Author Topic: 1/32 Roden Sopwith 1/2 Strutter  (Read 3852 times)
« on: June 25, 2024, 01:27:10 AM »
Dear all,
Finished the Roden Sopwith Strutter kit that was given to me by a fellow WW1 aircraft modeller last year.  The kit (parts wise) was all complete but was missing the clear film and decal sheets.
Following a request on this forum, NigelR was able to provide me a full Roden decal sheet as he has used the afternarket 'Aviattic' set.  Many many thanks, Nigel!
Nothing special here - I have built this one mostly OOB and rigged with 0.11mm fishing line for all bracing wires and knitting elastic to simulate control cables.   Finished by brush as always.
I also found this to be quite a demanding kit from Roden not helped by the 'instructions' that featured many mistakes and vague part placement.
Completed in second kit markings for No. 70 Sqn., RFC, flown by Lt. J H Gotch, Spring 1917.
Re: 1/32 Roden Sopwith 1/2 Strutter
« Reply #1 on: June 25, 2024, 04:44:50 AM »
Nice model, Dave, really looks the part. Great detail work and the rigging is terrific.
Great to see these Roden kits getting built, and built well.
Offline P.P.
« Reply #2 on: June 25, 2024, 04:30:00 PM »
I think this is great. I’ve been working with Roden kits too and I know it can be difficult. It’s a pleasure to see this one for me. Regards, Paul
Offline DaddyO
« Reply #3 on: June 25, 2024, 04:57:59 PM »
Lovely crisp building there Dave
Online PrzemoL
« Reply #4 on: June 25, 2024, 06:55:18 PM »
Very nice indeed.
« Reply #5 on: June 25, 2024, 07:04:25 PM »
That's turned out really nicely Dave, great job. I really like the subtle weathering on the underside and treatment of the structure showing through the CDL. The instructions can be more of a hindrance than a help on this one, I found Sandy's build on here very helpful.
Glad to be of assistance with the decals, TBH I had forgotten about sending those over (although to be fair it was a while ago....... ;) :))
I have recently rediscovered my store of knitting elastic and have been experimenting a bit with that. What was the brand you used - Prym?
« Reply #6 on: June 25, 2024, 07:35:20 PM »
Having seen this recently I can only add to the comments above that this is another of your first class models Dave. The weathering and rigging are top notch. I would never have guessed that you have to struggle in places with his model - it is a tribute to your skill and patience that it has turned out so well.
« Reply #7 on: June 26, 2024, 02:01:29 AM »
Many thanks, Sandy, PP, Paul, Prez and Stephen - appreciated!
« Reply #8 on: June 26, 2024, 02:05:18 AM »
Many thanks, Nigel -
You may this one possible, mate!
Regarding the elastic knitting thread.  Unfortunately, I don't know what make this is as I was given a small reel of this material from a fellow member of my model club.   All I can say it's not Pryme (I have and do use this) and this thread is slightly finer hence why I used it for simulating the control wires.
« Reply #9 on: June 26, 2024, 06:27:30 PM »
Thanks for that Dave, I shall investigate the options at the sewing/craft shop next time my wife goes shopping there......
« Reply #10 on: June 27, 2024, 04:22:17 AM »
Ditto all the above compliments !
« Reply #11 on: June 27, 2024, 08:01:57 AM »
Another Beauty Dave! As always, the painting and details are super. I admire those of you whom have mastered this kit. I fell victim to the sketchy directions. The W struts were installed wrong and I screwed it all up trying in vain to do a fix. Your build is inspiring and I know I will need to try again!
« Reply #12 on: June 28, 2024, 02:05:18 AM »
Your very kind, Rick -
Yes, the W cabane struts are a tricky part of the build for sure.  When first installed, mine were bowed on one side - I cured this by carefully cutting from under the upper wing and snipping (very small) sections away until they fitting correctly.
And yes, you must definately give this one another go.
« Reply #13 on: June 29, 2024, 09:46:01 PM »
Nicely modelled, Dave - a very handsome looking model.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #14 on: July 01, 2024, 03:52:58 PM »
Stunning model - really nice work! :)
//Ben - @AngryJazz_Models
