Author Topic: Jeannin Stahltaube - a scratchbuild in 1/144 scale  (Read 37247 times)
Re: Jeannin Stahltaube - a scratchbuild in 1/144 scale
« Reply #150 on: August 07, 2024, 05:43:38 AM »
Simply wonderful!
I do love the color of this a/c. For years and years and years I want to say these have been portrayed as being colored as just CDL. However, this olive green is just beautiful to me.
Offline William Adair
« Reply #151 on: August 07, 2024, 08:36:30 AM »
What is grey  ???scale
Greyscale is one of the printer options where it uses black toner only. The other option uses a mix of the coloured toners to achieve black, but it can fade or take on strange hues over time.   ;)
Simply wonderful!
I like this one too   :D
This particular aircraft had the grey green fuselage, but also CDL wings. So it should give it a bit more contrast. It’s one of the options in the WNW kit. I would have liked an all-CDL finish, but I couldn’t find one with this engine variant. I’m learning to love it though.  ;D
« Reply #152 on: August 09, 2024, 10:08:29 PM »
Lovely work as always! The cockpit coaming looks properly worn!
Offline torbiorn
« Reply #153 on: August 13, 2024, 08:47:19 AM »
Oh, wonderful things I have missed, I shall savour going through this thread. In the meantime, by happenstance I took a few photos of the Stahltube in Berlin - I can share them if you miss something.
« Reply #154 on: August 27, 2024, 10:20:18 PM »
What a great shot! That answers all my painting questions for the engine  ;D
Offline torbiorn
« Reply #155 on: August 28, 2024, 08:07:17 PM »
Got plenty more if you need to see other details. Unfortunately not a lot from above, as access was difficult. I was there at closing time so didn’t feel it was the right moment to ask for a chair to stand on either…
Offline DaddyO
« Reply #156 on: August 28, 2024, 09:05:44 PM »
FFS (rude expletive)  ;D
I hesitate to venture into this thread, mainly because I'm always inspired to take up gardening or knitting when I see what you're up to  ;) To say that I'm gobsmacked would be a gross understatement I love it, love it, love it.
Joking aside I'm really enjoying the inspiration that this thread offers and love to see what's possible - congrats and look forward to the next stage
« Reply #157 on: September 01, 2024, 04:05:16 PM »
Ah, those moments always seem to happen at closing time for me too!  :D
Cheers Paul! I'm curious to see how this one will come out. So far (thank goodness) I haven't had an attack of the clumsies   :-[
I've been slow at the bench the last few weeks due to work and a bit of illness, but I was able to get back into it and made the early-style seatbelts for the pilot and observer. These are made out of painted cigarette paper which has been cut into strips and threaded through the circular links then secured with watered-down PVA.
The extreme closeup makes them look a bit scruffy. Although at that level of zoom, even the sheet of A4 paper they are resting on looks pretty rough!
Offline Thumbs up
« Reply #158 on: September 01, 2024, 04:57:42 PM »
They are AMAZING......Now i'm going back to bed!
Online NigelR
« Reply #159 on: September 01, 2024, 06:24:45 PM »
Those are indeed amazing. Your fine motor skills must be really good (your modelling skills certainly are!).
Hope you are fully recovered and that we will see lots of progress.
« Reply #160 on: September 01, 2024, 11:14:59 PM »
What can I say besides Brilliant!
« Reply #161 on: September 01, 2024, 11:27:01 PM »
I'm not sure scruffy means the same in my world... Stunning work!
« Reply #162 on: September 03, 2024, 12:42:36 AM »
Honey, I shrunk William!
« Reply #163 on: September 08, 2024, 02:40:50 PM »
Sometimes I wish! ;D ;D ;D
Here's a little more progress. I rummaged through my brass stock and soldered up the tubular header tank, which sits just ahead of the observer on top of the engine. This was fed by the gravity tank suspended above and behind the observer's head. If that wasn't enough, the poor fellow sat atop the unprotected main fuel tank.  Bloody hell...  🔥
The header tank was a tricky beast to make. The rear portion has a sort of wishbone support that needed to be lap-joined to a short vertical rod, which was threaded through a hole in the main tube and soldered into place. The vertical stack was pinned and soldered too, then the piece was trimmed/repeatedly dropped on the floor until I got a good fit. 👍
The main engine block was painted a mid-grey base colour, then masked and the brass manifold intakes were sprayed with Mr Metal Color 219 (good stuff that). It gives a very welcome steampunk look to the engine. I'll paint the header tank with the same brass colour, then add some brackets and clips from painted decal strip.
Here's a shot of the offending item:
And another shot of it dry-fitted above the engine:
Offline FokkerFodder
« Reply #164 on: September 08, 2024, 02:59:26 PM »
Wonderful work! Can’t wait to see it with its wings on…
Matt
