Author Topic: Ki-45 Kai (Nick) Zoukei-Mura 1/32  (Read 5863 times)
Offline AngryJazz
    • @AngryJazz_Models
« on: November 30, 2024, 06:39:48 AM »
Hi guys
An update on what is on the bench  :)
I have recently finished 2 armor projects and want to get back to airplanes. This kit have been on and off my bench for about 1.5 years or more. Its time to get it done or throw it in the bin. I don't like to have to look at this HUGE kit taking up shelf space while being unfinished.
This build log is to try and keep me motivated and finally get the project moving.
The reason I lost motivation multible times was all due to poor fit on the exterior parts. The interior was very nice, but maybe I made small mistakes that caused issues.
The gaps - sanding, filling, scribing was too much.
Luckily its been on and off the bench so many times that most of the work is done (seams).
Hopefully it will be better from now on  ;)
To catch you all up with progress pictures
HUGE kit  :)
Current state of the kit - have since attached the tail and working on the landing gear area.
//Ben - @AngryJazz_Models
Re: Ki-45 Kai (Nick) Zoukei-Mura 1/32
« Reply #1 on: November 30, 2024, 08:25:10 AM »
Looking terrific! This seems like a very complex kit to Me. Especially compared to the OOB 1/72nd builds I am doing  ::)
« Reply #2 on: November 30, 2024, 07:32:54 PM »
Interesting. I knew these ZM kits had insane amounts of interior detail so it must be disappointing that the exterior parts are a poor fit. I can understand why that has slowed progress...
Offline DaddyO
« Reply #3 on: November 30, 2024, 07:41:27 PM »
Blimey AJ that's a big old chunk of plastic  :o
Got to say I have a proper soft spot for the Japanese aircraft of this period though - some beautiful designs and interesting colour schemes with (in many cases) the opportunity to have fun with the weathering  ;)
I remember falling in love with the old Airfix Dinah when I built it as a young lad and have enjoyed seeing others builds ever since
Offline AngryJazz
    • @AngryJazz_Models
« Reply #4 on: December 01, 2024, 06:29:14 AM »
Thank you all  :)
And yes absolutely insane amounts of details! There's even moulded pistons inside the engines  :o
From what I gather more people had issues with this kit, but some of their others should be very nice! But like WNW the tolerances are very tight, so im sure i caused a few of the problems myself.
I do like the colors of the Japanese planes, so like Paul says - its a good canvas for some fun  :)
Offline AngryJazz
    • @AngryJazz_Models
« Reply #5 on: December 05, 2024, 06:28:39 AM »
One thing i forgot to mention about the way ZM does their kits. They want to teach you everything about the plane as you build it. See it's inner workings come to life. Every part is named as you build it in the manual. This is the regular gas lever etc.
______________________________________________________________________________________________________
Finally the engines can be test fittet to the fuselage! Major milestone since it's the first thing you build when starting the kit.
Still need to be dusted off a bit better, but it's a nice feeling 😄
A lot of work has been made to get the wheel bays mounted. As anything from ZM - they are very detailed. You can see the engine details from the inside as well.
As you can see from all the filler - the underside is where I had the most issues with gaps etc.
However most is done and I took some time to fill and scribe a few other areas. I still need to fix a few more on leading edges and a panel or two.
Now to decide if I mount the engines and mask around or wait until after painting.
Waiting may result in more fit issues and i've already had many. It would be much easier to fill and sand at this stage.
 I should mention that i'll be cutting a few corners here and there. I already accepted this project will have to be completed to a lower standard than usual. For me it's more important not to lose my motivation trying to fix everything. I just want a decent model to display on the shelf 😊
« Reply #6 on: December 06, 2024, 02:42:34 AM »
WOW! Again, a lot of work but the Detail is amazing!
Offline Vickers
« Reply #7 on: December 06, 2024, 07:10:36 PM »
An ambitious project you've got there, AngryJazz. I have one in the stash and I even looked at the sprues once :o
Despite the fit issues that you've had to deal with it looks like you're bringing this complex kit together masterfully.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #8 on: December 08, 2024, 09:27:37 PM »
Thank you RAGIII and Vickers  :)
Im slowly getting closer to primer. Just need to sort out the last seams and the canopy.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #9 on: December 11, 2024, 01:01:04 AM »
After fixing quite a few issues I think its time for first round of primer  :)
Decided to mount the engines at this stage. With the fit issues I had i want to eliminate any surprises that might show up trying to fit these later.
« Reply #10 on: December 11, 2024, 12:10:34 PM »
I think I'd enjoy doing a Z-M kit - probably the Skyraider as it's the most appealing type to me - so until I have the funds I really enjoy seeing others build them. Great work so far!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #11 on: December 11, 2024, 05:05:25 PM »
Thank you very much Zac! I think you would enjoy them. I have a few ZM in the stash i really want to build soon. Like the 1/32 HO229 and HS-129 B3.
Most of their newer catalog should build very nicely!
Last night my wife wanted to do her nails so i got some extra time at the bench  ;D
Managed to sort out a few more things and get the Ki-45 primed. Then a quick buff of the primer with a sanding sponge before adressing some seams.
Think im ready for the first color  8)
I may go for the more complicated "spotted" camo
« Reply #12 on: December 12, 2024, 04:05:25 AM »
Great progress on a beautiful kit. A joy to watch!
« Reply #13 on: December 14, 2024, 12:02:21 AM »
I Totally Agree! Looking fantastic!!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #14 on: December 18, 2024, 05:18:06 AM »
Thank you very much both of you  ;D
The Ki-45 is slowly moving along! Had a lot of trouble getting the cowlings to fit, so all locating tabs had to go. Lots of pressure, glue and filler... But it looks alright now 😄
I wanted to have a panel removable for the engine, but I guess that will have to be for another build.
I painted the main colors for the top and underside (AK Realcolor 302 and 305) and gave the control surfaces a slightly different shade.
Next is a few highlights on both colors before I try my hand at the camouflage.
From the manual it looks like the grey has a bit of overspray from the green, so I will freehand the pattern and go back and correct the shapes afterwards. Should get me pretty close to what I want. The later weathering will also help to unify the colors - or so I hope 😅
The paint looks a bit more patchy on camera then in real life, not sure why. Also I will need to touch up a few areas on the wheel bay where a bit of overspray got in.
