Hi all
The engine is test fitted now
I had to carry out a lot of adjustments to the engine support frames
It'll all be detailed when I release my usual PDF build log on my website, once the model is finished
But in summery
All three frames have no locations in the fuselage sides and are simple butt jointed, which makes aligning the frames difficult
All three support frames were too wide to allow the fuselage halves to close up
The main bulkhead frame did not have corner cut-outs to fit over the upper lower longeron's on the fuselage sides
When I test fitted the engine, I found that the fine detail printed on the lower sides of the engine (magnetos, housings, carburettor components and pipes) fouled the top edge of the fuselage right side
Also the engine was tilted up at the front, as the front frame is too tall
However, I managed to sort these anomalies out eventually
