Author Topic: My Simple Tribute - 1/72 Revell Fokker Dr.1  (Read 19071 times)
Re: My Simple Tribute - 1/72 Revell Fokker Dr.1
« Reply #45 on: July 19, 2024, 12:18:55 AM »
Fabulous work, Brad. You're certainly turning it into something special.
Offline Allan31
« Reply #46 on: July 19, 2024, 03:27:23 AM »
Beautiful job on that Brad. Perfect weathering.
I have one of those in the stash, your build may have moved it closer to top of the list.
Online NigelR
« Reply #47 on: July 19, 2024, 05:05:58 AM »
That's looking amazing for 1/72 Brad. That propellor is stunning in that small scale. This is going to be an absolute jewel when it is finished.
« Reply #48 on: July 20, 2024, 06:10:22 AM »
S P E C T C U L A R !
Offline Brad Cancian
    • Brad's Models
« Reply #49 on: July 20, 2024, 08:41:27 AM »
Thank you everyone!  ;D
Just working out how best to tackle mounting the wings and getting everything straight. Might try something a bit different this time around...
Cheers again!
BC
    • Brad's Models
« Reply #50 on: July 21, 2024, 05:44:36 PM »
Some more progress over the weekend. I decided to try something slightly different, and mount the top wing to the middle wing before mounting the assembly to the fuselage. I tried this as I wanted to use a method which ensured the top and middle wings were in alignment for the interplane and cabane strut pieces with a minimum of fiddling. So, first she became a biplane, at which point I also mounted the guns and did the rigging of the cabane struts and aileron wires.
Then, I mounted this assembly to the fuselage, followed by the bottom wing, while the glue was still not quite set, in order to facilitate any adjustments. With a relative minimum of fuss, I now have something resembling a triplane...!
The close up photos show areas where I need to do more touch ups, but at least a sigh of relief now the hard part of any triplane build is done.
Cheers!
BC
Online NigelR
« Reply #51 on: July 21, 2024, 06:16:47 PM »
Now that's a novel way to approach a triplane build, but it worked really well. She is looking very good indeed.....
Online DaddyO
« Reply #52 on: July 21, 2024, 07:53:52 PM »
That's a bold approach Brad, but worked well for you  8)
The model's looking great as well
« Reply #53 on: July 21, 2024, 11:42:01 PM »
A novel way to build the wing cellule but as others said it worked well! Your triplane is really looking fantastic!
« Reply #54 on: July 22, 2024, 11:40:04 AM »
The giant pegs startled me...then I remembered this is allegedly only 1/72. I still don't believe it - she's so gorgeous!
    • Brad's Models
« Reply #55 on: July 27, 2024, 05:13:39 PM »
Hi everyone - she is now finished!
For all of the completed build photographs, see link here - https://forum.ww1aircraftmodels.com/index.php?topic=14551.0
Thanks to you all for your encouragement through this build. I hope it to be a fitting little tribute to a larger than life man. Blue skies, Dave!
BC
« Last Edit: July 27, 2024, 05:20:53 PM by Brad Cancian »
Offline Dirigible-Al
« Reply #56 on: July 28, 2024, 01:35:36 AM »
WHAT A BEAUTY!
Well done Brad, a superb job.
Alan.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #57 on: July 29, 2024, 05:48:36 PM »
Beautiful build - well done  :)
//Ben - @AngryJazz_Models
    • Brad's Models
« Reply #58 on: July 29, 2024, 06:54:46 PM »
Thanks lads!  ;D
« Reply #59 on: July 30, 2024, 05:10:32 AM »
Stunning build and excellent Tribute Brad!
