Author Topic: LVA Fokker D.XVI 1:72 MW Models  (Read 3246 times)
Offline IvotB
« on: May 03, 2013, 06:35:52 AM »
Invited by Gregory I will here show progress of a Fokker D.XVI.
It is just a short run resin kit in 1:72. It is basic but correct and shows the development of Fokker fighters after ww1. This plane was launched in 1929, was equipped with a 460hp AS Jaguar VIIa and had a top speed of 320km/h. In comparison a D.VII with BMW IIIa engine had 185hp and a max speed of 200km/h.
These are the main parts of the kit:
Struts have to be made from the styrene strips just like the landing gear. Just the wheels are supplied as resin castings. But the major shapes of the wings, fuselage, engine cowling, rudder and elevator seem to be formed correctly, so it should build into a nice model.
regards,
Ivo
Re: LVA Fokker D.XVI 1:72 MW Models
« Reply #1 on: May 03, 2013, 12:16:03 PM »
  Ivo,
I'm looking forward to seeing this project unfold my friend.
« Reply #2 on: May 03, 2013, 12:24:09 PM »
  Ivo,
Ditto
Offline IvotB
« Reply #3 on: May 14, 2013, 11:46:36 PM »
All parts have now been cleaned and cut from the resin casting pieces. There are just a few parts and now it is time to consider what I am going to do with them (apart from assembly into a model)
The exhaust ring didn't come out in one part:
Above you see the 2 exhaust pipes which connect to the ring and tranport all unwanted gassed towards the back of the cockpit and underneath you see on the left the exhaust ring where there should be 14 tubes from each cylinder, but not all survived. I am going to remove them all and replace those with brass wire. I will drill small holes in the ring. Then one large casting for the engine and the engine cowl:
This is how it is going to be.
The fuselage is one large casting and in the instruction paper there is already a warning that the mould for the fuselage has a problem on top as it seems in the original the fuselage halves didn't fit on top. Some sanding will correct this and rescribing the panels should then be done:
The inside of the cockpit has some imitation frame and a suggestion for MG's fitted inside:
I have no clue about the colors, but I will use the colors for the D.VII as a guidance. There is no instrument panel and I can't find anything anywhere about a D.XVI instrument panel. The total production at Fokker of this type is less than 30.
The lower wing has a nice tight fit in the fuselage and there is a small chair supplied (chair is perhaps too much, it just looks like two square pieces of styrene)
Next step will be cleaning the parts and painting the interior and the engine. Then all struts have to be made to the specifications.
regards,
Ivo
« Reply #4 on: May 14, 2013, 11:58:37 PM »
  Ivo,
The D.XVI is looking just awesome my friend. Beautiful resin casting is evident with this gem of a kit. It all appears outstanding to me with the exception of the engine. Not that it looks bad just a tad soft on detail. Looking forward to the next D.XVI installment. The thinness of the fuselage walls is very impressive.
Offline IvotB
« Reply #5 on: May 15, 2013, 05:34:47 AM »
Gregory,
You should see the resin casting of another Fokker biplane kit: Czech Master Resin Fokker D.XVII. That is really a piece of art. Even less have been produced by Fokker though. In my information just 10 D.XVII left the Fokker works.
But first the D.XVI
regards,
Ivo
« Reply #6 on: May 15, 2013, 06:10:32 AM »
  Ivo,
Outstanding my friend,looking forward to the D.XVII at a later date. I'm familiar with Czech Master Resin kits and you're right they are pieces of art.
