Author Topic: Way Off Topic - Pz.Kpfw IV Ausf H  (Read 3970 times)
« on: March 29, 2013, 09:30:51 AM »
After finishing my recent Bristol Fighter, I decided to take a bit of a break and build a tank model. The model is painted with Tamiya acrylics and I employed the hairspray technique to get a chipped paint effect in heavily traveled areas. The tow rope is nylon kite flying string. All in all, a fun little project which allowed me time to re-charge my WWI aviation battery.
Thanks for looking at something a long ways removed from WWI aircraft!
Offline lawman56
  • What about a pointed stick?
Re: Way Off Topic - Pz.Kpfw IV Ausf H
« Reply #1 on: March 29, 2013, 10:21:03 AM »
Looks really good! I have yet to employ the hairspray technique, but I think I'll have to give it try at some point. I really like the "spotted rust" effect you've managed to achieve.  :)
Joe Clark
"Illegitimi Non Carborundum"
« Reply #2 on: March 29, 2013, 11:02:08 AM »
A brilliant build Chris, very well painted and weathered and the tracks look very realistic. Your chipped paint result is perfect and a technique that could be used on WW1 aircraft especially around the engine cowls and wing leading edges, maybe you could give us a few hints on how you achived this result.
« Reply #3 on: March 29, 2013, 11:20:50 AM »
Great looking Panzer Chris! ;D  Whets my appetite to return to tanks for a change of pace. ;)
Offline LindsayT
« Reply #4 on: March 29, 2013, 01:11:56 PM »
Wow, Chris. That. Is. Awesome. Really beautiful paint job. One to be proud of.
Well done,
Lindsay
« Reply #5 on: March 29, 2013, 01:41:44 PM »
Very nice indeed, especially the paintwork and tracks.
Offline Edo
« Reply #6 on: March 29, 2013, 03:54:18 PM »
Hey Chris!
I am happy to discover that I am not the only one to take some detours on wwii subjects sometimes!  ;) at present I am working at a 88 cannond dio...
But your panzer does look really good,weathering is top notch!
Vry well done indeed!
Edo
Offline Andi Little
« Reply #7 on: March 29, 2013, 06:26:45 PM »
Great project - turned out very well. The weathering is up there with some of the best and the overall finish is particularly well executed.
A good solid job ... and very cleanly mucky !!!?
KBO ............. Andi.
Offline michael
« Reply #8 on: March 29, 2013, 07:27:21 PM »
Fantastic work there Chris ! Fantastic build and finish  :)
michael
« Reply #9 on: March 29, 2013, 10:43:23 PM »
Thanks guys for all of your kind comments.
As for the hairspray technique, this was something new for me and both Des and Lance Carroll have indicated that it has application in WWI modelling too, particularly with cowls and leading edges. That being the case, I'm tempted to give it a whirl on the cowl of my Sopwith Triplane, which I hope to start soon. I think it could be particularly effective on the corrugated skin of the WnW Junkers J.1, a kit which I had absolutely no interest in until now. Guess what I'm buying next.  ;D
All I did was lay down a sturdy base coat of red primer which was Tamiya Hull Red thinned with lacquer thinner. Then I applied two light misty coats of aerosol hairspray.
The camouflage colours were also Tamiya acrylics but thinned with tap water so they'd be easier to remove. When they were dry, I brushed water on the areas where I wanted to remove paint, leaving it for a minute or two to soak through to the hairspray. Then I used a flat, stiff bristle brush and gently scrubbed away at the paint until it started to chip. The hardest part is to restrain oneself from getting carried away with the effect! Click on the image below for an enlargement to see what I mean.
If you compare the image above with one below, you can see how the application of filters and washes tones down the effect though.
« Last Edit: March 29, 2013, 10:44:59 PM by Chris Johnson »
« Reply #10 on: March 30, 2013, 01:19:01 AM »
That looks great Chris! Thanks for sharing.
Offline Epeeman
« Reply #11 on: March 30, 2013, 06:48:34 AM »
Hello, Chris -
Model armour not really my thing, but what great workmanship on your part - looks very realistic!
« Reply #12 on: March 30, 2013, 09:24:09 AM »
Chris, that is one beautiful Model, even if it is of a "Target"! I hope you do use the hairspray method on your future WWI Builds as this example is perfect in my eyes, spectacular effect!
« Reply #13 on: March 31, 2013, 03:12:18 AM »
  Chris,
I can surely appreciate any Master Level work from any modeling genre, this latest project of yours is just that a Master Level project. Congratulations my old friend not only for this project but for all your Outstanding skill and craftsmanship.
« Reply #14 on: April 04, 2013, 05:20:43 PM »
That is world class armour modelling on show and worth the highest accolades. The weathering is outstanding and you should post this on some of the WW2 armour forums too. Fantastic work!
kind regards
