Author Topic: Eduard Sopwith Camel....  (Read 593 times)
Offline Allan31
« on: June 10, 2025, 01:11:26 AM »
Eduard Sopwith Camel. I can't tell if they are the same plastic or not.
Is the 8056 Camel plastic different than the 82171 plastic? Just different decals?
What one should I get?
Thanks....
Re: Eduard Sopwith Camel....
« Reply #1 on: June 11, 2025, 09:16:02 AM »
Going by Scalemates I believe they're different plastic: 8056 is the 2003 tooling (still a good build in my experience) with some new bits while 82171 is based on the 2021 tooling which by all accounts is excellent.
Offline Allan31
« Reply #2 on: June 12, 2025, 11:40:42 PM »
Thanks bunches Zac.
« Reply #3 on: June 13, 2025, 12:46:54 AM »
You can go to the Eduard site and download a PDF instruction manual for both and compare.
https://www.eduard.com/eduard/plastic-kits/profipack/aircraft/1-48/sopwith-f-1-camel-%28br-1%29-1-48.html
https://www.eduard.com/eduard/plastic-kits/profipack/aircraft/1-48/sopwith-f-1-camel-1-48.html
As stated before the higher # is newer.  Regards, Juan
