Author Topic: 1/32 partial stripdown Short Wright Flyer  (Read 12563 times)
Offline Boch
Re: 1/32 partial stripdown Short Wright Flyer
« Reply #30 on: April 08, 2025, 04:26:08 PM »
I love these pioneering machines. Their absurd shapes and improbable solutions. Great workshop and I keep my fingers crossed for further progress.
Lukasz
« Reply #31 on: April 08, 2025, 05:33:46 PM »
Great work and I love the engine Stephen.
This is another of your fine builds to follow with great pleasure!
« Reply #32 on: April 08, 2025, 06:33:54 PM »
More excellent work, I am loving that engine.
« Reply #33 on: April 09, 2025, 11:06:05 AM »
I always enjoy seeing your works in progress, Stephen, and this is no exception. Lovely, fine work.
« Reply #34 on: April 10, 2025, 03:31:56 AM »
Lovely attention to detail as always Stephen. I'm looking forward to seeing this come together!
« Reply #35 on: April 12, 2025, 06:24:55 AM »
Evening All,
Thank you Lukasz, Willem, Nigel, Zac and Ian for leaving your encouraging comments - I really appreciate them all.
It's official: the Short Wright model is now a real aeroplane, ie it has a spare wing!
I made the struts from wood as I considered that plastic strip might not be strong enough. The wood grain was filled with a mixture of talcum powder and dope and sanded down, followed by a coat of dope and a light sanding. I used the same mix of acrylics on the struts as I had used for other exposed wood parts described in the last post.
To hold the upper wing in place while I fixd the first set of struts was awkward because the solid part of the wing was quite heavy and had to be held gently in place with books! I also put a pot of paint between the rear of the booms to stabilize that part of the structure. Because the books completely obscured the card wing supports I have photographed the jig parts after the wing was in place but you can see their respective positions:
As usual this is all very high-tech Heath-Robinson, as per my usual building methods, but it worked.
The reason for the large gap in the centre of the front is that I am leaving the space clear so that I can more easily insert the engine, radiator, pilot's seat and frame and controls. I can however put in place some of the rigging to secure some of those pesky threads which seem to be permanently in the way.
Thanks for looking.
Offline Flamingo
« Reply #36 on: April 13, 2025, 05:19:28 PM »
Lovely scratchbuilding!
Cheers Joachim
jets are for kids
« Reply #37 on: April 13, 2025, 06:05:13 PM »
I agree, superb scratchbuilding. This is coming together very nicely.
« Reply #38 on: May 08, 2025, 04:52:23 AM »
Evening All,
Many thanks Joachim and Nigel for your comments.
I have had a checquered time recently, having been away twice in two weeks visiting family during holidays. In addition I found that the booms were not properly aligned after I have put the top wing in place, so I had to take it off and reset it - this time thing are properly aligned so I have been able to continue with the build.
I finished the elevators by adding the ribs from 20 x 30 strip which had been filed to shape. The ribs were added to the spars and the leading and trailing edge pieces were glued to the tips of the ribs with liquid cement.
The wooden frame of the elevators were painted the same colour as the remainder of the wood frame that would have been fabric covered on the real aircraft. I also made the rudders: one is the complete unit with frame and fabric covering (on one side only as per the original), and the other just the frame. These too have been painted.
The control for the wing warping consisted of a lever which operated a rod: the tail end of the rod moved from side to side, causing tension on a control wire. I made the rod from plastic rod with a hole drilled to allow the control wire to pass through. The front end of the rod was inserted into a hole in the control lever and the assembly superglued into place on the airframe. The warping wire guides on the upper and lower wings were cut from 15 thou card and superglued into place once the warping wires had been threaded through them.
The propellors were driven via chains which were channeled and protected in tubes. The chains passed over drives at the rear of the engine  and wheels on the ends of the propellor shafts. The propellor shafts were supported by triangular structures mounted between the wings.
I made the triangular supports and propellor drive shafts from brass rod which was soldered over a paper template:
These were primed and painted before they were mounted between the wings. The chain covers were also made from brass rod which was soldered: these too were primed and painted. The drive wheels on the ends of the propellor shafts were made from 20 thou scrap card.
The shaft supports were superglued to the wings and the drive shafts inserted and glued to the propellor shafts. Adding the longer chain drive from the engine to the prop shaft on the port (left side) required an unusual jig even by my Heath-Robinson standards. The chains around the drive wheels were made from stretched sprue.
Next I will start to add the features surrounding the pilot: there was no cockpit as such as (s)he sat on a seat mounted on a frame on the leading edge of the lower wing.
Thanks for looking.
« Reply #39 on: May 08, 2025, 05:46:02 PM »
This is incredible. Those ribs are amazing! Carving them consistently and getting them all properly aligned would be way beyond me. Fascinating to see how this is going together.
« Reply #40 on: May 11, 2025, 03:43:00 AM »
I echo this regarding the ribs - amazing work so far!   The engine you have made,  Steve lreally looks the part.   Great progress all round.
« Reply #41 on: May 11, 2025, 11:22:19 PM »
Really starting to take shape now , beautiful work so far !
« Reply #42 on: May 12, 2025, 03:02:45 PM »
Beautiful work all around and I agree with all the other comments on your work... but there's something fishy about it too, isn't there?! 😁
Offline DaddyO
« Reply #43 on: May 12, 2025, 05:13:08 PM »
Fabulous work going on here LM  8)
(I love the smell of dope mixed with talc which is something I grew up with)
« Reply #44 on: May 30, 2025, 08:03:16 AM »
Evening All
Thanks Nigel, Dave, Alexis, Frederik and Paul for your encouraging comments - they are much appreciated the more so as things are getting more tricky each time I add new parts to the model.
The radiator consisted of a series of vertical pipes mounted on the leading edge of the lower wing with pipes connected to the engine. I had drilled a hole in the lower wing a put a pin in the bottom of the radiator to make a secure joint. The pipes were made from 20 thou rod and connected the engine to the radiator. There was a small battery placed on the lower wing on the port (left) side of the engine: a small cable connected the battery to the engine:
The seat was CA'd to a frame made from 20 x 30 thou strip and the latter cemented to the ribs and solid part of the lower wing. A fuel tank was mounted between the inner interplane struts - the tank was made from plastic tube with card at the ends to block the hole in the tube. A water tank was also mounted between the struts and hung beneath one of the bars which held the fuel tank:
A control bar which actuated the rudders extended from the control lever on the right side of the pilot - this was connected to a cross bar on the lower rear boom which in turn was connected to the rudders by control wires. The bar from the control lever and cross bar were made from 20 x 30 thou plastic strip:
The rudders on the original machine consisted of a two wooden frames with a single sheet of fabric on the outer surfaces, joined with cross rods. I modelled the starboard (right) rudder with the fabric and the port (left) as just the frame. The fabric on the right side was represented with 20 thou plastic card and the frames made with 10 x 20 thou strip. 25 thou plastic rod was used to join the rudders and the whole rigged with monofilament thread:
When the rudders were finished I mounted them between the ends of the central booms and connected them to the control wires from the bar on the lower wing:
I have still to decide what to do next - either rig the wings and tie off some of the annoying threads or add the rear elevator and rig the rear booms: with several fragile parts sticking out and waiting to be knocked off or damaged I will need to consider carefuly how to proceed.
Thanks for looking.
