1/48 scale I'd go with Eduard's beautiful Nieuport 11 or 17. Both are fairly simple builds and build up into real stunners. If you prefer a German subject the Eduard's Pfalz D. III/IIIa or the any member of the Albatros family would a excellent candidate for your first 1/48 scale biplane. I would also suggest the same kits in 1/72 scale if that's the same you wish to build in.
The best of luck with your first biplane my friend. As always if you run into any difficulties during the build simply post your questions or problems here. You'll get Excellent help and advice from the multitude of very talented modeler here.
Online lcarroll
« Reply #6 on: July 31, 2013, 05:19:32 AM »
Simon,
   If you are going to start your adventure in 1:32 Scale then I second the recommendations for the Roden Fokker DRI, no end of potential colour schemes and minimal rigging. Should you decide to jump right into the rigging requirement then, as Chris and Greg pointed out, the Wingnut Wings Sopwith Pup is a fairly simple Build and the Kit is spectacular in engineering and ease of assembly.
    To help in your choice take a good look at some of the Build Logs here if you have'nt already, that will provide a lot of considerations in the scale and aircraft type you want to model. Last, as Greg has pointed out, all the help and encouragement you'll ever need is here for the asking.
   Good luck with your first, I look forward to following your progress and, above all else, ENJOY!
Lance :)
Offline Zabu
« Reply #7 on: July 31, 2013, 07:23:14 AM »
Hi  Simon... i'm a braille modeler but i woud recomend an 1/48 or 1/32 model. Maybe an 1/32 would be better.
I must agree with the options that are recommended. Fokker D.VII or Dr.1 are something great to start with , 'cause they don't have too much rigging, but hey, don't let those wires to scare you!
There are great modelers here always willing to help.
Good luck in your choise.
Offline simon 64
« Reply #8 on: July 31, 2013, 11:27:10 PM »
A friend of mine has donated an Eduard 1/48th Albatross to practise on, so we will see how it progresses and i'll keep you informed if you are intrested ( i'll try to keep the swearing down as much as I can to protect delicate ears!)
Offline Zabu
« Reply #9 on: July 31, 2013, 11:53:46 PM »
An Albatros isn't to much complicated, and IMHO the right school to ww1 aircraft. A little bit of rigging... but not to much.
Please post your build... we have many people willing to help in the way they can.
Cheers.
Offline simon 64
« Reply #10 on: August 01, 2013, 04:12:20 AM »
WellI've started! Built up and painted the engine, made my firat atempt at wood effect (waiting to see how that turns out finger's crossed )  and generally looked the kit over. After the carpet monster ate the same piece 3 times I think that the lack of swearing is a good sign ;D
Offline simon 64
« Reply #11 on: August 01, 2013, 04:13:47 AM »
please excuse the terrible typing I think the carpet monster has struck back!
