Author Topic: Latest acquisition in your collection  (Read 563018 times)
« Reply #645 on: August 13, 2014, 03:11:23 AM »
So that is what heaven looks like! 8) :o ;D
« Reply #646 on: August 13, 2014, 04:58:45 AM »
I hope you believe in reincarnation!  ;D
A stash worthy of the Gods!
vB
« Reply #647 on: August 13, 2014, 11:34:01 AM »
ALL I HAVE TO SAY IS WOW! Your disposable income is way above my level ! Congrats on your latest addition!
« Reply #648 on: August 14, 2014, 09:53:12 AM »
My Anniversary Presents have arrived: First from WNW
WNW&pheon 004_crop by richardgeisleriii, on Flickr
WNW&pheon 013 by richardgeisleriii, on Flickr
WNW&pheon 001_crop by richardgeisleriii, on Flickr
and... from Pheon:
WNW&pheon 065 by richardgeisleriii, on Flickr
« Reply #649 on: August 15, 2014, 06:28:39 AM »
Three Wingnut Kit's?...................You are in the race, Rick  ;D
Servus
Bertl
SWMBO doesn't know how MUCH I SPENT yet  :-[ Still a long way away from your stash!
Offline Snowy
« Reply #650 on: August 15, 2014, 07:05:31 AM »
Quote
...SWMBO doesn't know how MUCH I SPENT yet  :-[ Still a long way away from your stash!
They know, it's just they don't want you to question how much they spend at the hairdresser, on shoes or on handbags!
Offline WillScarlet
« Reply #651 on: August 15, 2014, 01:47:22 PM »
Adam, I would be interested in a report on the prop spraying template. I have one of his "wood grain" templates, and having used it only once, I find that the resulting "pattern" seems rather large even in 32nd scale.
                                             Will
Offline jknaus
« Reply #652 on: August 16, 2014, 03:50:46 AM »
Maybe I can offer some help also Will. I used the prop template on my Fokker DVII here http://forum.ww1aircraftmodels.com/index.php?topic=3477.msg63216#msg63216
This is the first time and also the first time I didnt use oil paints, just acrylics. I think I need more practice, but my initial thoughts are that it looks okay. I found it was kind of a pain to try and set up and hold, but as I use it more maybe I'll figure that out. You have to thin the paints and make sure you spray straight on. Then you have to remove the template and set up again for the other side. Hope that helps some.
James
« Reply #653 on: August 18, 2014, 07:11:01 AM »
Rick, Congrats on the Anniversary and the "gifts".
Bertl, If I were only your age my WNW stash might well approach yours.
« Reply #654 on: August 18, 2014, 07:22:08 AM »
I thought I'd get this before it is sold out!   ;)
« Reply #655 on: August 18, 2014, 08:02:20 AM »
 ......and you won't regret it von B, it's an absolutely exceptional Kit! (and I suspect high on the list of next out of stock :(
« Reply #656 on: August 18, 2014, 08:09:25 AM »
You have just purchased the best kit (IMHO) Wingnuts have produced Bob, like Lance said, you will not regret owning and building this brilliant kit.
« Reply #657 on: August 18, 2014, 03:29:40 PM »
Thanks, guys!
I hope I can do the old girl justice  :D
Biff Von Buckle
Offline eclarson
« Reply #658 on: August 21, 2014, 01:05:00 AM »
Great minds think alike, Bob!  I recently bought a WNW Biff for the same reason.  That and Des' glowing recommendation.   :)
Eric
« Reply #659 on: August 21, 2014, 09:52:05 AM »
Well the last phase of my Anniversary present arrived today. My order from Aviattic:
The Upper and Lower 5 color Lozenge in 1/24th scale, as well as a 1/24th interior sheet. In addition I received the Free sheet for the GB in the form of a cookie cutter 4 color Lozenge with blue tapes in 1/32nd. Also a couple of small samples of the PC 10 and CDL.THANKS RICHARD!
« Last Edit: August 21, 2014, 09:56:47 AM by RAGIII »
