Author Topic: Shelf Queen 2025 Group Build. 1/72 Choroszy Misus-Aviatik G1  (Read 9790 times)
Offline Allan31
Re: Shelf Queen 2025 Group Build. 1/72 Choroszy Misus-Aviatik G1
« Reply #60 on: March 25, 2025, 09:52:49 PM »
That is magnificent.
I'm still thinking we all need to see your collection some how. I've been following you builds for years and i remember what's in there...
« Reply #61 on: April 01, 2025, 06:17:56 AM »
Awesome work! I have never been able to drill and pin struts, especially ones that size  ::) Looks fantastic with the wing mounted and rigging installed!
« Last Edit: April 02, 2025, 05:46:20 AM by RAGIII »
« Reply #62 on: April 01, 2025, 06:34:50 PM »
Superb Tim, what amazing modelling. This looks incredibly impressive.
« Reply #63 on: April 02, 2025, 05:33:02 AM »
Thank you all for your supportive comments.
Part 11. Drivetrain construction:
This turned out to be the most challenging task so far. Originally, I planned on using the kit resin framework pieces. These did not clean up well and were warped.
 I decided to scratch the entire structure with brass rod. I?ve never had good results with soldering. It seems to not adhere to the brass so I just CA glued it all together. I started with measuring and mounting the drive shaft and gear boxes.
Next I added the brass rods one by one. This turned out better because I was able to drill location holes in the fuselage for support.
I painted the forward rods before adding the rear ones for easier access.
Here are a few pictures of the completed structures.
I also completed the propellers and radiators.
Then I decided to start working on the eight wheels. I hate doing wheels, especially eight of them! The kit supplied ones seemed too small compared to the picture. I decided to cast some larger ones I had. One ended up with a big air bubble that I later filled with putty
All the wheels cast and two axels scratched up from metal. I didn?t want this beast resting on brittle resin axels.
Next came the machine gun cage for the observers. I?m going to try and use the resin parts here.
I have to hollow out the center and clean up the edges. This drill and bit came in very handy.
Here is the result of very patient shaving and filing. Only lost one little connection piece!
I should be able to finish this one up by next weekend.
Thanks for looking in!
Tim
« Reply #64 on: April 02, 2025, 05:48:06 AM »
Brilliant Modeling! Lovely results on all!
Offline enathan
« Reply #65 on: April 02, 2025, 08:31:13 AM »
Fascinating Tim, great work!
« Reply #66 on: April 02, 2025, 06:13:59 PM »
Wow, well done on that drive train, excellent modelling there. And as for those gun rings, don't breathe too heavily on them....... ;)
« Reply #67 on: April 02, 2025, 06:39:37 PM »
Great work there Tim, resin is always a challenging job, I imagine how brittle those rings are!
Offline Allan31
« Reply #68 on: April 02, 2025, 10:19:29 PM »
Beautiful progress.
« Reply #69 on: April 18, 2025, 11:50:28 PM »
Finally managed to finish this one.  It?s been a most challenging kit to build but enjoyable nonetheless. I don?t think this could be built out of the box with all the thin resin struts and flash ridden parts. I used a lot of brass rod and strip.
Here?s one picture,  I?ll post the rest in the completed section.
Thanks for all your support and comments. Always appreciated!
All the best,
Tim
Offline Skyhook
« Reply #70 on: April 19, 2025, 03:39:19 AM »
This is a totally amazing result!  I especially like how you could replicate the different textures and materials beautifully. Masterful model indeed.
Cheers, Skyhook
Offline AngryJazz
    • @AngryJazz_Models
« Reply #71 on: April 22, 2025, 05:12:34 PM »
Wow the level of detail on this build - bravo!
//Ben - @AngryJazz_Models
