Author Topic: 1:32nd scale Pfalz D.VIII  (Read 4681 times)
Re: 1:32nd scale Pfalz D.VIII
« Reply #15 on: April 16, 2025, 08:02:35 PM »
That's beautifully put together Mike. But how the heck are you going to paint it with things like the windscreen in place? Careful masking I presume.....
Hi Nigel,
The fuselage is already painted Silver/Grey - it just looks close to the printed resin color on the photographs.
Silver/grey - Tamiya Flat Aluminium (XF16) and Sky Grey (XF19) mixed 2-1.
The rest of the model is decal, apart from landing gear/struts,
« Last Edit: April 16, 2025, 08:07:23 PM by Mike Norris (UK) »
« Reply #16 on: April 18, 2025, 07:51:11 AM »
I've added the decals required for this particular model.
The engine is also complete and fitted,
« Reply #17 on: April 18, 2025, 06:44:14 PM »
That's looking even better now Mike, this is a lovely build. It's making me want to get mine off the shelf....
Phew! That would've been tough if it wasn't painted.
« Reply #18 on: April 18, 2025, 06:47:07 PM »
Good progress, another beauty in the making.
Offline Allan31
« Reply #19 on: April 18, 2025, 09:31:00 PM »
Great progress Mike.
I'm surprised how similar in design and construction the Pfalz is to the SS D.III.
« Reply #20 on: April 19, 2025, 04:51:10 AM »
This particular Pfalz D.VIII had bracing struts fitted between the fin and tailplanes.
These were represented using flattened 0.4 mm diameter tube.
The tubes were retained in position using 0.12 mm diameter mono-filament through holes drilled through the fin and tailplanes,
Offline Richtrad
« Reply #21 on: April 19, 2025, 02:34:11 PM »
Mike, this Pfalz is looking really really good as per. Especially love the engine, guns and cockpit.
Warren Q
Offline AngryJazz
    • @AngryJazz_Models
« Reply #22 on: April 22, 2025, 11:33:28 PM »
Just lovely work!  :)
//Ben - @AngryJazz_Models
« Reply #23 on: April 26, 2025, 02:38:22 AM »
Moving along now.
The model and upper wing have been weathered.
A combination of:
Flory Models fine clay wash (Dark Dirt and Grime).
AK Interactive Kerosene wash (AK2039).
Tamiya Weathering Master (Set D - Oil Stain) and (Set A - Mud).
Dry brushed ?Mr. Colour? Super Iron 2 (203).
Now it's onto pre-rigging before fitting the upper wing,
« Reply #24 on: April 26, 2025, 02:47:15 AM »
Excellent work, this is coming together really well.
« Reply #25 on: April 26, 2025, 03:15:08 AM »
Your build is coming along very nicely, Mike. The weathering touches look lovely.
« Reply #26 on: April 27, 2025, 05:33:24 AM »
The pre-rigged upper wing is now located, but not fixed to the struts.
I'll fix the struts in the upper wing once the rigging is complete.
That way I don't risk contaminating the various rigging lines with adhesive at the upper wing.
Now it's onto final rigging,
Offline Dirigible-Al
« Reply #27 on: April 27, 2025, 07:07:14 AM »
Now it's almost done it actually looks better than the profile picture on your first post.
Alan.
« Reply #28 on: April 27, 2025, 08:21:48 AM »
Great progress. This is anotherveey nice model on the finishing line.
« Reply #29 on: April 29, 2025, 01:43:29 AM »
While I'm waiting for turnbuckles to arrive, I've completed the pilot figure.
Painted with Tamiya acrylics and Citadel paints,
