Author Topic: 1:32nd scale Albatros D.V - COMPLETED  (Read 22291 times)
Re: 1:32nd scale Albatros D.V
« Reply #45 on: September 22, 2024, 06:18:40 AM »
The basic fuselage is complete.
For this particular aircraft, I've added:
Modified 'Gaspatch' machine guns.
Centrally suspended central gun sight (above the machine guns).
Gun sight viewing hole in the windscreen.
Altimeter in left side of cockpit.
Rear view mirror.
Flare pistol on its mounting.
Flare rack.
Kit supplied engine exhaust pipe hollowed out.
Now it's onto weathering the fuselage,
Offline Vickers
« Reply #46 on: September 22, 2024, 11:27:43 AM »
Your Albatros is really coming along beautifully. Nice work!
« Reply #47 on: September 23, 2024, 12:38:10 AM »
Looking awesome Mike!
« Reply #48 on: September 23, 2024, 06:08:39 PM »
Very nice indeed. I really like those additions, especially the gunsight. Now I can see the fuselage in a bit more detail, I definitely prefer your wood finish to decals.
Offline Umlaufmotor
« Reply #49 on: September 24, 2024, 01:48:39 AM »
Hi Mike,
........ I just noticed this while looking at your pictures:
I think Pheon made a small mistake here - the weight table was not painted on the right side of the fuselage.
Neither on the Albatros D.V, nor on the D.Va.
Servus
Bertl
« Reply #50 on: September 24, 2024, 04:46:33 AM »
Hi Bertl,
Thanks for the heads up.
I should have noticed that.
I'll see if I can remove the decal without damaging too much the wood effect,
Offline Umlaufmotor
« Reply #51 on: September 24, 2024, 05:45:36 AM »
Hi Bertl,
Hi Mike,
Perhaps it is better to mask the decals in the necessary places and then paint over the table - then apply some more wood grain.
Then you can also change the elbow contour from round to pointed (see original).
Servus
Bertl
Online Tim Mixon
« Reply #52 on: September 25, 2024, 03:42:53 AM »
Excellent work on this beautiful scheme Mike. I have a question about the ring sights on the Spandau jackets. Is that bracing piece running from the top to the rear just part of the 3-D printing or an actual part of the sight?
Tim
« Reply #53 on: September 25, 2024, 06:04:06 AM »
Thanks to Bertl for spotting the decal errors.
I've removed the capacity data decal from the right side of the fuselage.
Also re-shaped the elbow of the 'jester' decal on both sides of the fuselage, to better represent the actual marking,
« Last Edit: September 25, 2024, 08:58:13 AM by Mike Norris (UK) »
« Reply #54 on: September 25, 2024, 06:06:18 AM »
Tim
Hi Tim,
What bracing pieces?
 ;) ;D
« Reply #55 on: September 26, 2024, 05:17:07 AM »
the Upper wing and fuselage have been pre-rigged.
The upper wing now fitted.
Even the elastic bands are colour matched  ;)
Next it's final rigging,
Offline Allan31
« Reply #56 on: September 26, 2024, 07:38:28 AM »
Looks outstanding Mike.
Is there somewhere you demonstrate that subtle mottling on the wings, that's the effect I'm looking for on a Roland CII to break up the all blue/grey.
« Reply #57 on: September 26, 2024, 09:12:43 AM »
Hi Alan,
I apply 'Flory Models' fine clay (Dark Dirt or Grime) wash over a semi-matte clear coat.
Then remove what I want using a slightly damp  tissue or brush.
The method is detailed in most of my PDF build logs in the Weathering chapter and in the construction chapters.
Click the link in my signature and go to the 'Logs' pages on my site.
You can download any of the build logs from there,
« Reply #58 on: September 26, 2024, 05:57:28 PM »
Looking really good Mike, and nice work on those rubber bands....! :D
« Reply #59 on: September 26, 2024, 10:21:48 PM »
Lovely detail work. Looking Terrific.
