Author Topic: 1/32 partial stripdown Short Wright Flyer  (Read 12560 times)
Re: 1/32 partial stripdown Short Wright Flyer
« Reply #45 on: May 30, 2025, 06:23:45 PM »
This just gets better and better. I love your attention to detail with things like the radiator, battery and controls. This really looks like a tricky build and I'm very impressed with your progress so far -keep going!
« Reply #46 on: June 01, 2025, 01:48:23 AM »
Great to see this one on the move again, Steve.
Looking great!   If it was me, I would be inclined to complete the main wing rigging first.   Dangly threads can easily get caught up in your hand whilst handling resulting in horrible drop accidents - as I can attest to personally!
« Reply #47 on: June 23, 2025, 06:02:01 AM »
Evening All,
Thank you Nigel and Dave for your comments - I much appreciate them. In spite of trying to make two scratch build simultaneously I have managed to do a little more to this project and not get confused as to what needs to be done on each project!
The supports for the forward skids and horns on which the front elevator was mounted were made from 40 x 60 thou strip. These were CA'd at the bottom where they are fixed to the brass bar skids, and cemented at the top where they are joined to plastic:
I have also added the clock which hung from one of the bracing wires near the pilot's head, but this is not visible in the photos. The control rod for the rear elevator ran from the left lever to the rear where it was connected to a horizontal bar: another control rod ran from the horizontal bar to the rear elevator. When the pilot moved the left lever forwards or rearwards the elevators at the front and rear would operate together. The rod from the left lever to the horizontal bar was fixed in place followed by the rear elevator. The elevator was supported by vertical struts - these were made from wood which had been filled with grain filler. A hole was drilled and enlarged on the fabric covered part of the elevator, and a gap cut in the spar on the uncovered side:
The control rod from the elevator to the horizontal bar at the rear of the lower wing has been inserted but is not yet fixed in position:
The side of the boom will be rigged when the control rod is permanently fixed.
I have also put on to the lower exposed wing section the tip bar and trailing edge "wire" - the latter is stretched sprue:
I am hoping that the next post for this project will be the last one - light is clearly visible at the end of the tunnel!
Thanks for looking.
Offline DaddyO
« Reply #48 on: June 23, 2025, 05:12:17 PM »
Lovely work Stephen. Already looking forward to the next post (as I'm sure, you are)  ;)
« Reply #49 on: June 23, 2025, 06:04:47 PM »
You confused me by switching threads to this one! :) Lots of lovely additional details and excellent construction work, it will be most impressive when it's done.
Online gedmundson
« Reply #50 on: June 25, 2025, 02:17:19 PM »
Sorry to chime in so late on this one - stunning work indeed, Stephen. So impressive.
« Reply #51 on: July 02, 2025, 09:25:26 AM »
Beautiful work !
Offline Skyhook
« Reply #52 on: July 02, 2025, 05:06:41 PM »
Hi!
Legendary stuff?.this shapes up to be a real stunner.
Cheers, skyhook
Online Dirigible-Al
« Reply #53 on: July 03, 2025, 04:02:10 AM »
I find it funny that you say you managed to do a little more. I hate to think how long it would take me to get to this. Great work!
Alan.
« Reply #54 on: July 06, 2025, 07:03:51 AM »
Evening All,
Many thanks Paul, Nigel, Gary, Alexis, Skyhook and Alan for your very kind comments - all are much appreciated.
When Rolls made his historic first return non-stop crossing of the English Channel, he had floats strapped to the underside and front booms in case he needed to ditch in the sea. Looking at the photos I estimated the size of the floats and covered two pieces of dowel and two pieces of plastic tube with crepe paper. I painted them grey to try to represent canvass covering - I suspect (but do not know), that the floats were some form of covered air bag because the Short Brothers had been making balloons for many years. In any event the photos of the aircraft show some form of fabric covering. The floats were tied to the airframe with thread as on the original machine they had been secured with rope:
The last major item to add to the airframe was the front biplane elevator. I had already made the flying surfaces and struts but I added the rigging first by drilling holes in the "solid" parts of the elevator surfaces. I cemented struts into the "solid " parts of the elevator surfaces and allowed these to set before the lower elevator was slotted over the left horn, (the right side had been broken off earlier in the build). The right horn was CA'd in place and supported with a conventional jig while the CA set properly:
When this structure was secure I could add the upper elevator, the central struts and then rig the whole. The boom supports from the wings to the undercarriage skids were made from 30 x 40 strip:
The early Flyers including the six built by the Short Brothers were launched from a wooden rail: the machine was mounted on a simple dolly which was attached to the skids and fell away on take off. I made up one of these from plastic strip with rod for the rollers:
The above image was taken before I had touched in the paint!
To complete the model I finishes attaching all of the remaining rigging wires - mainly anti-drag wires to the front and rear, and some bracing for the rear elevator. One of the last items added to the model were the propellors - these had been carved from wood and stained.
The above image shows the completed model before I mounted it on a base. I want to show the aircraft as it would have been prior to take off for Rolls' historic flight so I made a launch rail from basswood with wood strip for the ground supports:
The base was made from hardboard mounted on a wood frame, painted and covered with 2mm static grass. The rail was glued to the base:
Two trestles were made from strip wood to support the wings and stabilize the model on the launch rail. Finally the model could be placed on the trestles and rail and was considered finished:
I will post more pictures and notes in due course in the completed models section. The light has not been good today and the weather windy so I have been unable to take photos outside but I am hoping to have more luck tomorrow.
In the meantime, thanks for looking.
« Reply #55 on: July 06, 2025, 12:29:25 PM »
Bravo Stephen, she's a beauty! Thanks for chronicling the build and sharing it with us.
Online Dirigible-Al
« Reply #56 on: July 06, 2025, 03:07:18 PM »
Magnificent job and inspiring.
Alan.
« Reply #57 on: July 06, 2025, 05:44:58 PM »
You've done it again Stephen.
You are amazing us time and time again.
Looking forward to seeing more pictures of her.
Wilem
Online FAf
« Reply #58 on: July 07, 2025, 08:19:05 PM »
Great work! Very nice presentation of both work and finished model. I love the shape of the base.
