Author Topic: Hansa Brandenburg D.I Eduard 1/48  (Read 8673 times)
Offline xmald
« on: June 30, 2013, 09:14:21 PM »
In order to get to some mental balance after rigging the Taube I`ve decided to build something without rigging...
It`s an oldie goldie Eduard`s kit - I guess their fourth model from 1994. A lot of PE and very hard plastic. I`m planning to build machine nr. 28.11 flown by an Austrian (Hungarian actually) ace Karl Kaszala.
Inbox photo (source - The internet)
Best regards
Filip
Offline LindsayT
Re: Hansa Brandenburg D.I Eduard 1/48
« Reply #1 on: June 30, 2013, 10:26:28 PM »
I've never seen this one before. It'll be fun to watch something lesser known get built. Good luck with the build!
Lindsay
Offline Rob Hart
« Reply #2 on: June 30, 2013, 10:41:39 PM »
I'll be watching with much interest. I have a few of those kits and have recently entertained thoughts of converting one to a KDW.
Offline Jacek
« Reply #3 on: July 01, 2013, 01:29:35 AM »
I will be attentively watching your work, but it will be a pleasure :)
« Reply #4 on: July 01, 2013, 09:00:15 PM »
My goodness! No stings attached.  Filip you won't
know what to do with yourself! ;) ;D  I'm looking
forward to seeing this build.  Good choice.
Ernie
Offline Zabu
« Reply #5 on: July 01, 2013, 11:46:26 PM »
I'll sure be looking this one, having one 1/72 to build too.
Great choice!
Offline xmald
« Reply #6 on: July 10, 2013, 09:58:05 PM »
The cockpit is basically finished. I` ve added some details but what comes in box is decent anyway.
The engine is from LLoyd CV by SH - a horribly crude looking piece of resin.
The prop is homemade.
Best regards
Filip
Offline Jacek
« Reply #7 on: July 11, 2013, 12:24:42 AM »
Propeller and cabin elegant. Motor weak, but it's an old set :)
Offline Zabu
« Reply #8 on: July 11, 2013, 03:00:28 AM »
It's going great.
The interior looks fine and the prop it's nicely done.
Looking forward to your next update.
Offline xmald
« Reply #9 on: July 11, 2013, 03:39:44 AM »
Cheers!
Jacek I agree the engine is nightmarish and I would never put it into model if it was more visible. but the only part that you really see is the top. For the purpose of this model it`ll do!
Best regards
Filip
« Reply #10 on: July 11, 2013, 06:49:29 AM »
Outstanding work so far, Filip.  That cockpit is truly lovely.
Offline KrzysiekK
« Reply #11 on: July 12, 2013, 07:49:20 PM »
Props made by you are very promissing. :) How long does it take to prepare such one?
I have never done it before
regards
K
Offline Adam
« Reply #12 on: July 13, 2013, 01:40:13 AM »
Filip.
Nice to see yours next WWI model.
Adam.
Offline xmald
« Reply #13 on: July 13, 2013, 07:58:04 PM »
The fusselage is painted, it still needs some major touch-ups. This is the first time I`ve tried to emulate the veneer using oil paints and I must say I`m pretty satisfied with the result. The whole thing needs a little bit of sanding. I added the nails fixing the sheets of veneer to the construction using a sharp pencil. I have also attempted to emulate the swirls on the engine covers with a rather mediocre result...
It takes more than 12 hours for the wood glue (Wikol - you know it for sure;)) to cure, and then maybe 2 hours of carving and sanding, so it` s pretty short.
You should try it Krzysiek it` s a lot of fun. You can buy a nice set of prop bosses by Part and off you go!
Best regards
Filip
Offline Jacek
« Reply #14 on: July 13, 2013, 10:53:28 PM »
Sheathing looks great. Stair make a dark color to make it look that can be inserted into foot.
