Author Topic: Rib tape application question  (Read 1810 times)
Offline Big Sky Modeler
« on: March 25, 2025, 04:28:46 AM »
This question is for all of you who have applied decal rib tapes on top of lozenge decals.  Do you apply a clear gloss coat on top of the lozenge before applying rib tapes or do you apply the rib tapes directly on the lozenge decals?
Offline DaddyO
Re: Rib tape application question
« Reply #1 on: March 25, 2025, 06:21:08 AM »
Just done this on the current build.  :)
I tried adding the rib tapes without a gloss coat first (on a test wing) and had problems. Used a gloss coat and no issues at all. I also applied a coat after the rib tapes to seal them down. (Aviattic lozenge with Eduard tapes in this case)
Hope that helps
« Reply #2 on: March 26, 2025, 10:24:21 AM »
Thanks for the reply!  Just wanted to get some input before I proceed.  Didn't want to put an additional gloss coat on if it wasn't needed.
