Author Topic: Tale of two Pfalz  (Read 5036 times)
Tale of two Pfalz
« on: August 28, 2025, 04:44:01 AM »
Zac asked what was next on the bench and slowly been working on these two kits . Roden's Pfalz D.IIIa in 72 scale and Ardpol's Pfalz D.VIII in 72 scale .
The Roden kit took a bit of work getting the top cowl piece in places and cleaning up that seem . The tail slot needed to be deeping lots , I could have still did more filing but I was get tired of this . The engine does not fit right all but I didn't do anything to correct this overly then a bit of sanding . The lower fit wasn't the greatest a bit of sanding took care of that . I used spare seat belts for the seat out of the used parts bin and a few instruments for the panel and compass . The decals where just junk , they just fell apart when they hit the water . Since I have no spare decals for this scale I was able to source ones which will work but the scheme is fictional .
The Ardpol kit is actually a pretty nice kit . Not a lot of detail in the pit so I added seat belts , instruments . Had to make a new control column kit one was broken . Spreader bar was wrapped so new one was made up for scraps of plastic . there was to be a single pop and the four blade on but the single one was missing in the kit so thise change the subject I wanted to do . Going through Jack Harris book I went for one with mods made for testing . So this is actually the D.VII and not the D.VIII . The resin struts got scraped and new ones made form contrail stock . Sad part is you you get two right parts of the tail plane ! so for this i will just flip that part over in this scale it won't be all that noticeable  . Gun jackets are PE ones the last set I had in this scale , The tail skid and flaring are scratched
Re: Tale of two Pfalz
« Reply #1 on: August 28, 2025, 04:44:33 AM »
Offline DaddyO
« Reply #2 on: August 28, 2025, 05:42:25 AM »
Nice - Two silver Pfalz'  8)
(Just acquired the Ardpol one myself as it happens so interested to see how it shapes up)  ;)
Offline Rip Van Winkle
« Reply #3 on: August 28, 2025, 07:31:36 AM »
 I will also be following these builds closely.  I also have just acquired the Ardpol kit.  Nervous about resin kits.
« Reply #4 on: August 28, 2025, 10:46:57 AM »
Thanks for sharing these. I'm keen to follow progress. They look lovely already.
« Reply #5 on: August 28, 2025, 06:09:13 PM »
Those are indeed looking very nice so far. Excellent work on overcoming the issues with the DVIII/DVII.
Offline Will Levesley
« Reply #6 on: August 28, 2025, 07:41:54 PM »
Both look great so far.  Built the Roden kit recently and also discovered that the tail plane was too far back by about 5 mm!  Interested to see how the Ardpol kit goes together.
« Reply #7 on: August 28, 2025, 08:37:15 PM »
Good job with the cowling fit on the Roden Pfalz. I?ve built several and always had great difficulty with it. The Ardpol kit is coming along beautifully.
Offline Brad Cancian
    • Brad's Models
« Reply #8 on: August 29, 2025, 06:35:08 PM »
Excellent work so for Alexis! I built the Roden Pfalz a ways back and remember it wasn't the easiest of builds... yours looks great!
BC
Offline Jorgo
« Reply #9 on: August 30, 2025, 05:30:27 AM »
Having built the Pfalz also I know that it is Not an easy journey but I'm sure you'll manage it . Great start.
Joerg
« Reply #10 on: August 30, 2025, 08:09:44 AM »
Very glad to hear not the only individual who has experience  fit issue with this kit .
Thanks for the support guys and the comments  :)
« Reply #11 on: September 02, 2025, 08:41:25 AM »
All parts have got their coat of paint and sealed in with future ready for weathering on both builds . For the Pfalz logo's on the struts I just replicated it with a dot of red paint . I don't have decals for the L for the left and R for the right , lots of them for 48 scale . A sharped pencil was used for that . Not the greatest but fills the part okay . I did make an attempt with the bungee cord for the axles and that I will say didn't turn out well at all . Does add strength and so flimsy . Made a start on the lozenge with the under surfaces . Aviattic   5 colour is being used for both builds .
Once this has dried for a few hours it will get clear coated to seal them and it will harden up the edges a bit for trimming the excess off with a new sharp blade and tiny bits remaining a small touch of Tamiya extra thin takes care of that . Then the upper will get done . I still have rib tapes left form a Aeroscale set so will use those on the D.VII , I might have enough pink for the D.IIIa if not I have a sheet of Aviattic blue fabric faded to slice up .
« Reply #12 on: September 02, 2025, 08:42:07 AM »
« Reply #13 on: September 02, 2025, 08:42:50 AM »
« Reply #14 on: September 02, 2025, 08:43:30 AM »
