Author Topic: Albatros D.V, R. Flaschar (1/72, Eduard)  (Read 9362 times)
Offline Flamingo
Re: Albatros D.V, R. Flaschar (1/72, Eduard)
« Reply #60 on: May 24, 2025, 10:18:10 PM »
This level of detail in 72nd is breathtaking!
Joachim
jets are for kids
« Reply #61 on: May 25, 2025, 05:25:37 AM »
Thank you!
A small progress. Removal of wrongly placed cooling louvres and one too many inspection covers, the former ones will be replaced with Part PE details. Also, the spurious inspection covers on the lower wings underside pertaining to D.Va version removed.
And finally the tail bits attached and joints filled with CA glue as a putty.
« Reply #62 on: May 25, 2025, 07:38:06 AM »
This build is inspirational and just keeps rolling.
Warren D
Online NigelR
« Reply #63 on: May 25, 2025, 06:08:22 PM »
More excellent work!
« Reply #64 on: May 26, 2025, 12:24:04 AM »
Really nice work Prze !
Offline Allan31
« Reply #65 on: May 28, 2025, 12:49:59 PM »
Amazing stuff Prze.
« Reply #66 on: May 29, 2025, 04:54:04 AM »
Thank you.
Axial propeller carved from thin veneers. The spinner will be the combination of the kit part and PE back plate.
« Reply #67 on: May 29, 2025, 07:15:54 AM »
Wood coloured, Axial decals applied.
Offline enathan
« Reply #68 on: May 29, 2025, 07:51:22 AM »
Exceptional detailing for this (the right :) ) scale Przemol, absolutely fabulous!
Online NigelR
« Reply #69 on: May 29, 2025, 06:32:25 PM »
Beautiful!
« Reply #70 on: June 06, 2025, 03:19:29 AM »
The work goes on. The lower wing attached, seams cleared, primer set, PE fittings glued to the fuselage, some more will come later. And the exhaust and Spandaus got the colours.
« Reply #71 on: June 06, 2025, 07:08:11 AM »
Beautiful work Prze.
Hard to believe this is in 1/72.
If I hadn't known, you could have easily fooled into beleving this is in 1/32!
« Last Edit: June 06, 2025, 11:08:27 PM by Rookie »
Offline AngryJazz
    • @AngryJazz_Models
« Reply #72 on: June 06, 2025, 05:57:23 PM »
Oh god the size of those PE parts  :o
Very impressive progress - looking good  :)
//Ben - @AngryJazz_Models
Offline Allan31
« Reply #73 on: June 06, 2025, 10:54:45 PM »
Amazing.
« Reply #74 on: June 07, 2025, 02:52:54 AM »
Now comes the fun part , painting
