Author Topic: Shelf Queen 2025 Group Build - Junkers D.I (1/32, Wingnut Wings)  (Read 7406 times)
Offline Allan31
Re: Shelf Queen 2025 Group Build - Junkers D.I (1/32, Wingnut Wings)
« Reply #15 on: March 13, 2025, 09:37:59 PM »
The rest of us mortals start with the cockpit.
Looks great.
« Reply #16 on: March 13, 2025, 09:41:10 PM »
Thanks everyone!
Why 2 propellers?
The work on the cockpit goes in parallel :)  Photos will come when colouring ends and assembly begins.
Two propellers??? I do not understand your question, honestly. Up there are two photos of one carved propeller - both sides, which will replace the kit plastic element. ;)
Offline Allan31
« Reply #17 on: March 15, 2025, 01:42:50 AM »
I hit post before realizing same propeller, front/back.
« Reply #18 on: March 15, 2025, 08:49:19 AM »
The office is complete. Now to the engine...
« Reply #19 on: March 15, 2025, 02:03:38 PM »
Beautiful work on the metal finish Prze !
« Reply #20 on: March 15, 2025, 07:18:30 PM »
Wow, that was quick! Lovely work, the cockpit looks great.
« Reply #21 on: March 16, 2025, 12:19:25 AM »
Quick work with No Loss of quality. SOP for you!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #22 on: March 17, 2025, 06:48:08 PM »
Wow looks great! Almost like a sports car for the weekend track  ;D
//Ben - @AngryJazz_Models
« Reply #23 on: March 23, 2025, 07:55:48 PM »
Thanks.
Finally some progress to report. The body assembled, treating of seams at some spots is necessary and quite tricky given the surface detail. I am using the water based putty and white one shot primer - that is why the model is partly white.
Also work on engine is on, with the basic elements coloured and prepared for assembly.
« Last Edit: March 25, 2025, 11:51:06 PM by PrzemoL »
« Reply #24 on: March 24, 2025, 04:18:42 AM »
It looks great assembled! Nice start on the engine. This one is coming together nicely as expected!
« Reply #25 on: March 24, 2025, 06:36:29 PM »
Looking very good. It's interesting to see how you approach building the engine, very helpful.
« Reply #26 on: March 25, 2025, 01:48:56 AM »
Ooooooo , the power plant !  :)
« Reply #27 on: March 25, 2025, 07:04:43 AM »
Mercedes engine assembled. I plan to add the air pipes, fuel pipes and control linkages, but these after it sits on its bearers.
And some grime to subdue the glossy look.
« Reply #28 on: March 25, 2025, 05:52:07 PM »
The engine looks terrific so far Prze. Well done!
Offline Jorgo
« Reply #29 on: March 25, 2025, 06:22:39 PM »
This will be another masterpiece from you, Prze! The metal finish of the fuselage and cockpit is exceptionally well done.
Kind regards
Joerg
