Author Topic: Swedish Albatros B.II, WNW 1/32  (Read 2635 times)
« on: April 18, 2025, 10:42:47 PM »
Hello again... after a longish period of inactivity I've found some modelling mojo again.
Next year the Swedish Air Force celebrates its centenary and I'm planning to build my WNW Albatros B.II in Swedish markings as a celebration of that, although the aircraft will be pre-SwAF and rather show the beginnings of the air force before it actually became one. Work has started and almost everything is ready for primer.
But, there are a few issues... The history of the Albatros in Sweden begins just before the war breaks out in 1914. A German pilot, Lothar Wieland, was asked by Albatros Flugzeugwerke to make a promotion tour from Berlin to Copenhagen, Stockholm, St. Petersburg, Warsaw and back to Berlin. That tour was cut short as he and a Danish passenger, on 26 July, landed in Stockholm. Wieland was unfortunate enough to hit a patch of soft ground and the aircraft turned over with some damage to the propellor, wheels and the rudder. Spare parts were ordered and arrived, but the new propellor didn't fit and then the war broke out.
Wieland was allowed to return to Germany, but the aircraft stayed in Sweden where it was repaired and then flew on until 1918 as number '6'. During the repair work the airframe was measured and copied and later at least five different manufacturers produced their own variants, some closer to the original than others. These manufacturers were Svenska Aeroplanfabriken (SAF), Sodertelge Werkstader (SW), Marinens Flygvasende (MFV), Nordiska Aviatikbolaget (NAB) and Flygkompaniets Verkstader Malmen (FVM).
Using an online service known as 'DigitaltMuseum' (digitaltmuseum.se) you can find quite a lot of images of the different Albatroses in Swedish service by just typing in 'Albatros'. After looking through the photos it becomes obvious that the easiest choice is to build either the original German Albatros labelled '6' or one of those build by Sodertelge Werkstader under the designation SW12. Most of the other copies used a different engine, how different I don't know but the SW12 used the 100 hp engine that comes with the kit which makes it easier. Most of the other copies also used a different radiator setup. Some copies, later versions perhaps, also had different aileron and rudder designs.
So, having decided on the original '6', or possibly one of the four SW12 aircraft as the differences are almost non-existent but several SW12's were issued with skis which are available via the Swedish company Flying Bear, there are still a few things that will have to be changed compared to the kit in the box. Below you see three images from DigitaltMuseum. The first two are of the German original, now in Swedish service as '6', one earlier photograph and one later. The last photo is of an SW12 with skis.
I can spot three important, but fairly easy, modifications.
First, even on the original '6' the elevator and rudder lines are routed differently than the kit version. So I'll have to patch up the holes in the tailplanes and make new exit holes in the fuselage for the wires.
Second, the rudder is different from the kit version. There is a possibility that the earlier photo of '6' shows the kit version (see below), but I think it's likelier that it is the more rounded version we see in the second photo. Almost all other photos of the early Swedish Albatroses have this rounded rudder.
Third, the exhaust is of a kind that isn't in the kit. Obviously, the first photo show a completely different engine and radiator and I won't be building that, but the later photo shows the side mounted radiators and this other style of exhaust which suggests a different engine. This exhaust is clearly visible in the last photo and I think that I can get away with using the collector part that comes with the kit and then 'only' fashion the very front end and the pipe that goes up and backwards.
The first fix is super easy I hope, just filling the holes and sanding. Making a new rudder seems easy, but does anyone have any suggestions on how to go about it - plasticard simply?! For the third modification I'm thinking about roughly shaping the front end of the exhaust with Milliput, sand that to shape and then add a piece of tubing of the correct diameter, but if anyone has any other ideas on that feel free to let me know.
Take care!
« Last Edit: April 19, 2025, 12:15:52 AM by FAf »
Offline Scaleber
Re: Swedish Albatros B.II, WNW 1/32
« Reply #1 on: April 21, 2025, 02:13:13 PM »
Great to hear your mojo's back.  Looking forward to seeing this come together. Cheers / Ian
« Reply #2 on: April 21, 2025, 05:26:35 PM »
Good to see you back Fredrik, this is a very interesting project. Looking forward to it.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #3 on: April 21, 2025, 06:48:47 PM »
Very exciting project! I really like the Albatros and look forward to your build  :)
//Ben - @AngryJazz_Models
Online DaddyO
« Reply #4 on: April 21, 2025, 06:56:35 PM »
Should be an interesting model when finished (and I love these 2 seat Albatros' so you definitely get my vote)
ps - re the rudder I've just found that a single layer of plastic card tends to get a bit floppy when sanded down so for this I'd laminate a couple of layers together which should help stiffen it up. Alternatively you could use 'Perspex' as William does for his tiny masterpieces which is a sniffer material to start with and will sand to a knife edge if needed
« Reply #5 on: April 21, 2025, 08:10:37 PM »
Hi Faf,
Bjorn Carlson of 'Flying Bear' has 3D printed skis for the Albatross.
I have a set and they are very well printed.
