Under Construction
Aces Mounts 2025 GB - Sopwith Triplane - R.Collishaw (1/32, WNW)
3
6
Topic: Aces Mounts 2025 GB - Sopwith Triplane - R.Collishaw (1/32, WNW) (Read 8373 times)
PrzemoL
August 10, 2025, 04:20:53 AM »
My entry to the GB.
I have started with the engine cowling. I always wondered if the kit part can be thinned down to fit Taurus Clerget. Well, after some work with DSPIAE grinder and sandpaper and testing with my old Clerget on the stand, it seems it cannot, yet not much is missing. So I still have hope - I will build a new Clerget with slight mod to set the cylinders closer to the axis, and then it should fit in.
KiwiZac
Global Moderator
Re: Aces Mounts 2025 GB - Sopwith Triplane - R.Collishaw (1/32, WNW)
August 10, 2025, 09:31:21 AM »
I'm sorry to see your original engine plan is a no-go, Prze, but I have no doubt you'll work out a terrific solution. A great choice of kit and subject!
NigelR
August 10, 2025, 06:15:43 PM »
Excellent choice for the GB, looking forward to seeing you do this one.
That's the problem with "scale" engines - they won't fit inside model cowlings unless they have been specifically downscaled for a kit. Best of luck with the new engine build.....
PrzemoL
August 10, 2025, 06:23:09 PM »
Thanks, Zac and Nigel.
And no worries, mates. That old Clerget was never meant to get to this model, I just used it for testing. And now I know, what to do, so that the freshly ordered one fits inside.
DaddyO
August 10, 2025, 06:32:43 PM »
Lovely choice of model Prze, shame about the cowl thinning, but at least as you say you now have a plan for the engine and getting it to fit
Allan31
August 11, 2025, 08:46:52 PM »
Hammer those rocker arms flat, will fit fine.
I want to do Collishaws "Black Maria: in 1/48 maybe for this GB......
PrzemoL
Reply #6 on:
August 14, 2025, 06:31:27 AM »
I hope I will not need to use a hammer...
The new engine has arrived. I trimmed a bit the crankcase so that the cylinders sit closer to the axis. And it seems to work. There is still some margin to accomodate the valve rockers.
I hope Łukasz will forgive me that cheating on the diameter of his masterpiece Clerget...
NigelR
Reply #7 on:
August 14, 2025, 06:17:57 PM »
Looks like you did it - keep that paint thin......!
PrzemoL
Reply #8 on:
August 14, 2025, 06:22:41 PM »
Quote from: NigelR on August 14, 2025, 06:17:57 PM
sure I will. There is indeed some gap around...
PrzemoL
Reply #9 on:
August 15, 2025, 08:33:44 AM »
The work on Clerget continues. It is actually my third take on it. And my awe for the magic that Łukasz used to produce it is not diminishing...
I am mostly using the wet toothpick tip to transport the tiny bits which fit like Lego bricks. And to secure them I use the clear gloss lacquer.
The part count stands at 120 now but it is not the end.
PrzemoL
Reply #10 on:
August 19, 2025, 04:36:20 AM »
Small progress, the back plate from Taurus fit to the kit firewall.
PrzemoL
Reply #11 on:
August 21, 2025, 08:27:08 AM »
Colours, colours!
NigelR
Reply #12 on:
August 21, 2025, 06:38:39 PM »
Quote from: PrzemoL on August 21, 2025, 08:27:08 AM
Colours, colours!
And lots of teeny tiny parts! Watch out for the carpet monster staring over your shoulder........
Allan31
Reply #13 on:
August 21, 2025, 11:34:39 PM »
That will look stunning Prz.
PrzemoL
Reply #14 on:
August 22, 2025, 06:34:12 AM »
Thanks!
Carpet monster devoured just one bit, a spark plug. Luckily Łukasz provides some spares of small parts as a sacrifice, so I even did not bother looking for it.
Well, the assembly is now well progressing, another 80+ elements added. Now only the electric wires and valve push rods need to be attached. And it all still fits inside the cowling!
3
6
Under Construction
