Author Topic: RAF BE12a (was Be2e) - 1/72  (Read 17870 times)
Offline torbiorn
Re: RAF BE12a (was Be2e) - 1/72
« Reply #45 on: October 19, 2024, 08:09:42 AM »
This is really a good looking project?. There?s not enough models of the BE-series done?looks very impressive.
Cheers, Skyhook
Cheers :). I was half-expecting Airfix to release more versions, especially the BE2e. I also started building a pair of Se5a:s, it?s interesting to see the relations and common solutions and developments of that and the BE2/BE12 and RE8.
Anyway, started with the Bluerider decals. The white rings going on the fuselage are too large, so I decided to try the improvised compass-cutting of white decal paper as shown by William Adair. I made an adapter to an office compass so I can adjust the radius:
Need to support the blade better, it?s too wobbly to cut masking paper, but sturdy enough to cut transfers. Lacking any white, I butchered a pegasus sheet:
First test was quite ok.
Hope it?s not too morbid with skull&crossbones in a memorial build, the thought just struck me.
« Reply #46 on: October 19, 2024, 09:59:37 AM »
That?s looking very promising. Really nice cut out with the decal.
« Reply #47 on: October 19, 2024, 05:45:47 PM »
This is really starting to look the part, very nice work so far. You did well with cutting out the white rings, I could never get consistent circles from that type of cutter.
Offline torbiorn
« Reply #48 on: October 21, 2024, 01:24:34 AM »
I am surprised that it worked.
Started assembling. With only one pair of struts I?m simply using lego blocks for support. The first thing is to cut the spars/metal wires attaching the lower wings to length (the lower wings are not attached directly to the fuselage, there is a <1 mm gap). Done by trial and error until a dry-fitted strut sat perpendicular to the base plate - lego bricks ensuring that the wing tips have the same height.
Second step, attach all wires at one end. Normally I glue them to the points in the upper wing, then thread the wires through holes in the lower wings. For various reasons the opposite seemed like a better option here.
I did paint myself into a corner: there are wires between the forward cabane struts attachment point under the wing and the very front of the fuselage frames, inside the panels in front of the engines (yellow arrow in photo below). I had arranged attachment points there (PE eyelets) - but forgot to add the wires before covering with the cowling panels!  >:(
Now I have to figure out a way to attach these without causing irrepairable damage.
« Last Edit: October 21, 2024, 01:49:39 AM by torbiorn »
Offline torbiorn
« Reply #49 on: October 28, 2024, 03:29:17 AM »
Wings are attached and rigging started. Surprisingly the struts and wings aligned rather well. The tailplane is angled wrongly, but brute force and some green tamiya should fix that. Fighting the clock now:
« Reply #50 on: October 28, 2024, 07:15:30 PM »
It's looking good, keep going! Best of luck with the tailplane wrangling......
« Reply #51 on: October 28, 2024, 08:05:10 PM »
Looking great. Fingers crossed for a timely and successful final.
Offline torbiorn
« Reply #52 on: November 15, 2024, 09:29:17 PM »
That didn?t go as planned? First she took a nose dive from 1.5 m straight into the floor, then I was prevented from modelling for three weeks. Eventually I?ve gotten around to mend the damages, and almost finish the rigging.
The last - but maybe most important - pieces to build are the reason why she is painted black in the first place: the landing lights. To help making landing after dark less perilous, the night fighters were supplied with various types of lights. This one seems to have had both Holt landing lights and Holt flares. The landing lights were very weak (due to weak batteries I suppose) so the main equipment were the flares which were hung under the wing tips. Some carried plenty: I?ve only seen Be12a and Be2e having one under each wing, so I went for that. As opposed to the battery-driven lamps, the flares burnt extremely bright and reflections on various parts of the planes tended to blind the pilots. The black paint was therefore not meant to hide the plane from the enemy, but prevent blinding reflections from the flares.
I took measures from a WNW Fe2b kit, which have both the lamps and flares. The landing lights are tiny, measuring 1.5mm in length with about 0.8mm diameter. These I turned from clear sprue, added a wire and painted first silver, then brass, leaving the ?lens? unpainted. They also had built-in port respectively starboard lights: these I took the sloppy approach and simulated with drops of paint.
The flares are more straightforward, and were put together from rod and tube:
Terribly out of focus, but here they are installed:
A couple of loose wires and missing pieces, but I?m finally getting there. Hopefully she will look less like Darth Vader up front with the propeller installed.
« Last Edit: November 15, 2024, 10:08:13 PM by torbiorn »
Offline DaddyO
« Reply #53 on: November 15, 2024, 10:28:16 PM »
Looking good matey and love the little flare/landing light details (I've pinched the building methods to use on mine when I get around to it) ;)
Looks quite distinctive in the all black finish so will be a nice addition to the collection
« Reply #54 on: November 16, 2024, 12:27:33 AM »
Glad it survived the nosedive! Those flares look fantastic, a lovely additional detail. Well worth the effort.
Offline torbiorn
« Reply #55 on: November 21, 2024, 10:06:05 PM »
Thanks again for following. Lots of finicky touchups to finalize it, but finally there. Will put some pictures in the ?completed? forum.
Offline Allan31
« Reply #56 on: November 24, 2024, 06:28:07 AM »
Great job, love the all black finish.
« Reply #57 on: November 24, 2024, 07:52:21 PM »
Nicely done, she looks great! I love the landing flares, a nice touch.
Offline Skyhook
« Reply #58 on: November 27, 2024, 12:57:17 AM »
Excellent model! The rigging is marvellous?. This prompts me to do a nightfighting BE too? i have often thought about conversion from the excellent Airfix Be2c, so maybe it is the time to walk the walk. I have several kits in the stash, as it can be found at very cheap prices. Hats off, inspiring and fine work!
Skyhook
Offline torbiorn
« Reply #59 on: December 07, 2024, 11:30:30 AM »
Thanks gents, I?m ratger happy with the resilt, it?s a stark contrast in the otherwise brown and green shelf. I?m left with Be2c wings and various bits, looking for a use.
