Author Topic: Multi-Seat 2026 GB - RAF FE.2b A852 Night Bomber WNW 1/32  (Read 13004 times)
Re: Multi-Seat 2026 GB - RAF FE.2b A852 Night Bomber WNW 1/32
« Reply #45 on: April 29, 2026, 08:27:57 AM »
This is looking gorgeous, Prze. I'm hard-pressed to say anything that doesn't repeat what others have posted - but I like it a lot!
« Reply #46 on: April 30, 2026, 08:27:42 AM »
Thanks, Zac.
Today I attached the outer wing panels, second pairs of interplane struts and rigged 8 incidence lines.
« Reply #47 on: April 30, 2026, 10:19:05 AM »
Very very nice !
Offline acewwi
« Reply #48 on: May 01, 2026, 03:05:47 AM »
Hi Przemo,
Excellent and clean work, as always.
I have a question. In the previous FE.2b (Jess) for the incidence lines i think you used combination of eyelets and tubes.
Now I see clear lines. What material is used and how did you attach it?
Spyros
« Reply #49 on: May 01, 2026, 03:25:54 AM »
Thank you, Alexis!  :)
Hi Przemo,
Spyros
Hi Spyros. Many thanks for your kind comment. My first Fee was built some 15 years ago, when I used brass tubes for rigging. They may give an impression of turnbuckles but it was not intended. Fee had the RAF streamlined wires, no turnbuckles on the majority of rigging. Now I am using the polyimide tubing for securing the lines. And I continue to use the 0.12mm monofilament fishing lines, only that now I paint it with steel colour. Also the preparation of eyelet rigging stations is shown in some photos earlier in this thread.
« Reply #50 on: May 01, 2026, 06:05:40 PM »
Very impressive work, she's looking superb so far.
« Reply #51 on: May 03, 2026, 02:25:06 AM »
Main interplane rigging well underway, basically only the doubled lines to go. Also the bomb rack and u/c got their cables.
Online DaddyO
« Reply #52 on: May 03, 2026, 03:52:17 AM »
That is looking soooooooo nice  8)
« Reply #53 on: May 03, 2026, 08:57:32 AM »
Thank you, Paul.
The interplane rigging rigged! Just the outer doubled lines need their dose of steel paint.
« Reply #54 on: May 03, 2026, 11:15:14 PM »
This is really starting to come together now , wonderful work !
« Reply #55 on: May 04, 2026, 03:58:01 PM »
Thank you, Alexis.
More weekend progress - started working on tailbooms, prepared the tail skid and made the replacement for kit flattish PE representation of turnbuckles for rudder/skid cables.
« Reply #56 on: May 04, 2026, 06:42:37 PM »
Wow, this is a stunner! Superb work.
Can I ask about your rigging with turnbuckles? It looks like you are using Modelkasten which is threaded through the turnbuckle glued to itself and then neatly trimmed. Is this how you do it? I think it looks very realistic.
« Reply #57 on: May 04, 2026, 06:53:13 PM »
Thanks, Nigel.
I am actually using a darkish monofilament fishing line of 0.12mm. I attach it to the eyelets or eyes in the turnbuckles using the tube method - more precisely I use a polyimide amber tubing with 0.279mm internal diameter cut to very short sections, about 0.5-1mm long. It is the method I described in the Rigging for Everyone presentation available in this forum section.
Online DaddyO
« Reply #58 on: May 04, 2026, 07:34:39 PM »
More excellent detail work and the turnbuckles are a great improvement on the PE items. 8)
Interesting to note that you wrap the roundel slightly around the hinge line since this was something I was discussing recently . . .
« Reply #59 on: May 04, 2026, 08:12:39 PM »
Beautiful work Prze. I really like the scheme and will certainly save this for future reference.