In case you wanted to build a ski versions.
As for gap filling.
I've started using UV cured clear resin.
It flows great and under cheap UV light hardens in minutes.
It can be sanded more easily than CA adhesive,
https://www.flyingbear.se/shop-2/#!/products/32102--skis-for-albatros-bii
« Last Edit: April 21, 2025, 08:15:46 PM by Mike Norris (UK) »
« Reply #6 on: April 21, 2025, 09:48:22 PM »
Thank you for your support and tips!
Paul - good advice that I happened to chance upon myself because I didn't have any thicker pieces of plastic card at home. The lamination of three 0.25 mm pieces is quite sturdy.
Mike - I found a third image of my intended machine and this time with skis, so I might be leaning towards skis... Good to know that you approve of them. 🙂
« Reply #7 on: April 22, 2025, 04:23:01 AM »
Interesting project and a great kit. I will follow along with great pleasure.
« Reply #8 on: June 09, 2025, 04:38:59 AM »
Good evening! Time flies... almost a month and a half since my last entry but at least there is some progress to show for it.
I started out trying to fix the main issues necessary in order to make it more like the Swedish version. That included filling the holes in the horisontal tailplanes, making a new exhaust and a new rudder. The holes were filled with bits of PC and then Tamiya Surface Primer to fill in the gaps. A couple of sessions with sand paper and more surface primer were necessary.
I then traced the rudder shape with the help of actual pictures and some guesswork. It turned out quite ok.
Until I realised that the whole vertical tail was too large. The height was very different on these early machines and so I had to make a new vertical stabiliser and then adjust the rudder size as well. This new version will require some more work making new hinges, but it's on its way. No picture of the new rudder.
Leaving these bits for the time being I went ahead with the cockpit. Everything fits very well and most things are just straight forward. But being an early early version means that the elevator cables were routed inside the fuselage rather than on the outside, so I guessed that there should be elevator arms(?) on the same axle connected to the steering wheel but on the inside instead.
And then I also added tubing where the elevator and rudder cables should come out of the fuselage on my version. And then it was all closed up.
And now I'm working on the engine. Bits of it will be seen, but I intend to close all hatches so the lower parts of it will be hidden.
« Reply #9 on: June 09, 2025, 06:44:22 PM »
Good progress here. That interior looks fantastic, and the changes you are making seem to be going well. A very interesting build.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #10 on: June 10, 2025, 05:03:09 PM »
Huge progress! The interior looks really great  :)
« Reply #11 on: June 10, 2025, 05:36:32 PM »
Now, that is a project surely worth following. Great work all around!
PS. Have you checked if the map on the observer desk depicts part of Sweden?  ;)
« Reply #12 on: June 23, 2025, 02:19:19 AM »
Thank you Nigel, AngryJazz and Przemo for checking in.
@Przemo - No, I haven't compared the map to Sweden.😄 Maybe I should?! Even if I think it's likely to be a part of the Western Front.
I haven't actually built much more, but I'm thinking about how to paint the wings and would be happy if I could get some input on this.
Below there are four pictures. The first one is from the Wingnut Wings library and it shows an German Albatros with very translucent Wings, so obviously not painted wings.
The second photograph is of the original German plane that crashed in Sweden and remained here when the war broke out.
The third and fourth are of Swedish SW12 aircraft - more or less exact copies of the one in the second photo.
I think it's clear that the Swedish versions aren't as transparent as the German one in the first photo. But if you zoom in on the top wing of the second and third photo you can see that part of the trailing edge is very thin and lets light through. That is also the case of the lower wing.
Now to my question/wondering - in the third picture I see quite dark ribs a fair bit in from the trailing edge; does that indicate that the wings are very light in clour and semi translucent? Or is that just a trick of light?
What do you think? Any and all input are most welcome.
Fredrik
« Last Edit: June 23, 2025, 05:35:24 PM by FAf »
« Reply #13 on: June 23, 2025, 06:16:46 PM »
IMO the wings are painted or covered in a pigmented dope, except for the clearly translucent areas. But it's your call - you have a photo, if it makes sense to you based on the photo, go for it!
« Reply #14 on: July 30, 2025, 05:50:02 AM »
Thanks Nigel, for your thoughts. I ended up exactly along your thoughts, which is shown below.
I've painted the fuselage in Gunze Radome and tried with at slightly darker base on the "corners". Will see if this can be seen later on. I've also started on the wood grain. It's going to be quite dark and with a darkish varnish too, so I've painted a couple of panels with burn umber. It'll take some time given the drying time needed in between panels.
As mentioned above, I came to the conclusion that the wings were doped in some sort of linen-like colour and non-translucent except for parts of the trailing edge. So I painted parts of the affected ribs with at thin wooden brown colour, later to be overpainted with lightened Gunze Sail. Next job was to paint the Swedish national markings in white and black. Masks were cut and used for this. The next step is to mask off the semi-transparent bits and all of the ribs and then spray it all with very thin Tamiya Smoke, which is my usual approach.
Fredrik
