Author Topic: lozenge decals... edge work  (Read 2036 times)
mike in calif
« on: July 14, 2013, 10:04:31 AM »
The big question for me is: what is/are some ways to handle the leading and trailing edges of wings with lozenge decals? The L/E seems pretty straightforward- adjust decal to achieve a straight line at midpoint of radius. How about the trailing edge?
Offline Zabu
Re: lozenge decals... edge work
« Reply #1 on: July 14, 2013, 12:39:07 PM »
I don't know about you people, but i use a nice soft sandpaper.
Offline Ian from Doncaster
« Reply #2 on: July 14, 2013, 07:06:36 PM »
For scalloped trailing edges I first trim with a sharp blade perpendicular to the wing surface, then use a fine sanding stick.
I find wrapping rib tapes around the wing edges (to cover top/bottom lozenge joins) quite tricky, especially around the ends!
