Author Topic: 1:32nd scale Sopwith 1 1/2 'Strutter' (1.B2)  (Read 7619 times)
« on: November 05, 2025, 10:33:31 AM »
The Se5a (Viper) and Spitfire Mk.1a dual build and the Fokker D.VII build are nearing completion.
Therefore I'm starting the next build.
A Roden kit for a French model of a Sopwith 1 1/2 'Strutter' (1.B2), Ser No.326 '7' of French Escadrille SOP226.
« Last Edit: December 10, 2025, 11:35:54 PM by Mike Norris (UK) »
Offline Scaleber
Re: 1:32nd scale Sopwith 1B1 Strutter
« Reply #1 on: November 05, 2025, 12:05:43 PM »
Looking forward to watching your build.  I wasn't happy with mine (all my fault) so will probably do another one in the future.  Its a great plane / Ian
« Reply #2 on: November 06, 2025, 12:41:30 AM »
As always I will follow your build. Hopefully I will learn what caused Mine to end in total destruction  :-[
« Reply #3 on: November 06, 2025, 03:29:15 AM »
Very nice choice. CDL or aluminium dope? I understand there's a bit of discussion over that (I'm no expert in this subject though.....)
« Reply #4 on: November 06, 2025, 05:17:01 AM »
I had read of Aluminium doped Strutters, but was guided by the Windsock data file 34.
It seems at the time of writing, doped Aluminium Strutters had not been known.
From what I now read it seems a few Strutters were supplied to the French for evaluation.
They were considered worth using and licenses were given to allow the French to build the aircraft for their use.
Production was slow to start, as happened with the earlier Caudron aircraft.
The Sopwith aircraft built by the French looked similar to the British counterpart, although it's thought the 1.A2 (reconnaissance) version may have had reinforced wings and different equipment.
However, only the few early models originally supplied British were clear dope linen.
Later French built Strutters were probably Aluminium doped and by the end of 1917, the five coloured dope camouflage was universally adopted.
The camouflaged aircraft had the standard French 5 colours pigmented dope. On the upper wings pigmented dope was used, which is why a difference can sometimes been seen in hue between doped surfaces and the roundels.
If the landing gear, cowlings and plywood coverings were camouflaged, it was with the standard paints.
On the Aluminium doped aircraft, the colouring was apparently:
One coat of clear tautening dope
Two coats of Aluminium tautening dope
One coat of clear finishing dope
That fuselage and wings were similarly doped.
The cowlings left the factory burnished (sometime painted in unit level) and the exposed plywood decking was varnished. The landing gear was either painted silver (most often) or left with the blue -grey protective paint.
As with most WW1 aircraft research, very little can be actually confirmed.
However, given this and the helpful comments elsewhere, I've decided to amend the colouring of this model to that of an all Aluminium doped finish.
« Last Edit: November 07, 2025, 10:30:13 AM by Mike Norris (UK) »
Re: 1:32nd scale Sopwith 1A2 Strutter
« Reply #5 on: November 06, 2025, 07:24:01 PM »
Thanks for sharing Mike. I know it's something Dave Hooper was looking in to when he was working on the Strutter schemes for Aviattic. Your choice makes sense given what you say. Looking forward to this.
Offline Flute
« Reply #6 on: November 07, 2025, 12:13:21 AM »
When the idea was first mooted I did up a Roden 1/48th in aluminium, (well, Citadel Mithril Silver IIRC). Had it on the table, I think it was in the GWICC days, at SMW. I remember everyone who commented thought it was a daft idea, back then. Nice to see it becoming more fashionable.
Paul.
Online Dirigible-Al
« Reply #7 on: November 07, 2025, 04:20:36 AM »
I'm in for following this one.
Re: 1:32nd scale Sopwith 1 1/2 Strutter (1.A2)
« Reply #8 on: November 17, 2025, 02:14:36 AM »
A few modifications for the Sopwith 1.A2 'Strutter'.
Changes to the airbrakes.
Addition of the operating pulley and cable slot for the airbrakes (port underside of fuselage).
Aileron fitting.
Elevator angle.
Rudder fitting.
Tubular carburettor air intakes.
Gaspatch Vickers machine gun offset to the left on the decking panel (not central)
Gaspatch Lewis machine gun on Scarf mounting.
Addition of control column rocking shaft and cover.
Addition of starboard panel between observer and pilot cockpits
More research to be done for possibly adding the following cockpit details:
Rear of the fuel tank and forward in the observer/gunner cockpit.
Fuel contents indicator.
Compass.
Control rods or cables.
Magneto starter switch.
Clock or watch.
Frame over front of fuel tank.
Tachometer.
« Last Edit: November 17, 2025, 02:45:31 AM by Mike Norris (UK) »
Offline Big Sky Modeler
« Reply #9 on: November 17, 2025, 06:12:15 AM »
Mike,
I'm guessing you are aware of this, but Memorial Flight has a French Strutter restoration with a lot of photos of the inside and outside.
https://www.memorial-flight.com/sopwith-strutter?lang=en
« Reply #10 on: November 17, 2025, 07:13:31 AM »
Mike,
Thanks - yes it's one of my resources for research.
« Reply #11 on: November 18, 2025, 08:00:40 PM »
Lovely detail work Mike, those additions really elevate the build. Excellent research as well, very helpful for other modellers.
« Reply #12 on: November 18, 2025, 08:49:13 PM »
When to two halves of the fuselage are joined together, the joint seam on the underside of the fuselage will be visible in the rear of the observer/gunners cockpit.
This was sorted by fitting a 1.0 mm thick plastic card insert,
« Reply #13 on: November 20, 2025, 04:18:09 AM »
The fuselage halves and cockpit parts have been painted
Tamiya acrylics used.
Wood and leather effect was made using ?Windsor & Newton? Griffin Alkyd oil paints (Burnt Umber, Burnt Sienna and Raw Sienna).
Fuselage halves and instrument panel gloss coated ready for decals, which is the next step,
« Reply #14 on: November 20, 2025, 05:55:13 AM »
That's a beautiful wood effect Mike!
