Author Topic: Junkers J1 1/72  (Read 7561 times)
Offline DaddyO
Junkers J1 1/72
« on: June 09, 2024, 04:44:37 AM »
Just completed this one and I'll take some photos tomorrow of the finished model, but here's a work in progress shot to act as a bookmark ;)
It is, of course, Eduard's lovely kit. This one's a profipack version (although if I'm honest I'd stick with the standard version if you are buying one since the only differences are the decals [ lozenge isn't usable because of the odd sizing] and the etch [the majority isn't seen and offers little advantage over the moulded plastic parts eg the radiator hidden deep in it's casing under the top wing]
In addition to correcting the upper wing dihedral issue by cutting the outer panels and raising the tips so the top of the upper wing is flat I put a fair bit of time into the rest of the build adding stitching on the rear section, replacing the moulded hatch detail, drilling out louvres and adding a small compass on the lower wing which was strangely missing. I replaced the horns with my preferred etched ones and detailed the fin mounting (looking closely at photo's it is very slightly raised above the fuselage and has a prominent fixing at the tip) Likewise the rudder shows a distinct gap where it joins the fin/fuselage so it was out with the brass wire.
I needed a jig to put the thing together since it's a bit of a beast despite the lack of rigging, but the brass pins added to the ends of all struts were a big help when it came to final assembly
Offline DaddyO
Re: Junkers J1 1/72
« Reply #1 on: June 09, 2024, 05:47:00 PM »
Right. . . . . drum roll please . . . I present the Flying Furniture Van  ;D
Offline DaddyO
Re: Junkers J1 1/72
« Reply #2 on: June 09, 2024, 05:48:15 PM »
The underside view I needed to add extra crosses to the underside of the top wing which weren't included in the kit.
Offline DaddyO
Re: Junkers J1 1/72
« Reply #3 on: June 09, 2024, 05:49:24 PM »
A close up of the side showing a few of the extra's added during the build (flares, handle, stitching  and fin details)
Offline DaddyO
Re: Junkers J1 1/72
« Reply #4 on: June 09, 2024, 05:50:33 PM »
Front view showing the carved propeller and compass added to the lower wing
Offline DaddyO
Re: Junkers J1 1/72
« Reply #5 on: June 09, 2024, 05:54:29 PM »
Finally on it's base with wheel chocks made from spruce with folded etch for the handles. I've yet to add the Parabellum mount in the gunners cockpit, but will probably leave the gun off since there are a lot of photo's showing them on the ground without the gun mounted.
I deliberately chose a simple 'green' scheme because I wanted to try and reproduce the faded and chipped paintwork seen in contemporary photos and most of the ones I've seen built go for a later camouflaged  version.
Re: Junkers J1 1/72
« Reply #6 on: June 09, 2024, 06:23:12 PM »
Lovely work, I really like the attention to detail on this one and that extra stitching looks great. Nice weathering as well, very effective and not overdone. I bet it's impressive, even in 1/72 scale.
Another absolute cracker, well done. Looking forward to seeing this one in the flesh. Although please touch up those visible white bits on the base before it gets on to the GWSIG stand...... ;) ;D
Offline DaddyO
Re: Junkers J1 1/72
« Reply #7 on: June 09, 2024, 06:29:19 PM »
Cheers Nigel
(Yep already touched them up - amazing how they can be missed and so glaring obvious when you take a picture) ::)
Tempted to add a couple of crewmen on the upper wing, but really need to press on with the Pfalz . . . .
Online Brad Cancian
    • Brad's Models
Re: Junkers J1 1/72
« Reply #8 on: June 09, 2024, 06:46:06 PM »
Very nicely done Paul! I have one of these in the stash half build from... oh... maybe 20 years ago...? Still not brave enough to tackle the 'challenges' with the kit - you have done magnificently!
Cheers!
BC
Offline DaddyO
Re: Junkers J1 1/72
« Reply #9 on: June 09, 2024, 07:32:44 PM »
Thanks Brad
Not as bad as it seems, so do have a go  ;)
This one was started a few years ago when I took the nearly purchased kit on a canal boat holiday and started cleaning up the bits in the evenings. It then languished in its box till I decided a nice 'quick' build was required (best laid plans etc.)
The wing error is easily corrected by gluing the whole wing together and then sawing through the bottom half only, at the join section, and inserting a strip of plastic card to push the wing level at the top.
Adding pins to the original plastic struts and drilling suitable holes means that with the model in a jig you can fit the struts a pair at a time without getting in a mess. The flexibility of the plastic means that the last pair can be bent slightly to spring them in place and once everything is glued it is pretty solid.  ;)
Offline Dirigible-Al
Re: Junkers J1 1/72
« Reply #10 on: June 10, 2024, 12:02:22 AM »
Well done Paul, you have done that lovely machine proud. Seeing this I really wish a kit of this was made in 1/48.
Alan.
Offline DaddyO
Re: Junkers J1 1/72
« Reply #11 on: June 10, 2024, 02:25:03 AM »
Thanks Alan
It's a big old bird and positively dwarfs the other 72nd models I've built (I've a hankering to build something really small next; perhaps one of the Kondor prototypes . . . .) :-\
Re: Junkers J1 1/72
« Reply #12 on: June 10, 2024, 02:57:13 AM »
Ye gods what a beast... great job, Paul, that prop is especcially lovely.
Offline DaddyO
Re: Junkers J1 1/72
« Reply #13 on: June 10, 2024, 03:13:23 AM »
Cheers Dutch (It is, indeed, a bit of a lump) ;)
Offline Big Sky Modeler
Re: Junkers J1 1/72
« Reply #14 on: June 10, 2024, 09:58:15 AM »
Great job on a unique subject.  One of my favorites.  I agree with others on the weathering, good looking without over doing it.
