Author Topic: Lohner AA 1/72 prototype  (Read 2593 times)
Offline DaddyO
« on: January 21, 2025, 11:45:36 PM »
First one of the year finished (although to be fair most of it was done at the end of last year) :D
Lohner was one of many small manufacturers that produced aircraft during the first world war. This was the final development after problems with earlier versions and due to lackluster performance production wasn't required. The prototype fist flew late June 1917 and was later converted when the triplane craze swept Germany by adding a third wing; needless to say it wasn't a great success and Lohner ended up producing Aviatik Berg D1 designs under license.
The model is by Choroszy in 1/72 and due to the noted fragility of the medium only the main components were used. The struts were filed brass strip and wire soldered together (The prongs on the undercarriage legs are 'hop ups' for the mechanics working on the engine) Rigging is 1lb monofilament and the lovely wheels are 3 D printed items.
The varnished plywood of the fuselage is painted using oils over an acrylic base coat and the 'transparent' effect of the fabric covered wings is done with masking and layers of paint. The instruments are visible for once with some careful brushwork creating the dials. Prop is carved wood as usual.
Offline DaddyO
Re: Lohner AA 1/72 prototype
« Reply #1 on: January 21, 2025, 11:49:12 PM »
Interior before it was closed up (Instruments are painted apart from the floor mounted compass which was courtesy of Eduard)
Offline DaddyO
« Reply #2 on: January 21, 2025, 11:50:54 PM »
Pugnacious little thing ain't it?
Prop is my usual carved effort
Offline DaddyO
« Reply #3 on: January 21, 2025, 11:51:58 PM »
Tailskid detail before fitting and adding bungee cords
Offline DaddyO
« Reply #4 on: January 21, 2025, 11:53:18 PM »
Prop and struts (before the latter were primed with an etch primer which, I've found stops the acrylic top coats from flaking off)
Offline DaddyO
« Reply #5 on: January 21, 2025, 11:55:22 PM »
A quick view of the underneath to show the transparent rib effect. I used cross decals and oversprayed them a bit too much before doing the ribs so they are virtually invisible - ah well  ::)
Offline DaddyO
« Reply #6 on: January 21, 2025, 11:56:30 PM »
Last couple of views because why not? ;D
Offline DaddyO
« Reply #7 on: January 21, 2025, 11:58:26 PM »
 ;D
Hope you like. First time building a resin model I ended up pinning everything with tiny brass pins not very trusting of that new fangled 'superglue' stuff  :)
Thanks for looking
« Reply #8 on: January 22, 2025, 12:39:10 AM »
That is an absolute Beauty Paul! Another unusual bird finished to perfection !
Offline DaddyO
« Reply #9 on: January 22, 2025, 01:17:05 AM »
Cheers RAGIII
Finish isn't quite as good as I'd like, but learning all the time and it's such a pretty little thing. Just need a suitable base knocking up for it now  :)
Offline Bluesfan
    • MW Miniature Work
« Reply #10 on: January 22, 2025, 01:45:49 AM »
Thanks for showing us! Very nice work  :)
Offline Jorgo
« Reply #11 on: January 22, 2025, 02:01:25 AM »
Excellent in every aspect, the woodgrain is perfect and also the CDL. BRAVO !
Joerg
« Reply #12 on: January 22, 2025, 02:22:12 AM »
Very good and a little known type too. The prop and wheels are excellent - both very realistic.
« Reply #13 on: January 22, 2025, 02:59:34 AM »
Lovely work, she's a beauty!
« Reply #14 on: January 22, 2025, 03:36:26 AM »
That looks pretty darned good to me, nice work on the Choroszy kit. Hope we'll see it at Bovington...... :)
