Author Topic: W. M. Alexander's Sopwith Triplane 'Black Prince'  (Read 34511 times)
Re: W. M. Alexander's Sopwith Triplane 'Black Prince'
« Reply #120 on: May 16, 2013, 09:02:08 AM »
Oh my, Chris!  She is a looker, ain't she!  I might have to order one of these, dammit.
Pull the trigger Bud. You won't be disappointed. We just gotta get you started in 1:32 scale!
That's just beautiful work, Chris.  The rigging is looks great- there's more of it then you first think, isn't there?
You're right about that Dal. I thought there was hardly any at first glance, but I know better now.
« Reply #121 on: May 16, 2013, 09:39:12 AM »
Looks fantastic!
« Reply #122 on: May 16, 2013, 09:41:59 AM »
Excellent work Chris. She looks fabulous. I think weathering will take care of the wheel inside covers.
« Reply #123 on: May 16, 2013, 10:17:25 PM »
Looks really good, Chris.  Great job!
Best Regards,
Ernie
« Reply #124 on: May 17, 2013, 01:42:35 AM »
So, I'm down to the very last part to add to my Tripe. It's the propeller for the Rotherham petrol pump that is mounted to a cabane strut. I carefully left it off until the very last as I just knew I would break it off somehow. I touch it on the propeller shaft with tweezers and . . . PING . . . off it goes into oblivion. I haven't lost a part in years but this one is gone. I sent an e-mail to WnW in hopes of securing a replacement but I'm not holding my breath.
One of you fellows wouldn't have a spare one in your back pocket, would you? I thought not.
« Reply #125 on: May 17, 2013, 02:51:27 AM »
Ouch... trying not to laugh...
I do have a tripe in the stash if you want dimensions etc to fabricate a replacement until the proper part arrives...
« Reply #126 on: May 17, 2013, 03:21:45 AM »
Chris, you could probably make a much nicer one by cutting off a little rectangle of pe fret, sand or file to shape then twist the ends just a bit.  Drill a hole in the center, slap that baby on and maybe add a nut to the hub just to finish it off.  I think it would be more to scale than the kit part.  Just a thought.
« Reply #127 on: May 17, 2013, 05:12:03 AM »
If youre stumped do you have that reusable casting material BvB gave a link to? (or any casting material for that matter) I can send mine down the road for you if WNW fails you.
« Reply #128 on: May 17, 2013, 05:12:43 AM »
If it's not too much trouble, I'd appreciate that. Right now I'm just guessing, and I have a habit of guessing too big.
Yep, that's what I'm doing Bud. I'm using pop can aluminum though, as I find it easier to work with.
« Reply #129 on: May 17, 2013, 05:14:01 AM »
I don't have any of that but if my handmade propeller fails, I'll be looking you up.  ;D
Offline Ian from Doncaster
« Reply #130 on: May 17, 2013, 05:39:21 AM »
Chris this little prop looks very similar to the one used on the WNW Fe2B (Late) under the nascelle.  In that kit it is part R26, if you wanted to have a look at the instructions on WNW's site?
Now that Fee kit comes with 2 R sprues for duplication of other parts, but only one R26 is used.  Unfortunately, I lost one of mine to the carpet monster so can't help you there, but if anyone else has a Fee with remaining R sprue parts, perhaps they can help?
« Reply #131 on: May 17, 2013, 06:17:20 AM »
Hey guys, thanks for all of your suggestions! I've made a replacement from a strip of brass bar I had on hand and it looks the part. Images to follow.
« Reply #132 on: May 17, 2013, 07:00:46 AM »
Bravo! ...in the interim i made these for you, probably too late to be of use, but j.i.c.:
« Reply #133 on: May 17, 2013, 07:19:12 AM »
Thanks very much Bo! I want to apologize right up front for going ahead and making the propeller before you posted this information. I should've waited for this material or sent you a PM, but all of a sudden, there I was, shaping a piece of brass. As luck would have it, I'm right in the ballpark with the measurements you've provided. It might not look as good as the kit supplied piece, but if WnW do send along a replacement, it'll do until then.
Thanks again Bo for going to all of this effort on my behalf. I hope I can return the favour in the not too distant future.
« Reply #134 on: May 17, 2013, 08:22:29 AM »
No worries at all! Just figured since I shot the pics, might as well post them in case they might be of use. Anyway it was fun ogling the Triplane sprue. I suppose it will be some time before I get to mutilate it.
Glad to hear everything is shaped up and ready for the "completed" hangar. Congrats on a beautiful model.
