Author Topic: Shelf Queen 2025 Group Build. 1/72 Choroszy Misus-Aviatik G1  (Read 9777 times)
Re: Shelf Queen 2025 Group Build. 1/72 Choroszy Misus-Aviatik G1
« Reply #45 on: March 04, 2025, 10:26:41 PM »
Thanks Paul, Nigel. I?m relieved that I hadn?t had the wings attached yet.
« Reply #46 on: March 09, 2025, 12:52:22 AM »
ARRRRRRGH!  :o
Done this myself on several occasions (you'd think I would learn) So glad to see that the damage wasn't too extensive and is already repaired. Looking forward to the next (hopefully not too exciting) update ;)
Same here. I dropped My WNW DH2 and the whole tail assembly came loose. Only held on by the rigging! You have made an excellent recovery! Happy to see that the mishap has turned out well.
« Reply #47 on: March 09, 2025, 11:02:22 PM »
Part 8.  Lower wing attachment.
I spent several hours masking all the ribs for the second time Friday. I only had the Mojo to complete the lower wing because it was my next choice for assembly.
This brings to mind a big drawback to the construction of these resin kits.  There are no clear step by step instructions, numbered parts, or any other clear part distinction. Only a crude exploded drawing for assembly. And when building an experimental aircraft, I can only find three photographs for reference.
Anywho, here is the completed lower wing. I overdid the Tamiya clear smoke and had to overshoot another light coat of Vallejo aged white.
Once that was sufficiently dry, I needed to plan out how to attach it to the fuselage.
I ended up going with the kit resin spars because they were pre molded as one piece. I drilled holes and added brass rod attachment points. ( Only stuck the drill bit into my fingers twice) 🥴
This pic shows the attachment spars and reinforcement rods (brass). This is surprisingly sturdy
Forgot to show you the complete tail section and rigging.
Here?s an overview of the project as it sits. Trying to decide if I should do the propeller structures or mount the upper wing next.
If you zoom in on the wing, you can see faintly see the spars and bracing wires.
Thanks for all the encouraging comments and
Thanks for looking in!
Tim
Offline Dirigible-Al
« Reply #48 on: March 09, 2025, 11:20:53 PM »
'Propeller structures or upper wing'. I would do first whatever is least likely to get broken while doing the other.
Alan.
« Reply #49 on: March 09, 2025, 11:44:47 PM »
Alan.
excellent advice! JMHO  8)
« Reply #50 on: March 10, 2025, 12:10:03 AM »
Great progress and great recovery work on this model.
Given the hyper-complex nature of its design, one should bear in mind that Austria is also the home of Sigmund Freud and psycho analysis . . .
« Reply #51 on: March 10, 2025, 01:30:53 PM »
Coming along quite well Warren . I'm taken by your wood effect , love it !
« Reply #52 on: March 17, 2025, 11:40:41 PM »
Part 9. Upper wing
Time definitely seemed limited this weekend. All sorts of distractions kept me busy and away from the bench. But, despite that I did get the upper wing completed and started working on the struts.
The lower wing ribs, framework, and internal structure was masked.
Then lightly overspray with Model Air aged white
Framework masking was removed and the rib masks were peeled back so they may be reapplied after the next painting.
Light layers of aged white were sprayed until it looked transparent
After it dried, I reapplied the rib masks and oversprayed Tamiya clear smoke to highlight the ribs. This was overdone with my heavy handed airbrush work again. I needed to apply another light aged white layer after the masks were removed. Next I applied the kit decals. I forgot to apply decal film and they cracked up pretty noticeably. They needed to be touched up to cover the cracking.
The upper wing is actually the same span as the lower but looks smaller in the picture.
I painted and added the landing gear supports
Now the model has legs to rest on
The kit resin interplane struts are way too flexible to provide any structural support for the upper wing
My first choice was to fabricate the struts from brass strip but I didn?t have any that looked thick enough for this large model
I decided on using Contrail strut material. It?s a little too wide when compared to the plans but will look just fine when used.
The strut is same width as the brass one just looks larger in the image
I?ve added some brass attachment pins to the ends.
Next up is painting them and upper wing attachment!
Tim
Offline Allan31
« Reply #53 on: March 18, 2025, 02:21:43 AM »
You clearly own a pretty big pair of brass ones to tackle this project.
Beautiful work my friend, you amaze....
« Reply #54 on: March 18, 2025, 04:39:19 AM »
Nice work on the struts. I have some of that Contrail strut material but never seem to have the size I need  ::)
Online KiwiZac
« Reply #55 on: March 18, 2025, 09:31:26 AM »
This is looking so, so pretty. Lovely work so far!
« Reply #56 on: March 18, 2025, 06:53:22 PM »
This really is a major project Tim, a lot of work involved and I am glad you are sticking with it because I am keen to see this one built. Excellent work on the wing and the struts.
Offline Skyhook
« Reply #57 on: March 19, 2025, 06:19:03 PM »
This one looks absolutely magnificient. So good details and the materials look just like the real thing, great stuff.
Cheers, Skyhook
Online PrzemoL
« Reply #58 on: March 19, 2025, 07:54:22 PM »
Great progress!
« Reply #59 on: March 25, 2025, 08:45:01 PM »
Part 10.  Upper wing attachment:
Despite having a full agenda this weekend, I was able to make serious progress on this build.
The struts were painted and wooden stain left to dry over the previous week. The struts attachment points were faired in with sheet metal. I replicated this with Tamiya tape covered in CA glue.
Starting with the four innermost struts, they were glued in place. Then the upper wing was attached and alignment checked. Gradually adding the rest of the struts working outwards.
Thank heavens the attachment pin holes were aligned properly!
I then began the rigging process with fine black EZline.
Next steps will be to add the propeller shaft structure and radiators.
Tim
