Author Topic: Der Kampfflieger Caproni Ca.3 1/72nd  (Read 828 times)
Offline NinetythirdLiberator
« on: May 26, 2026, 02:22:09 PM »
All,
Just started this one...one of my favorites!
I'm trying to leave mods to a minimum but I know I'll want to change some things.  It'll look cool next to the Gotha as well!
I've only cut some things out and started the main bathtub.  Added the fuel tanks and only did the slight mod of giving it a 1/32nd balsa floor backing and the same for the rear engine mount.  Less flimsy that way.  Looking nice so far.
Onward...Dogs Body Dan
Offline DaddyO
Re: Der Kampfflieger Caproni Ca.3 1/72nd
« Reply #1 on: May 26, 2026, 05:39:26 PM »
 :o Wowzer Dan - That's going to be quite an impressive model when built and I'm looking forward to following your progression
« Reply #2 on: May 26, 2026, 06:00:49 PM »
It will be interesting to see how you handle the complexity of this one in paper..... You like a challenge!
Offline enathan
« Reply #3 on: May 26, 2026, 09:21:47 PM »
Great! This is definitely a build log I will follow.
« Reply #4 on: May 27, 2026, 03:03:22 AM »
Thanks, Folks!  It is a strangely elegant plane (in my opinion, anyway) and has lots of rigging, drag, two booms and three rudders.  What's not to like!
Plus, it was usually a tail-sitter which will make my life easier...
Dan  ;)
« Reply #5 on: May 28, 2026, 02:44:12 PM »
I did some more basic cockpit with seats and instruments.  I also added a thin balsa floor to the nacelles and got them almost done.
So far, so good!
Dan
« Reply #6 on: May 28, 2026, 06:40:22 PM »
Definitely so far so good!
Offline Dirigible-Al
« Reply #7 on: May 29, 2026, 03:29:55 AM »
You don't pick many easy subjects do you! Another one to follow.
Alan.
« Reply #8 on: June 01, 2026, 08:33:02 AM »
Thanks, Guys...
A bit more.  It sort of fell together and this makes it easier to handle in some ways.  I put a thin piece of 1/32nd balsa (sanded a bit) in the bottom wing and the stab just for a bit of strength.  I'm amazed by the alignment which seems darn good so far.  The middle tub is just sitting there for show at this point.  Rigging will be a blast!
More soon...Dan
« Reply #9 on: June 01, 2026, 06:11:56 PM »
That's rapid progress and she is looking mighty good. No challenges so far......
« Reply #10 on: June 02, 2026, 11:32:04 AM »
Awesome work , she is going to be a pretty big size when finished .
Have always wanted to build this type in 48 scale ....maybe one day .
« Reply #11 on: June 26, 2026, 02:28:59 PM »
Life is finally got out of the way for a bit so I got all three engines installed as well as the nacelle rads and some piping for them.  Still figuring stuff out and more interior to go but I can't wait to start the struttery!
More soon...Dan
P.S. Alexis:  This download came with a 1/48th version.  Maybe someday!
« Reply #12 on: June 26, 2026, 06:06:13 PM »
Good to see some progress here, the engines look good in situ.
« Reply #13 on: June 27, 2026, 01:44:54 AM »
Thanks, Nigel!   ;D
I can't wait to start rigging as that will really make it look busy.  Today I'll add some more interior and start struts.  Stay tuned....
Dan
« Reply #14 on: June 27, 2026, 03:04:17 PM »
Tonight I got the 3-D yokes made from pulled plastic sprue and thin fuse wire as well as the pulled sprue exhausts.  I also added some more piping for the rear engine but it's just a best guess.  I need seat belts and then I'll start some fuselage rigging and then struts.  Lots of control cables that head out from the center fuse to the tails.
More soon...Dan
