Author Topic: 1/32 albatros D:III roden  (Read 83145 times)
Re: 1/32 albatros D:III roden
« Reply #255 on: August 10, 2013, 09:11:07 PM »
Your work on this one is absolutely Incredible! LOVELY ALBATROS!
Offline mc65
« Reply #256 on: August 12, 2013, 07:16:41 AM »
hi all!
thank you very much... altough the fuselage is on the dark side of the wood, I am also quite satisfied, especially thinking at the kit base.
lance, for the undercarriage I used the flat rigging thread bought on the wnw site. actually isn't correct, should be something round and a lttle bigger, but to me it's ok like that.
today, back from work, I managed to buy a wooden frame and some spares to assemble a base. I home to have some time in the next days to do it.
cheers, p. ;)
« Reply #257 on: August 13, 2013, 01:46:26 AM »
   Paolo,
My friend you have more than earned all the praise indeed. I noticed back on post #241 the figures you're working on behind the Albatros. Although I suspect they have nothing to do with WWI in the least but still very interesting works in progress.
« Reply #258 on: August 15, 2013, 04:04:43 AM »
Hello Paolo:
I think you have a real stunner there.  I followed your build thread and you overcame many obstacles without giving it it's first and last flight.  For that you are  to be commended.  You took an adequate kit and made it into a masterpiece.  I am duly impressed with the work and workmanship.  Now, if Squadron weren't sold out of it, I would buy one.
Offline mc65
« Reply #259 on: August 15, 2013, 10:07:08 AM »
pant, puff, grunt! heavy days, here... :P
I didn't manage to work on the wooden base, just shoot this:
5953
gregory, you're right (and sharp eyed)... nothing to do with WWI... something totally different! if I do something of that strange project, I'll post some pics.
thank you again for appreciation, I hope to achieve a good result with the base, soon!
« Reply #260 on: August 15, 2013, 01:49:34 PM »
Look on the bright side, Paolo...after all you've done with
the Alby build, the base will be a piece of cake!
« Reply #261 on: August 15, 2013, 10:34:23 PM »
Paolo, it's more than perfect, it looks more real than the real one...
Fantastico Paolo!!!!
AnDò
 8)
Offline Mac
« Reply #262 on: August 16, 2013, 12:17:52 AM »
Beautiful work , I have learned so much by following this thread! well done! :D
Regards Pam
Offline mc65
« Reply #263 on: August 23, 2013, 03:45:17 AM »
hi all, thank you so much for the appreciation...
the last days are really busy at work, and I managed to work on the base just here and there, mainly because the layers of paint on the wood request several days to cure.
but today was the day... here some pics of the wsip (work still in progress ;))... I post all the passages not because are so interesting, if not because it's a really low cost work to achieve a decent (on my opinion) base for the models. hope may be interesting!
carved the perimeter, leaving a 1cm rim.
5996
put aside the glass, glued and nailed the back of it inside the frame. here at the end of three layers of walnut paint on it.
also, I drilled two holes corresponding to the wheels. at the end, I'll put pins within.
6172
with some tape to protect the wood, I put inside a layer of clay. since I want just a bit of plain grass airfield, I don't do any particular shape to it, just plain, with few smooth "waves". (sorry for the backcloth, it was too hot to work inside!)
after that, I scribed wheels traces.
6173
then, after a wash of water mixed with white glue, I scattered some earth from the backyard, mixed wit little stones and pigments.
6174
gone the tape, I retouched the edges and smoothed the wheels traces..
6176
and push the D.III on her assigned spot, so she'll meet the pin holes, and sit leveled.
6177
et volià.
6178
now it's just matter of waiting the clay drying's time, but anyway tomorrow I leave for five days out... ???
back home I'll adjust the earth color and glue on some grass and flowers.
by the way, someone has at hand the month in wich voss changed jasta? I should do a proper vegetation, I guess...
bye bye, p. ;)
« Reply #264 on: August 23, 2013, 05:46:19 AM »
Very nice, Paolo. The whole thing is fantastic, congrats.
Voss was officially kicked out of Jasta B on May 20, 1917, I think he went directly to Jasta 5.
« Reply #265 on: August 23, 2013, 09:21:13 AM »
Great job on the display base, Paolo.  Fitting spot for your beautiful Albatros to
rest.  A hearty "well done!" for both.  Now after catching your breath, I wonder what
gems you have up your sleeve? ;)  Thanks again for a great build!
« Reply #266 on: August 24, 2013, 03:04:57 AM »
  Paolo,
Absolutely beautiful work my friend. Congratulations and Well Done.
Offline Zabu
« Reply #267 on: August 25, 2013, 08:02:52 AM »
Nicely done Paolo.
Simple... but with no need to anything esse imo.
Your Alb it's a beauty.
Offline AndrewS
« Reply #268 on: August 27, 2013, 11:56:48 PM »
Wow, amazing!
I've missed this thread, but I've just read all the pages  ;D
Great build, great painting and great weathering.
Bravissimo, ottimo lavoro!
Andrea
Offline mc65
« Reply #269 on: August 28, 2013, 09:02:31 AM »
yeeeeeess! back home, finally... it was a long long journey. :o
thank you all very much, in particular to bo. so, I'll try to render a not-so-plain airfield in the middle of springtime.... in detail, I want to try to do some dried puddles, and add several shades of yellow-green grass, and just few flowers.
ready? set, go!
adjusted the earth color with some brown, sand, earth.
6316
spread on different shades of synthetic grass with the mc-elettrostatic applicator.
6317
gone the tape, I retouched the edges, and add grass tufts in different shades and length.
6318
then I sprayed away the excess from the dried puddles. I also managed to remain without white flowers, the right ones here, on my opinion.
obviously the white underneath the grass is white glue. when dry it will disappear. I trust. ;D
6319
well, for tonight it's enough. tomorrow I'll add grass, adjust again the greens, and so on.
6323
6325
so, if there are not macro interventions on the grass (have your say, don't be shy!) I'll start to assemble & paint the young verner...
6328
bye bye, p. ;)
