Author Topic: Jeannin Stahltaube - a scratchbuild in 1/144 scale  (Read 37008 times)
Offline William Adair
Re: Jeannin Stahltaube - a scratchbuild in 1/144 scale
« Reply #120 on: July 14, 2024, 10:35:56 PM »
This is truly a David to a WNW Goliath! Miraculous work!
That's a nice way of putting it. It really does feel like that sometimes!  :D
I hadn't tackled the padding around the cockpits yet, so I tried something a little different and built the coaming up gradually by painting it freehand with layers of Mr Surfacer and a fine brush. This worked out surprisingly well, as the cockpit edge helps guide the brush and you get a nice even line.
The other detail was the lower rudder and vertical stabiliser. The first version that I made was just styrene and sprue, and I was worried it might be too flimsy. I made a new-improved version and soldered it together with the kingpost and locating pins from .2mm nickel silver. Just for fun, the rudder and stabiliser are made from 18ct yellow gold.
I also started thinking about the rigging too. One clear photograph of the Jeannin Taubes shows the elevator and aileron lines anchored to little curved mounting horns. I drilled a 0.1mm hole at each rigging point and wrapped some wire around a .7mm drill bit to make some C-shaped horns. It should be posible to thread these through the control surfaces and attach the rigging to them when the time comes. The test looks quite promising, although the radius of the circle seems a bit small.   :-\
« Reply #121 on: July 15, 2024, 12:49:33 AM »
Incredible modeling...Pure Gold  ;D
« Reply #122 on: July 15, 2024, 02:05:26 AM »
Wow!  Just wow.
Offline Dirigible-Al
« Reply #123 on: July 15, 2024, 03:27:56 AM »
You are a very brave man to rig a Taube in 1/144, my hat off to you.
« Last Edit: July 15, 2024, 03:39:46 AM by Dirigible-Al »
« Reply #124 on: July 15, 2024, 03:38:55 AM »
Oh stop it, I couldn't even drill a .1mm hole let alone fabricate clever rigging fixings to go in them!!!
Superb work, really fascinating to watch.
Offline Flamingo
« Reply #125 on: July 15, 2024, 04:10:14 AM »
More tiny miracles!
"you get a nice even line"  NO, tried something similar in 72nd and it was not even at all.
Drilling .1mm holes - I would break 3 drills per hole, minimum.
Your model is so precious, no need to use material that cost  50€ per gram!!
jets are for kids
« Reply #126 on: July 15, 2024, 04:46:02 AM »
Wow!  Just wow.
And two more from me...  :o
« Reply #127 on: July 16, 2024, 04:53:24 AM »
Quote
And I would leave the end of one of the broken drill bits stuck in the hole!
« Reply #128 on: July 17, 2024, 11:47:49 AM »
Oh I break the drill bits all the time too! I think I only got away with it this time because the control surfaces are only .15mm thick and I rested them on a block of neoprene rubber while I was drilling.  That way when the drill bit broke through the plastic it didn’t hit a hard surface and shatter. 👍
« Reply #129 on: July 17, 2024, 05:55:58 PM »
All I can do is shake my head in admiration and amazement. The idea of building a Taube kit in 1/48 or even 1/32 is daunting enough...and that's after someone's made the bits for me!!
« Reply #130 on: July 17, 2024, 09:21:57 PM »
I was watching "Tales of the Unexpected" on the telly the other evening and I'm sure I saw you, William, in one of the episodes?
« Reply #131 on: July 22, 2024, 12:18:59 AM »
There is a certain resemblance.  ;D ;D ;D
Finally starting to get some paint on. I masked off the ribs on the tail and sprayed a lighter mix of the base colour for a slight contrast. With luck I might be able to do the CDL on the wings tomorrow. After that, I'll need to do some shading and try my hand at the squiggles on the cowling.
« Reply #132 on: July 22, 2024, 06:14:59 PM »
More quality work. That is looking really good, a lovely finish on the painted parts.
« Reply #133 on: July 22, 2024, 07:07:11 PM »
I agree, it is just so clean and neat.
Alan.
« Reply #134 on: July 22, 2024, 07:46:00 PM »
Thank you to you both!🙏  That is very kind of you. I usually spray at about 25psi with paint that is very heavily thinned. The airbrush is held about 25-30mm away and sprayed in very rapid passes to stop the paint from getting too thick and running. I don't know how this would work for larger objects (probably not well) but it gives a pretty smooth finish on the small stuff.
