Author Topic: 1:32nd scale Albatros D.V - COMPLETED  (Read 22316 times)
Re: 1:32nd scale Albatros D.V
« Reply #30 on: August 21, 2024, 01:55:51 AM »
Looking very nice. Are you painting the plywood or using decals?
« Reply #31 on: August 21, 2024, 07:47:10 AM »
Hi Nigel,
Not sure.
I usually brush oils for wood effects.
However, I have the plywood decal set from 'Proper Plane', which I might try this time.
I've previously had a go with 'HGW' wood decals, but found them too fragile.
We'll see,
« Reply #32 on: August 21, 2024, 08:45:22 AM »
Lovely.
« Reply #33 on: August 21, 2024, 06:16:35 PM »
I've often been tempted to try decals but it seems difficult getting them to conform around the curved areas. I see that some of the Proper Plane sets are tailored for the DV, so if you use those I'll be interested to see how they turn out.
« Reply #34 on: August 21, 2024, 07:35:12 PM »
Hi Nigel,
I had used the 'Proper Plane' wood decal set for the Roland D.VI model by 'Wingnut Wings'.
I wrote a booklet on how to apply those decals.
Alex had it on their website, but no longer as the decal set is no longer available.
However, the techniques are just as applicable to the Albatros set.
I've emailed you a copy as it might be of interest,
« Last Edit: August 21, 2024, 07:40:10 PM by Mike Norris (UK) »
« Reply #35 on: August 22, 2024, 08:06:21 AM »
Looking wonderful Mike.
« Reply #36 on: September 17, 2024, 05:55:25 AM »
Progress on the Albatros.
Fuselage painted and plywood effect by Raw Sienna oil paint over Dark Yellow base coat.
Decals from the 'Pheon' set.
Kit circular access panels and cooling louvres removed and slots made under louvers.
Replacement were from 'Proper Plane.
'Aviattic' decals used for flying surfaces and on a mid-grey base coat (to slightly darken the decal colours).
Wing decals are from the 'Wingnut Wings' decal sheet.
All clear gloss coated to protect painted surfaces and decals from future handling, but will be semi-matte for final finish,
« Reply #37 on: September 17, 2024, 06:42:22 PM »
That's looking really good Mike. I see you decided not to use the wood decals after all, any particular reason for that?
« Reply #38 on: September 17, 2024, 07:41:00 PM »
Hi Nigel,
Despite a smooth and glossy surface, I had problems with patches of silvering on the first few decals I applied, even with PVA added to the decal water.
Therefore I reverted to using oils instead.
Anyway I think some wood effect decals are overstated with the wood grain too heavy and obvious.
When I've stood next to actual aircraft, the wood grain is there, but I think less obvious than some decals.
Just my take and others may disagree  ;)
« Reply #39 on: September 17, 2024, 08:06:35 PM »
I think your wood looks great - there's a hint of grain and I suppose that it would be more visible if one crept closer to the actual model.
/F
« Reply #40 on: September 18, 2024, 01:22:27 AM »
/F
I agree! Of course, I have always been a "Less is Best" guy with wood grain in scale! Lovely DV Mike!
« Reply #41 on: September 18, 2024, 06:18:20 PM »
Well, that's my take too, I totally agree ;) Oils are more subtle and controllable, it looks like you got a really good finish on this one.
« Reply #42 on: September 19, 2024, 05:41:19 PM »
Lovely progress, fine colours. I do prefer painting the wood over the decals, too. Yours is looking great.
Offline Umlaufmotor
« Reply #43 on: September 19, 2024, 10:55:32 PM »
Hi Mike,
very nice progress on your albatros.
The fuselage and the coloring on the wings look really good - I'm looking forward to the overall result.
One small detail:
The retaining plate for the turnbuckles on the wing root should be made of wood, not metal.
So no gray-green primer on these two plates.
It doesn't matter whether D.V or D.Va, this was built in the same way on both series.
Here on the replica it can be seen much better than on most of the original pictures:
Source The vintage Aviator and James Fahey
Servus
Bertl
« Last Edit: September 19, 2024, 11:00:46 PM by Umlaufmotor »
« Reply #44 on: September 20, 2024, 12:41:18 AM »
Hi Bertl,
Thanks for the heads up  ;)
I'm planning to replace the anchor point with the 'Proper Plane' parts anyway.
So I'll change the colour to wood then,
