Author Topic: Latest acquisition in your collection  (Read 562935 times)
« Reply #2295 on: August 06, 2022, 01:15:04 AM »
....well it's important to do as you're asked. Glad you got some good ones. Hopefully no Covid either as I have heard there was a major outbreak at the show.
Offline Naimbs
« Reply #2296 on: July 09, 2023, 10:47:30 AM »
Offline AngryJazz
    • @AngryJazz_Models
« Reply #2297 on: April 17, 2024, 09:33:40 PM »
Managed to get hold of one on top of my wishlist  ;D
Was quite a bit more expensive than I would have liked, but since my spare Dolphin sold for a good price - it pretty much evened out  :o
//Ben - @AngryJazz_Models
« Reply #2298 on: April 19, 2024, 05:53:29 AM »
One of the five or so best kits ever released!
If I were a pharao, one of these would go with me into my pyramid one day.
Offline Umlaufmotor
« Reply #2299 on: April 19, 2024, 11:54:48 PM »
A wonderful kit.
The box is filled to the brim with the finest plastic parts.
I also have this kit at home - but haven't built it yet.
Every now and then I open the box, marvel at the plastic parts and drool as I close the box again.
There are some of these wingnut kits that are simply outstanding.
Dolphin, Roland D.VIa/b, Albatros B.II, Stahltaube, AMC DH.9 and a few others.
The Salmson's are also beautiful kits.
Have fun with the FE and look forward to a build report.
Servus
Bertl
Offline AngryJazz
    • @AngryJazz_Models
« Reply #2300 on: April 22, 2024, 03:57:48 PM »
Sounds like I made the right choice when i picked up this kit  ;D
However will properbly build the DH.2 before this one. Just to get used to the rigging.
And the kit almost complete my collection. Mostly just missing that Pfalz D.III...
Offline Umlaufmotor
« Reply #2301 on: February 19, 2026, 03:40:52 AM »
Hi,
Today I received a package from "Flugzeugwerke", from Barneveld, Wisconsin.
It wasn't a model, but rather some super-fine accessories in the form of a 3D-printed radiator for the Pfalz D.III from Roden or the D.IIIa from Wingnut Wings. Both aircraft types were equipped with the same Teves and Braun radiator.
The parts for the radiator are packed separately in a small but sturdy cardboard box so that they cannot damage each other.
The box also contains easy-to-understand assembly instructions.
I see that the complete mounting bracket for the radiator cover is cleverly designed ..... it could almost be mounted so that it is movable  8)
Even the small water drain cock is included with the component.
A nice little side effect - even the cardboard box has the Pfalz logo on it and is "painted" in the green-gray primer used on the metal parts at the time.
But pictures say more than a thousand words.
Servus
Bertl
« Reply #2302 on: February 19, 2026, 07:38:55 PM »
This looks amazing. I have mine on order for my Roden DIII, but I have the wing to Bo in the US so that I can exchange for one in which he has milled the opening - there's no way I could do that!
Offline Umlaufmotor
« Reply #2303 on: February 22, 2026, 05:44:18 AM »
Hi Nigel,
I suspect Bo mills the cutout with a small CNC machine.
This can be a tricky business if you want to do the cutout for the radiator yourself?but it is doable.
First, drill out the corners and then drill more holes close together along the contour of the radiator.
Finally, use a resin saw and a good, fine file to work out the corners and straight edges.
At least, that's how I do it with the WingnutWings Albatros radiators when I replace them with Bo's fine 3D parts.
Either way, you have to be careful when you get the wing back, as its structure is significantly weaker than before ? the stiffening, solid plastic piece of the cast radiator is now missing.
Careful handling is now required, especially with the often strongly curved Roden top-wings, xplicitly if you want or need to straighten the wing.
Also, make sure that the baldachinstruts and the outer V-struts are not at different heights when reassembling so that a straight wing line is created and the wing cannot be bent again ? because if it is, it will happen in the area of the newly inserted radiator.
But I think you will know all this yourself.
Servus
Bertl
Offline Umlaufmotor
« Reply #2304 on: February 23, 2026, 10:33:58 PM »
A really pretty little Italian Nieuport XI was delivered to me just a few minutes ago:
 ...... and the perfect book to go with it - really thick and heavy - has been sitting on my shelf since January:
Many thanks to Edgar from Copper State Models at this point - really well done.
Servus
Bertl
« Reply #2305 on: February 24, 2026, 03:10:55 AM »
Damn, you beat me! Mine clearly has further to go...... ;)
What's the Italian Aces book like? Does it have good references for the Nie 11?
