Author Topic: 1:32nd scale Fokker D.VII (OAW) - FINISHED  (Read 3768 times)
Re: 1:32nd scale Fokker D.VII (OAW)
« Reply #15 on: October 27, 2025, 07:34:18 PM »
Looking forward to seeing the decals on this one. And it's definitely not an SE5a...... ;) :)
« Reply #16 on: October 27, 2025, 11:29:02 PM »
I commented on your mis-post, but I will say again, nice decal prep. Looks gorgeous!
« Reply #17 on: October 28, 2025, 06:48:51 AM »
Nice work Mike !
« Reply #18 on: October 30, 2025, 12:17:13 AM »
Mike, I?m very impressed with your progress on this one, as always with your builds. I acquired the WnW decals for this aircraft and have the correct kit to build it?forgetting I had robbed the axle fairing from it to build Barker?s 1919 racing plane (with a large 50 on the side) many years ago. I plan on modifying a spare kit part to eventually build my own at some point. Looking forward to seeing your updates here, and taking notes as you go.
« Reply #19 on: October 30, 2025, 05:58:18 AM »
I've added all of the necessary decals now.
The fuselage, wings and control surfaces are all from the specific Aviattic set (?Aviattic? clear backed Seven Swabians (ATT32173) and (ATT32070).
Unfortunately the pre-shading on the wings and tailplane were not dark enough, so are not really visible.
Now it's onto the weathering stage,
« Reply #20 on: October 30, 2025, 06:22:46 AM »
Looks good to Me Mike! JMHO but I think too light is far better than too dark on the rib shading!
« Reply #21 on: October 30, 2025, 07:11:21 PM »
I'm with Rick, too light is better than too dark IMO :) . This is looking very nice, you did a great job getting all the panels neatly aligned and fitting well.
« Last Edit: October 30, 2025, 07:15:27 PM by NigelR »
« Reply #22 on: October 30, 2025, 08:15:34 PM »
Hi Nigel,
Yes the decal should not be separate.
Initially I thought that having the separate panel indicated that the whole panel would have been metal.
I also thought that maybe the decal could sink into the join line anyway.
So I cut and applied decal to the panel separate to the main fuselage.
I should have spotted in internal lozenge decal on the Aviattic sheet as a clue.
Bit late now to rectify sadly.
We live and learn,
« Last Edit: October 30, 2025, 09:02:49 PM by Mike Norris (UK) »
« Reply #23 on: October 31, 2025, 07:03:57 PM »
Don't worry Mike, you'll see I changed my comment to remove the nitpicky point I made. Only nerds like me will notice (and as I just went through that process on my DVIIF it was fresh in my mind). It's still a great looking build  :)
« Reply #24 on: October 31, 2025, 09:20:59 PM »
Hi Nigel,
You needn't have removed the comment.
It was correct and we all learn from others mistakes  ;)
Everyone of my 60 models have at least one error somewhere.
It's just most modelers probably wouldn't notice them, but I know  ;D
« Reply #25 on: October 31, 2025, 11:13:40 PM »
I was pretty sure you knew, which was why it didn't really need saying..... ;) :) But you are so right, we all need to make compromises as we build, and sometimes forget things, otherwise we'd never finish anything!
« Reply #26 on: November 01, 2025, 12:39:57 AM »
Another stunning model in the making...
« Reply #27 on: November 01, 2025, 05:03:44 PM »
The W's are done.
Weathered, Weapons, Windscreen.
Also the exhaust and a modification to add a flare pistol to the centre, leading edge of the upper wing.
The pre-rigging is also added.
Next up is assembly,
Online Jorgo
« Reply #28 on: November 01, 2025, 05:29:32 PM »
Wonderful made W s, excellent, chapeau !
Joerg
« Reply #29 on: November 01, 2025, 07:34:14 PM »
Lovely job on all the weathering Mike, it looks fantastic! Those are the details that bring the model to life for me.
