Author Topic: Gunbuses after 30+ years  (Read 4291 times)
« on: May 28, 2013, 08:20:21 AM »
Evening All,
Like many others (it seems) I have returned to modelling after 30+ years break. I restarted about 15 months ago and while rooting around in the roof last summer found two unfinished models: one was a Vickers FB5 Gunbus and the other was a derivative the FB 9 or Streamline Gunbus. These were conversions from the Airfix DH 4 (wings, wheels, struts, gun,) with engines and props from the Airfix Avro 504, and moulded fuselages. I found them in an advanced state of construction, ie I had to put on the booms and tailplanes, top wings and undercarriage and paint and rig them. Having completely forgotten that I had ever started them I decided that perhaps it would be a good idea to finish them. Having looked at the quality of work on this site I am not sure whether these are up to the mark, but as I have had positive responses elsewhere I am taking the plunge here. The FB 5 build recently appeared on Modelling Madness if anyone is really interested in modelling masochism, or just wants an different challenge from super-detailing. These models are in God's Own Scale and are rigged with copper wire - just a foible of mine - I prefer it to other media especially on models as delicate as these where thread would probably put too much strain on them.
This is how I found the FB 5 except that I had made the skids just before I took the image:
These are photos of the completed model:
These are images of the much less known Streamline Gunbus: I have not seen images of any models in any scale of this particular aircraft but perhaps I have not looked hard enough. There is no serial because the photo on which based my model had the rudder obscured. It was a two-seat trainer - hence the two control horns on the nose. This model was in a similar state to the FB 5 when found except that I had attached the lower wings to the fuselage and fixed the booms to the wings.
The FB 5 represents a machine from 5 Sqdn at Abele in the spring of 1915: I am not sure of the camouflage colour as it could also have been earth or PC 8: the pattern is representative because this too was unclear in the photo that I used. The underwing roundels should probably be inboard of the alerons but I had painted them before I realised my error and I was not going to try to correct them. Apart from the serial on the FB 5 everything was hand painted. There are some minor errors on the FB 9 too but this is the best that I can do and I am pleased with the results - in fact I am now going to have a go at some more RFC/RNAS pushers.
Thanks for looking.
« Last Edit: July 06, 2017, 04:16:11 AM by lone modeller »
Re: Gunbuses after 30+ years
« Reply #1 on: May 28, 2013, 08:42:44 AM »
They are two very impressive looking models, and being in a small scale makes them even more impressive. The colours you used appear to be correct and your rigging skills are superb. Congratulations on finishing these two "old" models and I look forward to your next build.
This forum caters for all levels of modelers, there is no discrimination at all so please feel free to post whenever you like.
« Reply #2 on: May 28, 2013, 10:49:18 AM »
Those are great looking models all the more impressive in the small "I cant see it to do it" scale.
« Reply #3 on: May 28, 2013, 12:39:00 PM »
Now, that is NEAT! Very nice and definitely a real find!
« Reply #4 on: May 28, 2013, 01:17:04 PM »
Very nice pair of FB's - finishing them after so long had to feel good! I have the Pegasus FB5 in my stash and still haven't had the b***s to start it and I've been back into modelling (after 30 years) for 3 years....Great job!
« Reply #5 on: May 28, 2013, 09:48:25 PM »
   Two outstanding models LM. Very impressive work my friend . What other gems in the making did your attic hold?
Offline Epeeman
« Reply #6 on: May 29, 2013, 03:31:32 AM »
Welcome aboard, LM -
Two great looking models there which are rigged up really well.
« Reply #7 on: May 29, 2013, 08:31:53 AM »
Hello Lone Modeler:
Well........after 30 years,  you must feel a sense of accomplishment!  I think they turned out great and are two very interesting models, no doubt; especially significant in 1/72nd.
Welcome aboard, and looking forward to more of your pusher models.
« Reply #8 on: June 01, 2013, 04:45:55 AM »
Thanks for the compliments everyone.
I am in the process of making an FE 8 from the Airfix Avro 504 at the moment and will post pictures when it is complete. I have another recent build, and some conversions (from over 30 years ago) in the roof in boxes (to keep the dust off and protect them), - will try to get those down and photograph them too.
All of them are inn God's Own Scale of course.
« Reply #9 on: June 01, 2013, 06:31:12 AM »
I can't be;ieve you said you were not sure they were good enough comparedd to the work on this site! They are outstanding Scratch/kitbashed builds that wouldn't be recognized as such, a true mark of outstanding work! By the way, just for the record, I believe God has switched scales to 1/32nd....... ::)
« Reply #10 on: June 01, 2013, 01:15:45 PM »
Brilliant pair of Gunbuses, Lone Modeller.  A tribute to your modeling skills that you were able to pick up where you left off 30 years ago and create such gems.
« Reply #11 on: June 02, 2013, 07:52:33 AM »
Thank you all again for the very kind words and complimentary remarks which I found very encouraging. I think that I suffer from a common problem which is that I know where the errors are on my models and feel that they should not really be there. But then I suspect that most of us probably feel the same - no model is ever perfect, although some of those that I see on this site come pretty close. Will return with more pictures later.
Offline xmald
« Reply #12 on: June 03, 2013, 06:34:19 AM »
Fabulous! I haven` t seen many Gunbus` models yours are trully great!
Best regards
Filip
